écran bleu
écran bleu - Matériels & problèmes divers - Hardware
Marsh Posté le 27-04-2014 à 20:46:44
Bonjour, j'aimerais trouver d’où vient mon écran bleu.
On Sat 26/04/2014 21:51:46 GMT your computer crashed
crash dump file: C:\Windows\Minidump\042614-15178-01.dmp
This was probably caused by the following module: win32k.sys (win32k+0x22C9ED)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF960002FC9ED, 0xFFFFF8800B2F9110, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
file path: C:\Windows\system32\win32k.sys
product: Système d’exploitation Microsoft® Windows®
company: Microsoft Corporation
description: Pilote Win32 multi-utilisateurs
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
Merci.
