2 nouvelles tours Antec: LANBOY ( alu ) / Sonata
2 nouvelles tours Antec: LANBOY ( alu ) / Sonata - Matériels & problèmes divers - Hardware
Marsh Posté le 10-02-2003 à 15:54:41
Gaming on the Go
You don't game the night away alone - that's not your style. And when you get together with the gang to battle it out, you want a case that won't weigh you down. That's why this superlight aluminum case is just for you. With easy-tote carrying strap, blue LED-illuminated power supply, and windowed side panel, it's just what you've been looking for. It's definitely the Power of You.
Features:
    * Aluminum mini tower case
    * Windowed side panel
    * SmartBlue 350, 350Watt ATX12V power supply with internal illumination
    * 2 Front mounted USB ports
    * 8 Drive Bays:
      - External: 4 x 5.25", 2x 3.5"
      - Internal: 2 x 3.5"
    * Cooling capacity: up to 2 x 80mm fans
      - 1 rear (optional)
      - 1 front (optional)
    * Motherboards up to Standard ATX
    * Free case-carrying strap
http://www.antec-inc.com/images/400/lanboy.jpg
http://www.antec-inc.com/pdf/drawings/LANBOY_en.pdf
http://www.antec-inc.com/pro_detai [...] dID=15000#
Message édité par DrDS le 10-02-2003 à 16:08:24
Marsh Posté le 10-02-2003 à 15:57:41
Y'a aussi ça:
Just what a PC should be - Seen, not heard.
Relax. Your computer is still running...but with Sonata you get to enjoy the Quiet. The Serenity. The Tranquility. Totally engineered with quietness in mind, the Sonata features low noise cooling, vibration-absorbing drive mounts, and a special TruePower power supply. It won't disrupt your environment, and its sleek, piano black finish will fit your style. That's computing your way. That's the Power of You.
Features:
    * TruePower 380Watt ATX12V power supply with single fan design for enhanced quietness
    * Front mounted USB & IEEE1394 (FireWire) ports
    * Washable Air Filter
    * Front Audio ports
    * 9 Drive Bays:
      - 3 x 5.25" external drive bays
      - 2 x 3.5" external drive bays
      - 4 x 3.5" internal drive bays in individual trays with rubber grommets to absorb hard drive vibrations
    * Cooling: Up to 2 120mm Fans
      - 1 rear (standard)
http://www.antec-inc.com/images/400/Sonata_3.4view_final.jpg
http://www.antec-inc.com/pro_detai [...] dID=15138#
Message édité par DrDS le 10-02-2003 à 15:59:38
Marsh Posté le 10-02-2003 à 16:07:25
[:valentinorossi]
Marsh Posté le 10-02-2003 à 16:48:33
Le bide ne m'atteint pas mais quand meme  :na:
Marsh Posté le 10-02-2003 à 16:49:23
Waouuu!  Quesque c'est.... moche!  :o
Marsh Posté le 10-02-2003 à 16:52:10
Certes oui  :jap: mais le concept de la 2ieme est très interressant ( silence avec une true-power equippé d'un seul ventilo silencieux  :love: ).
Marsh Posté le 14-10-2004 à 01:20:29
Ben moi je trouve le premier moche...
et g un Sonata qui est VRAIMENT très joli en vrai et très silencieux avec pleins de trucs sympas (Alim Antec TruePower380W silencieuse, système de racks, portes à clés, patins caoutchouc, superbe finition, ventilo 120 intégré, ouverture du capots facile, etc....) :love:
le seul problème réel c qu'il est noir, c'est très beau mais ça attire énormément la poussière (du moins ça se voit plus que sur du blanc!) :sweat:
Marsh Posté le 14-10-2004 à 01:36:27
bob-le-Moche (mdr le pseudo)
Ta chercher se topic au fond du trous ?
Sonata, trop petit je préfère le P160 (bcp + de place)
C'est d'ailleur celui ci que j'ai  :love:
Marsh Posté le 14-10-2004 à 01:46:42
lol exact c ma façon à moi de faire revivre les vieux topics oubliés...
non mais c vrai que le Sonata n'est pas une grand tour mais ça suffit largement si on ne fait pas de watercooling ou autres bidouillages pas très utiles à mon gout...
pour info g lecteur dvd et graveur dvd avec en plus le rack de ma carte son en façade, 2 disques dur (et ya encore de la place), un Zalman Cu-7000 sur le proc, CG + 2ports PCi utilisés et tou ce petit monde n'est pas du tout à l'étroit.
De plus, la temp de mon CPU (P4 2.8C) est à 33° et ma Cm (P4C800 dlx) à 29° ...
Marsh Posté le 14-10-2004 à 02:21:22
Ben j'ai vu les 2 (Sonata et P160) ben essai de bidouiller dans le Sonata quand toute la config est monter.
Grosse galère a mon avis :sweat:  (surtout avec mes gros doigts)
Marsh Posté le 14-10-2004 à 08:09:46
Je te l'accorde...  ;)
Marsh Posté le 14-10-2004 à 16:05:57
Mais bon c'est vrai qu'il a un beau look le Sonata, mais quelques défaut.
Le ventilo en aspi sur les HDD.
La place un peu réduite (pour un water plus tard par exemple) :D
Pas de sondes thermique (comme sur mon P160)
