Bluescreen à répétition - Matériels & problèmes divers - Hardware
MarshPosté le 12-02-2011 à 16:15:49
Bonjour, Je me suis monté un pc il y a une semaine et depuis plusieurs jours j'ai des bluescreens à répétition. J'ai l'impression qu'ils apparaissent parfois quand j'écoute une musique ou que je regarde une vidéo.
J'ai scanné le pc avec whocrashed et j'obtiens ce rapport : On Sat 12/02/2011 13:59:35 GMT your computer crashed crash dump file: C:\Windows\Minidump\021211-21060-01.dmp This was probably caused by the following module: tcpip.sys (tcpip+0x3FB80) Bugcheck code: 0x1000007E (0xFFFFFFFFC000001D, 0xFFFFFA800489D083, 0xFFFFF88003170698, 0xFFFFF8800316FF00) Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M file path: C:\Windows\system32\drivers\tcpip.sys product: Système d’exploitation Microsoft® Windows® company: Microsoft Corporation description: Pilote TCP/IP Bug check description: This indicates that a system thread generated an exception which the error handler did not catch. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Sat 12/02/2011 13:59:35 GMT your computer crashed crash dump file: C:\Windows\memory.dmp This was probably caused by the following module: tcpip.sys (tcpip+0x3FB80) Bugcheck code: 0x7E (0xFFFFFFFFC000001D, 0xFFFFFA800489D083, 0xFFFFF88003170698, 0xFFFFF8800316FF00) Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED file path: C:\Windows\system32\drivers\tcpip.sys product: Système d’exploitation Microsoft® Windows® company: Microsoft Corporation description: Pilote TCP/IP Bug check description: This bug check indicates that a system thread generated an exception that the error handler did not catch. The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Sat 12/02/2011 13:56:21 GMT your computer crashed crash dump file: C:\Windows\Minidump\021211-21340-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x70740) Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80002C907B3, 0xFFFFF880026AAD10, 0x0) Error: SYSTEM_SERVICE_EXCEPTION file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Sat 12/02/2011 12:50:09 GMT your computer crashed crash dump file: C:\Windows\Minidump\021211-19032-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x70740) Bugcheck code: 0x109 (0xA3A039D899A5F677, 0xB3B7465EEC22C86D, 0xFFFFF80002CC12B0, 0x1) Error: CRITICAL_STRUCTURE_CORRUPTION file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that the kernel has detected critical kernel code or data corruption. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules. The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
Etc etc... avec toujours ntoskrnl.exe en cause.
Quelqu'un a un conseil ou une idée d'où ça pourrait venir? RAM? Composant défectueux? Driver merdique?
Merci d'avance.
Message édité par Milohardware le 12-02-2011 à 16:31:35
Marsh Posté le 12-02-2011 à 16:15:49
Merci d'avance.
