Ecran bleu après installation SSD - Matériels & problèmes divers - Hardware
Marsh Posté le 21-06-2021 à 17:07:39
Installe Whocrashed pour avoir des détails concernant l'écran bleu.
Ton autre SSD est en SATA ou nvme ?
As-tu des périphériques non reconnus (point d'exclamation jaune) dans le gestionnaire de périphériques ?
Marsh Posté le 22-06-2021 à 17:08:27
merci pour ta réponse.
Voilà le diagnostic whocrashed:
Crash dump directories:
C:\WINDOWS
C:\WINDOWS\Minidump
"On Sun 20/06/2021 19:28:23 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\LiveKernelReports\PoW32kWatchdog-20210620-1928.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!IoUnregisterShutdownNotification+0xF84)
Bugcheck code: 0x1A1 (0xFFFFD08FB42E9040, 0x0, 0x0, 0x0)
Error: CUSTOM_ERROR
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sun 20/06/2021 19:26:07 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\062021-18562-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F6C20)
Bugcheck code: 0x139 (0x2, 0xFFFFF18543625FA0, 0xFFFFF18543625EF8, 0x0)
Error: KERNEL_SECURITY_CHECK_FAILURE
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: The kernel has detected the corruption of a critical data structure.
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: vhdmp.sys (vhdmp+0x10325)
file path: C:\WINDOWS\system32\drivers\vhdmp.sys
description: VHD Miniport Driver
The crash took place in a Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time. "
Mon autre SSD est en sata.
Oui j'ai un periphérique avec un point d'exclamation jaune dans périphérique d'interace utilisateur "HID-compliant headset" avec marqué: "Ce périphérique ne peut pas démarrer. (Code 10)".
Marsh Posté le 22-06-2021 à 17:31:47
Ok, merci.
On va commencer par la traditionnelle commande sfc /scannow que tu vas lancer dans une fenêtre de commandes MS-Dos en mode administrateur (clic droit puis exécuter en tant que ....), et tu nous dis ce qu'il en est.
Concernant "hid compliant hedset", tu n'as aucun problème avec ton micro-casque ?
Si tu n'as aucune erreur, supprime simplement le périphérique et redémarre, dis nous ensuite s'il revient dans la liste et son état.
Sinon les questions classiques :
De quand date l'installation de windows ?
Quelle version de W10 as-tu précisemment (touche Windows + R et tu écris winver puis ENTREE) ?
As-tu installé les pilotes propriétaire de tes composants ou as-tu laissé windows s'occuper des pilotes ?
Edit : par contre tu n'es pas dans la bonne catégorie, edite le premier post de ton topic et change de sous-catégorie, mets "matériel & problème divers", ce sera déjà plus adapté que "disque".
Marsh Posté le 22-06-2021 à 17:41:34
Voilà le resultat de la commande :
"Début de l’analyse du système. Cette opération peut nécessiter un certain temps.
Démarrage de la phase de vérification de l’analyse du système.
La vérification est à 100% terminée.
La Protection des ressources Windows a détecté des fichiers corrompus et les a réparés.
Pour les réparations en ligne, les détails sont inclus dans le fichier journal de CBS situé à l'emplacement suivant :
windir\Logs\CBS\CBS.log. Exemple : C:\Windows\Logs\CBS\CBS.log. Pour les réparations
hors connexion, les détails sont inclus dans le fichier journal fourni par l'indicateur /OFFLOGFILE."
J'ai fait ce que tu m'as dit pour le périphérique et effectivement le problème n'est plus reconnu en erreur ;D.
Marsh Posté le 22-06-2021 à 17:48:38
| xbrolee a écrit : J'ai fait ce que tu m'as dit pour le périphérique et effectivement le problème n'est plus reconnu en erreur ;D. |
"hid compliant headset" est bien présent mais plus de point d'exclamation c'est ça ?
Du coup pour l'écran bleu tu nous diras ce qu'il en est si ça revient ou pas.
Marsh Posté le 22-06-2021 à 17:55:07
C'est ça, plus de point d'exclamation.
J'ai la version window 20H2. Window je l'ai installé quand j'ai eu mon pc c'est à dire en 2017.
J'ai laissé window s'occupé des pilotes .
Merci pour ta réactivité , je te tiendrai au courant si ça a résolu le problème.
Merci beaucoup
Marsh Posté le 24-06-2021 à 19:14:23
Pour le moment , le problème ne s'est pas reproduit, je ne cri pas victoire trop vite car c'était très aléatoire comme problème.
Marsh Posté le 24-06-2021 à 19:52:08
Yep tiens nous au courant.
Marsh Posté le 04-07-2021 à 19:30:50
Hello la comu !
J'ai eu de nouveau le problème sauf que la ça ne pas mis d'écran bleu mais l'ordinatreur à redémarré directement.
J'ai fait le test Whocrashed ça me dit ça :
"Crash dump directories:
C:\WINDOWS
C:\WINDOWS\Minidump
On Sun 04/07/2021 19:26:35 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\070421-17140-01.dmp
Bugcheck code: 0x139 (0x2, 0xFFFFAF0E62C7DFA0, 0xFFFFAF0E62C7DEF8, 0x0)
Marsh Posté le 04-07-2021 à 23:08:20
Salutation,
sur quel slot m2 ton SSD nvme a été installé? face carte mère, sur le 1 au dessus de la carte graphique ou le 2 en bas à droite?
il faudrait installer le logiciel crystaldiskinfo et mettre une copie d’écran des informations concernant ton ssd nvme.
Marsh Posté le 06-07-2021 à 08:20:13
Non je n'ai pas faitr de maj du BIOS, du moins pas à ma connaissance.
Je l'ai installé sur le 2 en bas à droite.
(01) PNY CS3030 500GB SSD
Model : PNY CS3030 500GB SSD
Firmware : CS303226
Serial Number : PNY512000354901031DD
Disk Size : 500,1 GB
Buffer Size : Inconnu
# of Sectors :
Rotation Rate : ---- (SSD)
Interface : NVM Express
Major Version : NVM Express 1.3
Minor Version :
Transfer Mode : PCIe 3.0 x4 | PCIe 3.0 x4
Power On Hours : 708 heures
Power On Count : 116 fois
Host Reads : 1282 GB
Host Writes : 475 GB
Temperature : 26 C (78 F)
Health Status : Bon (100 %)
Features : S.M.A.R.T., TRIM, VolatileWriteCache
APM Level : ----
AAM Level : ----
Drive Letter : B:
Marsh Posté le 06-07-2021 à 13:01:17
Je viens de faire la MAJ du BIOS, j'ai due déconnecté un disque dur HDD car il était trop absolete, trop d'erreur et en fin de course.
Marsh Posté le 06-07-2021 à 21:13:36
Différentes MAj du Bios apportent des correctifs divers et variés notamment pour des problèmes sur 3 marque de SS M2 samsung plextor et sandisk.
Sinon je ne sais pas où tu as récolté les infos demandés mais j'ai beaucoup plus confiance en crystaldiskinfo
car d'après les info que tu as transmis, il semble fonctionne vraisemblablement en mode pcie X4, mais les second port M2 (ici en bas à droite) de certaines carte mères sont paramétrés par "défaut" en mode X2 ou (auto = pcie x2) pour laisser une paire de port sata actif.
il serait judicieux de contrôler dans le bios le paramétrage réél de ce port M2_2 ( menu onboard device configuration ou configuration des périphériques embarqués)
Marsh Posté le 07-07-2021 à 16:55:35
Merci pour la réponse.
J'ai bien utilisé crystaldiskinfo pour avoir ses infos.
En effet, en allant dans mon BIOS, le M2.2 était en x2 , j'ai eu le choix de le mettre en X4, chose que j'ai faite du coup.
Marsh Posté le 07-07-2021 à 23:23:03
Ok, louche cette histoire mais tu as bien fait de le basculer en x4, éventuellement contrôler un test de débit avec crystaldiskmark,
on aurait pu le faire avant la bascule histoire de comparer mais c'est pas grave.
ensuite de contrôler si tu as toujours des écrans bleu de nouveau.
Marsh Posté le 15-07-2021 à 19:25:58
Du coup j'ai déconnecté mon disque dur qui était flingué , et j'ai mis en x4 , après 9 jours, toujours pas d'écran bleu
je vous tien au courant . Merci encore du temps que vous m'accordez.
Marsh Posté le 29-07-2021 à 21:19:01
je pense que le problème est réglé. Merci bcp aux personnes qui m'ont aidé.
Marsh Posté le 21-06-2021 à 16:50:47
Bonjour la communauté ,
je viens vers vous alors que je n'écrit jamais sur les forum mais là malgré toute mes recherche je ne trouve pas de solution à mon problème.
Mon soucis concerne un nouveau SSD PNY 500 Go (https://www.pny.eu/fr/consumer/explore-all-products/solid-state-drives/1084-xlr8-cs3030-m-2-nvme-solid-state-drive---500gb)
Ma carte mère est une: ASUS PRIME Z270 A series.
CG= RTX 2060 super.
J'ai DEUX SSD, DEUX HDD.
Voilà j'ai installé mon SSD au pc avec un dissipateur de chaleur classique. Mon PC tourne nickel avec, je peux installé des jeux dessus et il est fonctionnel.
Cependant , de manière aléatoire, j'ai un écran bleu qui apparait avec comme message : kernel security check failure. Il survient de temps en temps après plusieures heures et pas forcément tout les jours.
Et aussi, pensez-vous qu'avoir 4 disques dur est de trop pour ma config ?
Je tien à préciser que je suis un amateur donc détaillez le plus possible s'il vous plait
Merci à tous d'avoir pris le temps.
Message édité par xbrolee le 22-06-2021 à 17:52:23
