[FIXED]Problème postfix envoi de mail: qmgr ne se connecte plus à smtp
Problème postfix envoi de mail: qmgr ne se connecte plus à smtp [FIXED] - Réseaux - Systèmes & Réseaux Pro
Marsh Posté le 12-03-2009 à 11:40:20
Je suis confronté à un problème avec postfix qui m'échappe complètement. Le qmgr ne communique plus avec le smtp suite à un upgrade du serveur.
Voici mes infos:
postconf -n:
alias_database = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
alias_maps = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
append_dot_mydomain = no
biff = no
broken_sasl_auth_clients = yes
config_directory = /etc/postfix
debug_peer_list = 127.0.0.1
default_transport = smtp
home_mailbox = .maildir/
inet_interfaces = all
mailbox_command = /usr/bin/procmail
mailbox_size_limit = 0
mydestination = red.tiny.be, localhost.tiny.be, localhost
myhostname = red.tiny.be
mynetworks = 127.0.0.0/8
myorigin = /etc/mailname
recipient_delimiter = +
relayhost = smtp.tinyerp.com
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, check_policy_service inet:127.0.0.1:60000, reject_unauth_destination,        reject_rbl_client zen.spamhaus.org,        reject_rbl_client bl.spamcop.net,        reject_rbl_client cbl.abuseat.org,        reject_rbl_client list.dsbl.org,        permit
smtpd_sasl_auth_enable = yes
smtpd_sasl_authenticated_header = yes
smtpd_sasl_security_options = noanonymous
smtpd_tls_CAfile = /etc/postfix/cacert.pem
smtpd_tls_auth_only = yes
smtpd_tls_cert_file = /etc/postfix/smtpd.cert
smtpd_tls_key_file = /etc/postfix/smtpd.key
smtpd_use_tls = yes
tls_random_source = dev:/dev/urandom
transport_maps = hash:/etc/postfix/transport
unknown_local_recipient_reject_code = 450
virtual_alias_maps = hash:/etc/postfix/virtual_aliases, hash:/var/lib/mailman/data/virtual-mailman
virtual_gid_maps = static:5000
virtual_mailbox_base = /var/mail/vmailbox/
virtual_mailbox_domains = tinyerp.com
virtual_mailbox_maps = ldap:tiny, ldap:tinyindia, hash:/etc/postfix/virtual_mailbox
virtual_uid_maps = static:5000
le master.cf:
smtp inet n - n - - smtpd
2525 inet n - n - - smtpd
#submission inet n      -       -       -       -       smtpd
# -o smtpd_etrn_restrictions=reject
#628      inet  n       -       -       -       -       qmqpd
pickup    fifo  n       -       n       60      1       pickup
cleanup   unix  n       -       n       -       0       cleanup
qmgr      fifo  n       -       n       300     1       qmgr
#qmgr     fifo  n       -       -       300     1       oqmgr
rewrite   unix  -       -       n       -       -       trivial-rewrite
bounce    unix  -       -       n       -       0       bounce
defer     unix  -       -       n       -       0       bounce
trace     unix  -       -       n       -       0       bounce
verify    unix  -       -       n       -       1       verify
flush     unix  n       -       n       1000?   0       flush
proxymap  unix  -       -       n       -       -       proxymap
#smtp      unix  -       -       n       -       -       smtpd
relay     unix  -       -       n       -       -       smtp
#       -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq     unix  n       -       n       -       -       showq
error     unix  -       -       n       -       -       error
local     unix  -       n       n       -       -       local
virtual   unix  -       n       n       -       -       virtual
lmtp      unix  -       -       n       -       -       lmtp
anvil     unix  -       -       n       -       1       anvil
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# maildrop. See the Postfix MAILDROP_README file for details.
maildrop  unix  -       n       n       -       -       pipe
  flags=DRhu user=vmail argv=/usr/local/bin/maildrop -d ${recipient}
uucp      unix  -       n       n       -       -       pipe
  flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
ifmail    unix  -       n       n       -       -       pipe
  flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp     unix  -       n       n       -       -       pipe
  flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -d -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
  flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
# only used by postfix-tls
#tlsmgr   fifo - - n 300 1 tlsmgr
#smtps   inet n - n - - smtpd -o smtpd_tls_wrappermode=yes -o smtpd_sasl_auth_enable=yes
#587   inet n - n - - smtpd -o smtpd_enforce_tls=yes -o smtpd_sasl_auth_enable=yes
tlsmgr    unix  -       -       -       1000?   1       tlsmgr
scache    unix  -       -       -       -       1       scache
discard   unix  -       -       -       -       -       discard
#gnarwl    unix  -       n       n       -       -       pipe flags=F user=gnarwl argv=/usr/local/bin/gnarwl -v $sender $recipient
#spamassassin unix  -       n       n       -       -       pipe   user=nobody argv=/usr/bin/spamc -e /usr/sbin/sendmail -oi -f ${sender} ${recipient}
Mon message d'erreur dans les logs (var/log/mail.log):
postfix/qmgr[23389]: warning: connect to transport smtp: Connection refused
L'envoi de mail se fait bien par d'autres biais: local, virtual. Seul le smtp foire.
Voici le résultat d'un strace de qmgr:
Process 23389 attached - interrupt to quit
select(16, [5 6 10], [], [5 6 10], {5, 816000}) = 0 (Timeout)
time(NULL)                              = 1236854378
alarm(333)                              = 315
socket(PF_FILE, SOCK_STREAM, 0)         = 8
fcntl64(8, F_GETFL)                     = 0x2 (flags O_RDWR)
fcntl64(8, F_SETFL, O_RDWR|O_NONBLOCK)  = 0
connect(8, {sa_family=AF_FILE, path="private/smtp"}, 110) = -1 ECONNREFUSED (Connection refused)
close(8)                                = 0
stat64("/etc/localtime", {st_mode=S_IFREG|0644, st_size=2945, ...}) = 0
send(7, "<20>Mar 12 11:39:38 postfix/qmgr"..., 95, MSG_NOSIGNAL) = 95
ioctl(3, FIONREAD, [100])               = 0
Là, je sèche, s'il y en a qui ont des idées. Merci d'avance!
Message édité par fredux200175 le 19-03-2009 à 10:48:53
Marsh Posté le 12-03-2009 à 18:06:52
il te manque
  1. smtp      unix  -       -       -       -       -       smtp
dans le master.cf
Messagerie dédiée, Relais Mail Antispam/Antivirus, Infogérance 24/7: http://www.eole-its.com
Marsh Posté le 19-03-2009 à 10:48:00
Merci, ca a résolu le problème.
Marsh Posté le 19-03-2009 à 12:05:24
Bon, le problème n'est pas pour autant complètement résolu.
J'ai ce message ci:  warning: master.cf.db: duplicate entry: "smtp"
J'ai donc supprimer cette ligne: smtp inet n - n - - smtpd
Le problème, c'est que j'utilise un script écrit en python (très important ce script) qui lorsque je supprime cette seconde ligne ne fonctionne plus.
Ce message de warning n'a pas l'air d'être un gros problème pour l'utilisation de postfix. Quelqu'un peut-il m'expliquer la différence entre ces deux lignes ? Y-a-t-il éventuellement moyen de faire fonctionner le tout en une ligne ?
Marsh Posté le 19-03-2009 à 13:19:42
smtp      unix  -       -       -       -       -       smtp  c'est le client smtp qui va envoyer le mail
smtp inet n - n - - smtpd   c'est le demon smtp qui va recevoir les mails sur le port 25
fais voir ton master.cf a jour
Marsh Posté le 20-03-2009 à 10:33:35
Marsh Posté le 21-03-2009 à 02:35:22
n'ffectue pas de postmap sur le fichier master.cf
efface le fichier master.cf.db (pas le master.cf !) et redemarre postfix
Marsh Posté le 24-03-2009 à 11:41:51
OK, un tout grand merci je n'avais pas vu que le problème venait du fichier master.cf.db et non master.cf. J'avais déjà trouvé bizarre sur un site de voir ce postmap master.cf.
