New Hard Drive Setup Issues
New Hard Drive Setup Issues - Disque dur - Hardware
Marsh Posté le 26-07-2010 à 12:22:16
My hard drive crashed and so I got a replacement.
I set the BIOS settings to [AUTO] but I wonder if that was the smartest thing to do.
The size that it displayed seemed to be a little low.  I am wondering if maybe I should have done something other than set the BIOS to automatic determine the settings for the new hard drive.
I suspect I did something wrong because when I have tried to install the Ubuntu Operating System it is stuck on 36 % when formating and/or configuring the hard drive.
How do I go about making the BIOS hard drive settings by hand?
Marsh Posté le 26-07-2010 à 12:58:58
model of your motherboard? model of your hard drive? and french would be much better thank you
Marsh Posté le 26-07-2010 à 20:58:51
Je vais poster en anglais puis en français parce que les Français seront machine qui traduit la.
The Hard Drive is a Western Digital PATA
320 GB
WD3200JBRTL
ULTRA DMA/100
8MB BUFFER 7200 RPM
if I do not get it running today, I think I will try using the old slave drive as the master drive.
The screen says, regarding the motherboard:
Award Medallion BIOS V6.0
COPYRIGHT (C) 1984-2001, Award Software, Inc.
ACPI BIOS Revision 1003. LV
Inter (R) Gleron (TM) 1200 MHz
Memory Test 261120K OK+ 1024 shared memory
and so on...
I think the motherboard cannot handle a 320 gig hard drive.  Unless I can get some magic from you, I am going to take the new hard drive back to the store and swap out the old slave hard drive and make it the new master drive.
Le disque dur est un Western Digital PATA
320 Go
WD3200JBRTL
Ultra DMA 100
8 Mo 7200 tr / min TAMPON
si je n'ai pas le faire fonctionner aujourd'hui, je pense que je vais essayer d'utiliser le lecteur vieil esclave que le disque maître.
L'écran indique, en ce qui concerne la carte mère:
Médaillon BIOS Award V6.0
COPYRIGHT (C) 1984 à 2001 Software Award, Inc
Test de mémoire 261120K OK + 1024 la mémoire partagée
et ainsi de suite ...
Je pense que la carte mère ne peut pas gérer un disque dur de 320 gig. Sauf que je peux obtenir quelque chose de magique de vous, je vais prendre le nouveau disque dur au magasin et de swap sur le disque dur vieil esclave et de le rendre le lecteur nouveau maître.
Marsh Posté le 26-07-2010 à 21:35:27
your drive must be bad clusters therefore have problems surface. Software exists to work ca, but it is best to do as you want and put it in slave starting afresh with a new disc
Marsh Posté le 26-07-2010 à 21:36:29
320 GB
WD3200JBRTL
ULTRA DMA/100
8MB BUFFER 7200 RPM
and so on...
320 Go
WD3200JBRTL
Ultra DMA 100
Bonsoir,
le forum est 100% francophone, meme si certains comprennent l'anglais, alors s'il te plait ecrit nous dans un francais comprehensible par tous.
les seuls choses que j'ai vaguement  compris c'est le intel gleron 1200, il sort d'ou ce proc, il est monté sur quoi, car à l'origine c'est la carte mere qui gere le disque dur, il y a de forte chance, que ca soit limité à 120 go, penser à nous donner la marque et modele de celle ci.
Marsh Posté le 26-07-2010 à 22:32:09
Suite a un crash hdd son disque dur n'est plus reconnu entierement dans le bios et a une tentative d'installation de Ubuntu il bloque a 36%. Donc apparament son hdd a subit un crash et soit il utilise des logiciels de récupérations qui peuvent eventuellement muter les parties endommagés mais le mieux c'est de prendre un autre hdd et de mettre celui la en esclave pour qu'il essaye de faire avec ce qu'il reste a ses risques et péril qu'il crash complet.
Voila en gros la traduction de tout ca ;)
