BSOD
BSOD - Matériels & problèmes divers - Hardware
Marsh Posté le 23-08-2014 à 14:28:20
bonjour,
Pour finir mon été en beauté, j'ai eu le droit un Blue screen.. à deux reprise dans la semaine.
Voici le rapport Whocrashed :
On Sat 23/08/2014 01:30:26 GMT your computer crashed
crash dump file: C:\Windows\memory.dmp
uptime: 15:06:25
This was probably caused by the following module: Unknown (0x00000000)
Bugcheck code: 0x7E (0xFFFFFFFFC0000005, 0xFFFFF8800F5AEDBB, 0xFFFFF8800406A228, 0xFFFFF88004069A80)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug check description: This bug check indicates that a system thread generated an exception that the error handler did not catch.
A third party driver was identified as the probable root cause of this system error.
j'y ai pas trouver de solution,mes drivers sont à jours , mais le BIOS j'en ai aucune idée.
On Sun 24/08/2014 15:47:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082414-8470-01.dmp
uptime: 05:24:56
This was probably caused by the following module: atikmdag.sys (atikmdag+0xC7DBB)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8800F57CDBB, 0xFFFFF880040AA228, 0xFFFFF880040A9A80)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\drivers\atikmdag.sys
product: ATI Radeon Family
company: Advanced Micro Devices, Inc.
description: ATI Radeon Kernel Mode Driver
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmdag.sys (ATI Radeon Kernel Mode Driver, Advanced Micro Devices, Inc.).
Google query: Advanced Micro Devices, Inc. SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
uptime: 05:24:56
Bugcheck code: 0x7E (0xFFFFFFFFC0000005, 0xFFFFF8800F57CDBB, 0xFFFFF880040AA228, 0xFFFFF880040A9A80)
Google query: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Encore des bsod récurents
Merci d'avance, je ne trouve pas de solution
Message édité par noxno le 24-08-2014 à 17:59:16
