installation modem creatix
installation modem creatix - Matériels & problèmes divers - Hardware
Marsh Posté le 16-09-2004 à 15:38:01
salut à tous,
j'ai un pote qui est passé sous winXP et qui ne parvient pas à installer son modem interne creatix ham v90. je lui ai filé les pilotes officiels dispo sur le site, mais impossible de l'installer. quand on lui propose "disquette fournie" dans l'assistant d'ajout de nouveaux materiels, il donne le *.inf, mais rien. nada. aucun materiel n'apparait. voici la demarche évidente précisée dans la doc, mais je sais plus trop quoi lui dire.
1. Extract the driver into a temporary directory.
2. De-install the old driver (see also de-installation of the driver after this paragraph) or delete, after a new installation of the operating system, the entry for the modem (“PCI Communication Device”) at the device manager (start – settings – control panel – system – hardware – device manager [classic view] respectively start – control panel – performance and service – system – hardware – device manager[category view]) under “Other components”.
3. Reboot your PC.
4. The assistant for searching new hardware: “PCI-Communication device (simple)” will be started.
5. Choose “Install the software from a list or a special source (for advanced users)” and continue with “Next”.
6. Search this source for the correct driver. Activate “search also the following source” and specify the directory, where you have extracted the driver or search the position with the option “search”. Important is, that you have given the complete path. Confirm this window with “Next”.
7. The PC is searching the given sources and find “Creatix V9X HAM Data Fax Modem”. The software will be installed.
8. Completion of  the assistant. The software for the following hardware has been installed: Creatix V9X HAM Data Fax Modem. “Finish”.
9. The modem should be available at the control panel (printer and hardware) under telephone- and modem-options.
d'avance merci !
Marsh Posté le 19-09-2004 à 01:21:41
fait une instal manuelle du genre :ne pas detecter mon modem,me laisser choisir,de la tu cherche le pilote te tu l'instal
Marsh Posté le 20-09-2004 à 23:57:02
ouis c'est bien ce qu'on avait tenté. mais finallement, on a réinstallé win2000 (car son pc était à un stade où il pouvait plus rien faire, plus formater) pour réinstaller win98 en formatant. et là, les drivers marchent. allez savoir pourquoi...
Marsh Posté le 21-09-2004 à 08:19:43
Si ce sont les drivers pour 98 qu'il essaye d'installer, pas la peine de chercher plus loin..
Marsh Posté le 21-09-2004 à 16:30:34
non. on avait les drivers correspondant à chaque version de windows. on est pas con à ce point tout de même  [:bbcmoi]
