[!]RTC[!] Remplacer un moteur...
Remplacer un moteur... [!]RTC[!] - Auto / Moto - Discussions
Marsh Posté le 03-07-2003 à 04:03:32
Comme certains le savent je remplace le moteur de ma cadillac, j'ai trouvé un vendeur assez sérieux, mais c'est un peu zarbe, je trouve qu'il manque des pièces au moteur qui me propose (photo) non ?
http://membres.lycos.fr/houseparty18juin/4.1%20cad%20DK%2023.JPG
Il manque pas la couverture du haut ?
Voila le mail du mec:
Mr. Khalifa,
Yes, the engine is a premium engine with many modernizing upgrades over the original.
It comes with a complete gasket set and oil pump, but not water pump or manifolds.
Yes, they are in stock, ready to ship. We will require a cylinder head casting number from you as there were two different engines installed into vehicles with that VIN.
Picture is attached of an engine prior to crating.
Dave Schaffner
ASE cert. Master Mechanic
ASE cert. Master Machinist
Remanufactured.com
14401 South Archer Ave.
Lockport IL 60441
1-815-838-4850
-----Original Message-----
Sent: Wednesday, July 02, 2003 12:20 PM
To: citizen@msn.com
Subject: Re: Cadillac engine
Dear Sir,
I have couple of questions regarding the engine:
1- is it a long block grade ''A'' ? VK 23 or VK 26 ? Please control wich is suitable here is the chassis number: 1G6CD518XH4238156.
2- Engine ready for installation with oil pumps and water pumps built in ? Does it have intake manifolds ?
3- Does it come with a complete gasket kit for assembly ?
4- Is it in stock ready for shipment ?
5- Can you send me pictures of the engine by email ?
thanks.
Waiting for your reply.
Keshlaf Khalifa.
From: Remanufactured.com 1-800-575-6998 [mailto:citizen@msn.com]
Sent: vendredi, 25. avril 2003 13:38
To: khalifa
Subject: RE: Cadillac engine
       Keshalf;
    We do ship overseas and we have found the most simple way to do this is C.O.D. for the freight.
Dear sirs,
I am looking for a remanufactured Cadillac 1987 Deville 4.1L FWD V8, please give me your best export price to Geneva, Switzerland, shipment should be done by airfreight to Geneva's airport.
Best regards.
Keshalf khalifa.
Message édité par khalifa le 03-07-2003 à 04:04:21
Marsh Posté le 03-07-2003 à 06:04:38
ya pas de manifold ni de pompe a eau
mais c quoi qui est briser sur le tien ?
Marsh Posté le 03-07-2003 à 11:09:44
Je me baserai pas sur des photos pour acheter un truc ocmme ça moi... :heink:
Marsh Posté le 03-07-2003 à 16:35:26
Sans blague :sarcastic:
Je sais pas ce qui est casse mais ptet une bielle coulee et reparer ca aut plus chere que remplacer...
Marsh Posté le 03-07-2003 à 17:36:00
si c'est une bielle coulée t'as juste besoin du bloc sans rien autour, puisque le reste est récupérable sur l'ancien.
donc ça devrait passer il me semble?
enfin avec juste une photo c'est difficile de juger de l'état d'un moteur:D
