BSOD - MEMORY_MANAGEMENT - ntoskrnl.exe
BSOD - MEMORY_MANAGEMENT - ntoskrnl.exe - Matériels & problèmes divers - Hardware
Marsh Posté le 01-04-2010 à 17:14:44
Je rencontre depuis l'assemblage de mon nouveau matériel des BSOD fréquents faisant référence à ntoskrnl.exe ainsi que watchdog.sys
Ma configuration est la suivante :
Carte mère ASUS P7P55D LE
Processeur Intel i5 750 Lynnfield 2.66GHz
Carte graphique ATI Radeon HD5850 1Go DDR5
Alimentation Advance 650W
Mémoire vive OCZ 2x2Go 1600MHz (OCZ3G1600VL4GK)
Disque dur Hitachi 500Go SATA II 7500t/min
Boitier Antec Three Hundred (2x140mm ventilateurs + 3x120mm ventilateurs)
Windows Seven Professionnel 64 bits officiel licence MSDN
Voici le résultat de Whocrashed :
Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Thu 01/04/2010 01:12:45 your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x1A (0x3452, 0x7FEFE62C000, 0xFFFFF70001081CF8, 0x0)
Error: MEMORY_MANAGEMENT
Dump file: C:\Windows\Minidump\040110-22167-01.dmp
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
On Wed 31/03/2010 19:52:54 your computer crashed
Bugcheck code: 0xA (0xFFFFF68000132F08, 0x0, 0x0, 0xFFFFF80002A90AE2)
Error: IRQL_NOT_LESS_OR_EQUAL
Dump file: C:\Windows\Minidump\033110-29952-01.dmp
On Wed 31/03/2010 18:36:57 your computer crashed
Bugcheck code: 0x18 (0x0, 0xFFFFFA80044117F0, 0x2, 0xFFFFFA80054437BF)
Error: REFERENCE_BY_POINTER
Dump file: C:\Windows\Minidump\033110-21106-01.dmp
On Wed 31/03/2010 16:58:22 your computer crashed
This was likely caused by the following module: watchdog.sys
Bugcheck code: 0x10E (0x23, 0x1, 0x20000000, 0x0)
Error: VIDEO_MEMORY_MANAGEMENT_INTERNAL
Dump file: C:\Windows\Minidump\033110-16364-01.dmp
file path: C:\Windows\system32\drivers\watchdog.sys
description: Watchdog Driver
On Wed 31/03/2010 03:46:04 your computer crashed
Bugcheck code: 0xFC (0xFFFFF8800889D490, 0x80000000671E3963, 0xFFFFF8800889CF10, 0x2)
Error: ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY
Dump file: C:\Windows\Minidump\033110-17612-01.dmp
Conclusion
5 crash dumps have been found and analyzed. Note that it's not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Pouvez-vous m'aider à éclaircir cette analyse ??? Je lance un memtest dès ce soir et je vous dirais le résultat...
Merci.
En attente d'une réponse de votre part.
Cordialement,
Baptiste.
Marsh Posté le 01-04-2010 à 17:20:09
Hello, c est quoi c talim pourave.... :o
ta pas honte depuis le temps qu on dit qu il est interdit de venir sur Hfr avec des alims Advance  :whistle:  :lol:  :lol:
non serieux ton alim faut vite la changer avant de rendre ton matos aux eterniter informatique.... [:aras qui rit]
ex d alim de bonne qualitay
http://www.ldlc.com/fiche/PB00091486.html
Message édité par chriskenoby le 01-04-2010 à 17:22:33
Les créateurs de l'Electro, c'est eux KRAFTWERK http://www.kraftwerk.com/concerts/ [...] _robo.html - Mes Cartes https://drive.google.com/drive/fold [...] 0-vZPkdfoi
Marsh Posté le 01-04-2010 à 17:20:14
Aie, alimentation de mauvaise qualité, il faudrait tester ta ram et ton processeur ;)
Les Cartes Son Haute Fidélité pour mélomanes, musiciens, audiophiles, la MAO, le cinéma,...
Marsh Posté le 01-04-2010 à 17:28:51
Lollllllllllllllllllllllll....
Pour tout vous dire j'avais une alimentation sur mon ancien PC de 600w que je comptais garder pour ma nouvelle config.
Il s'est avérer que lors du montage, l'alim étant placée en bas dans le boitier Antec mon ancienne alim avait le bras principal pour la carte mère trop court !!!!
J'ai donc récupérer l'alim plus récente que j'avais monté dans le pc de mon coloc et il s'avere que c'est une Advance !!!
Bref ce soir je lance le memtest, si mes deux barrettes de RAM sont bonnes alors je m'en irais illico m'acheter une alim CORSAIR (ce que je comptais faire au début mais qui augmentait le prix d'environ 70€ a 100€ suivant les points de ventes).
Voilà si vous avez des commentaires à faire ou d'autres solutions à me proposer je suis tout ouïe et merci de votre rapidité à répondre.
Marsh Posté le 01-04-2010 à 17:31:36
Corsair cx 400w @ moins de 45 € et ce sera parfait !
Test ta ram avec memtest, ce sera déjà une bonne base ;)
