Souci pilote ATI sur une HD7970 sous W8 Pro - Carte graphique - Hardware
Marsh Posté le 25-05-2013 à 14:40:03
bonjour, j'ai un souci quand j'installe les drivers de ma carte version CCC 13.4 à la fin le journal installation me signale un problème qui est le suivent: <?xml version="1.0"?> <?xml-stylesheet type="text/xsl" href="Report.xml.xsl"?> <monetreport xmlns:dt="urn:schemas-microsoft-com:datatypes"> <general> <cmdline>-UI </cmdline> <time>05/25/13 14:28:41</time> <action>install</action> <download></download> </general> <dcm> <primary> <name>AMD Radeon Graphics Processor</name> <manufacture>Advanced Micro Devices, Inc.</manufacture> <chiptype></chiptype> <chipid>0x6798</chipid> <vendorid>0x1002</vendorid> <ssid>0x3000</ssid> <ssvid>0x1002</ssvid> <classcode>0x030000</classcode> <revisionid>0x00</revisionid> </primary> <device> <name></name> <manufacture>Advanced Micro Devices, Inc.</manufacture> <chiptype></chiptype> <chipid>0xaaa0</chipid> <vendorid>0x1002</vendorid> <ssid>0xaaa0</ssid> <ssvid>0x1002</ssvid> <classcode>0x040300</classcode> <revisionid>0x00</revisionid> </device> </dcm> <exist> <package> <description>AMD Gestionnaire d'installation de Catalyst</description> <result></result> <version>8.0.911.0</version> <size>20 </size> </package> <package> <description>Microsoft Visual C++ 2010 Redistributable 64bit</description> <result></result> <version>10.0.30319</version> <size>9 </size> </package> <package> <description>AMD Accelerated Video Transcoding</description> <result></result> <version>12.10.100.30328</version> <size>3 </size> </package> <package> <description>Catalyst Control Center</description> <result></result> <version>2013.0328.2218.38225</version> <size>150 </size> </package> </exist> <install> <package> <description>AMD Gestionnaire d'installation de Catalyst</description> <result>Succeed</result> <version>8.0.911.0</version> <size>20 </size> </package> <package> <description>Pilote d'affichage AMD</description> <result>Fail</result> <version>12.104.0.0000</version> <size>90 </size> </package> <package> <description>Pilote audio HDMI</description> <result>Fail</result> <version>8.0.0.8811</version> <size>1 </size> </package> </install> <uninstall> </uninstall> <downloaded> </downloaded> <resource> <hwinfo>Informations sur le matériel</hwinfo> <existpkg>Packages existants</existpkg> <pkg2inst>Packages à installer</pkg2inst> <pkg2uninst>Packages à désinstaller</pkg2uninst> <otherdev>Autres périphériques détectés</otherdev> <errmsg>Messages d'erreur</errmsg> <name>Nom</name> <manufacture>Fabricant</manufacture> <chiptype>Type de puce</chiptype> <chipid>ID du périphérique</chipid> <otherhw>Autre matériel</otherhw> <download>Télécharger les packages</download> <succeed>Réussite</succeed> <fail>Échec</fail> <vendorid>ID du fournisseur</vendorid> <classcode>Code de classe</classcode> <revisionid>ID de la révision</revisionid> <ssid>ID du sous-système</ssid> <ssvid>ID du fournisseur du sous-système</ssvid> <header1>Gestionnaire d'installation de Catalyst™</header1> <header2>Rapport d'installation</header2> <finalstatus>État final :</finalstatus> <versionofitem>Version de l'élément :</versionofitem> <size>Taille :</size> <bytes>Mo</bytes> </resource> <error><msg>Installation du pilote : l'installation a échoué</msg></error> <error><msg>Installation du pilote : l'installation a échoué</msg></error> <error><msg>Installation du pilote : l'installation a échoué</msg></error></monetreport> Voila je suis sous "Windows 8 Pro 64" je cherche une solution & pour le reste de ma config voir mon profil.
Marsh Posté le 25-05-2013 à 15:42:26
Fait une restauration de ton systeme...vers l'ancien pilote
Marsh Posté le 25-05-2013 à 16:04:49
Je viens de le faire ça fonctionne pour le moment!
Marsh Posté le 25-05-2013 à 17:44:47
OK redonne moi des nouvelles
bonjour,
<general>
</general>
<dcm>
<primary>
<ssid>0x3000</ssid>
</primary>
<device>
<name></name>
<ssid>0xaaa0</ssid>
</device>
</dcm>
<exist>
<package>
<result></result>
<size>20 </size>
</package>
<package>
<result></result>
<size>9 </size>
</package>
<package>
<result></result>
<size>3 </size>
</package>
<package>
<result></result>
<size>150 </size>
</package>
</exist>
<install>
<package>
<size>20 </size>
</package>
<package>
<size>90 </size>
</package>
<package>
<size>1 </size>
</package>
</install>
<uninstall>
</uninstall>
<downloaded>
</downloaded>
<resource>
<name>Nom</name>
<fail>Échec</fail>
<bytes>Mo</bytes>
</resource>
