blue screen
blue screen - Matériels & problèmes divers - Hardware
Marsh Posté le 15-03-2015 à 18:37:30
Bonsoir, tout est dit dans le titre... j'ai un souci assez embêtant depuis quelques temps avec des écrans bleus.
ca survient systématiquement quand je lance roguekiller entre autre, le démarrage du pc est plus lent qu'avant et à chaque fois il me fait planté bitdefender que je suis obligé de réinstaller.
J'ai pensé au virus mais après avoir passé malwarebytes et adwcleaner rien de suspect, voici un rapport d'après whocrashed:
On Sun 15/03/2015 16:49:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031515-12324-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12A3B)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8009FF2028, 0xBF800000, 0x200401)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0x1E3)
Conclusion
2 crash dumps have been found and analyzed. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
de ce que je comprends, il y a un souci avec HAL.DLL mais quoi ?
voici ma configuration:
I5 4570@be quiet pure rock
H87-HD3 Gigabyte
8Go G.SKILL ARES 1600
SSD kingston V300 + WD caviar blue
R9 270X MSI
Cooler Master G550M
merci d'avance.
Z9 USB3 full be quiet - CM G550M 550w - H87 HD3 - I5 4570 3,2Ghz@be quiet pure rock - 16Go DDR3 G.Skill Arès 1600 - Gigabyte GTX 1060 6Go - Son creative audigy SE - win10 64 - ssd V300 120Go + 1To caviar blue
Marsh Posté le 17-03-2015 à 14:05:25
Marsh Posté le 17-03-2015 à 14:16:36
