On Wed 08/08/2012 16:09:33 GMT your computer crashed crash dump file: C:\Windows\Minidump\080812-26910-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x87CE9) Bugcheck code: 0x116 (0xFFFFFA800E3364E0, 0xFFFFF8800FD73918, 0xFFFFFFFFC000009A, 0x4) Error: VIDEO_TDR_ERROR file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed. The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Wed 08/08/2012 16:09:33 GMT your computer crashed crash dump file: C:\Windows\memory.dmp This was probably caused by the following module: ntkrnlmp.exe (nt!KeRemoveQueueEx+0x1839) Bugcheck code: 0x116 (0xFFFFFA800E3364E0, 0xFFFFF8800FD73918, 0xFFFFFFFFC000009A, 0x4) Error: VIDEO_TDR_ERROR Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed. The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Wed 08/08/2012 12:02:59 GMT your computer crashed crash dump file: C:\Windows\Minidump\080812-26660-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x87CE9) Bugcheck code: 0x116 (0xFFFFFA800A2804E0, 0xFFFFF8800FD31918, 0xFFFFFFFFC000009A, 0x4) Error: VIDEO_TDR_ERROR file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed. The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Wed 08/08/2012 11:57:37 GMT your computer crashed crash dump file: C:\Windows\Minidump\080812-26005-01.dmp This was probably caused by the following module: unknown_module_fffff880`014724c0.sys (Unloaded_Unknown_Module_fffff880`014724c0+0x3AB1502) Bugcheck code: 0x116 (0xFFFFFA800F2D23C0, 0xFFFFF8800FD86918, 0xFFFFFFFFC000009A, 0x4) Error: VIDEO_TDR_ERROR Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed. A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: unknown_module_fffff880`014724c0.sys . Google query: unknown_module_fffff880`014724c0.sys VIDEO_TDR_ERROR
4 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Si vous avez des idées je suis preneur. Merci d'avance.
Marsh Posté le 08-08-2012 à 18:35:11
Je fais face à plusieurs Bug sur ma bécane,
cela survient uniquement in game,
Je fais du graphisme et du montage vidéo également, et de ce côté rien à déclarer.
Tout est régulièrement mis à jour.
auriez vous une piste?
Intel i7 970
12Go DDR3 Corsair Extrem
SLI Nvidia GTX 560 Ti
Win 7 64Bits Ultimate Ed.
Voici un relevé WhoCrashed:
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
Conclusion
Merci d'avance.
