[Topic Unique] Thermaltake Chaser A series
Thermaltake Chaser A series [Topic Unique] - Boitier - Hardware
Marsh Posté le 06-11-2013 à 07:57:28
Si vous le souhaiter je me propose pour gérer un topic avec un peu d'aide.
http://www.thermaltake.com/product [...] C_00002125
http://www.thermaltake.com/product [...] C_00001951
http://www.thermaltake.com/product [...] C_00001969
Je trouve que le A71 a du potentiel.
Case Type : Full Tower
Dimension : (H x W x D) 537 x 221 x 565mm (21.1 x 8.7 x 22.2 inch)
Net Weight  : 10 kg/22.1 lb
Side Panel  Transparent Window
Color  Exterior & Interior : Black
Material : SECC
Cooling System :
Front (intake) :
200 x 200 x 30 mm fan (600rpm, 13dBA)
Rear (exhaust) :
120 x 120 x 25 mm Turbo fan (1000rpm,16dBA)
Top (exhaust) :
200 x 200 x 30 mm Blue LED fan (600rpm, 13dBA)
Side (intake):
200 x 200 x 20 mm Blue LED fan (600rpm, 13dBA)
Bottom (intake) : (Optional)
120 x 120 x 25 mm or 140 x 140 x 25 mm
Drive Bays  :
- Accessible : 3 x 5.25’’, 1 x 3.5’’
- Hidden : 5 x 3.5’’ or 2.5’’
- HDD Docking : 1 x 3.5” or 2.5”
Expansion Slots  :8
Motherboards : 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX), 12” x 13” (Extend ATX)
I/O Ports : USB 3.0 x 2, USB 2.0 x 2, HD Audio x 1
PSU  : Standard PS2 PSU (Optional)
LCS Upgradable  : Supports 1/2”、3/8”、1/4” water tube
Radiator  : Top: 1 x 120mm or 2 x 120mm
Rear: 1 x 120mm
Other :
CPU cooler height limitation: 160mm
VGA length limitation: 344 mm
Tests:
www.funkykit.com/reviews/chassis-s [...] sis-review
http://benchmarkreviews.com/2770/t [...] se-review/
http://www.overclockers.com/therma [...] se-review/
http://www.tweaktown.com/reviews/5 [...] index.html
Photos :
http://reho.st/www.overclockers.com/wp-content/uploads/2013/07/tt_chasera71-29.jpg
http://reho.st/www.overclockers.com/wp-content/uploads/2013/07/tt_chasera71-30.jpg
http://reho.st/www.overclockers.com/wp-content/uploads/2013/07/tt_chasera71-33.jpg
http://reho.st/www.overclockers.com/wp-content/uploads/2013/07/tt_chasera71-39.jpg
http://reho.st/www.overclockers.com/wp-content/uploads/2013/07/tt_chasera71-52.jpg
http://reho.st/imagescdn.tweaktown.com/content/5/5/5576_31_thermaltake_chaser_a71_full_tower_chassis_review_full.jpg
http://reho.st/www.overclockers.com/wp-content/uploads/2013/07/tt_chasera71-78.jpg
http://reho.st/www.overclockers.com/wp-content/uploads/2013/07/tt_chasera71-70.jpg
Message édité par dartuil le 08-11-2013 à 05:19:02
Ne pleurez pas ma mort car ma gloire elle est éternelle.
Marsh Posté le 06-11-2013 à 07:57:45
Marsh Posté le 06-11-2013 à 07:57:50
Marsh Posté le 07-11-2013 à 09:13:44
Chassie trop basique, façade jolie... Mais trop tap a l’œil.
Cage hdd dans le mauvais sens, pas super pour les câble
Un seul 120 en façade
120 latéral sans filtre, YES ! ....
La petit vitre latérale ma fais directe pensés sa un Hublot ^^
Et les trou watercooling en 2014 je me demande a quoi sa sert encore ??
Bref je fais que donné mon avis ;)
Bonne journée !
Marsh Posté le 08-11-2013 à 04:38:15
Tu parle des petit modèle parce que le a71 est filtré partout :)
200 en  façade  , 200 en haut , 200 à gauche le tout filtré.
Message édité par dartuil le 08-11-2013 à 04:42:45
Marsh Posté le 09-11-2013 à 17:57:59
Effectivement, j'ai regarder le modèle sur le site moi ;)
B sa doit être silencieux !
