Muvo non plus reconnu
Muvo non plus reconnu - Matériels & problèmes divers - Hardware
Marsh Posté le 25-05-2004 à 10:41:25
Voilà j'ai ce gros soucis  :(
J'ai enlevé le microdrive d'origine 4go
pour mettre un microdrive IBM 1Go
en faisant ce manipulation
http://www.pcconsultant.com/microdrive.htm    :D
mais malhereseument je savais pas que après il fallait faire ca
http://andymack.com/mylog/pivot/en [...] andard-881
car moi j'ai mis le firmwire 1.11  :(
donc now j'ai sur toutes les positions Media Error
meme sur la position 5 cat à dire connect USB je n'arrive pas car j'ai Media Error
donc comment je pourrais faire?
j'ai lu ca:
FYI The 4Gb Muvo2 US firmware queries a hidden 3K file on the 4GB drive to verify that it is installed before it will go into normal operating mode. If the file cannot be found the 4GB Muvo2 reverts to recovery mode. Creative added this check at the last minute to prevent people from pulling the Hitachi microdrive and replacing it with standard CF flash memory. Be sure to make a backup of your 4Gb drive BEFORE you format the Hitach 4GB Microdrive in another CF device. Otherwise, you will render your Muvo2 useless even if you reinstall the original Hitachi 4Gb microdrive. You can use Ghost to make the backup image and even restore the created image to a standard CF flash memory using a CF reader/Writer attached to your PC. Once you have restored the image to a standard CF card it can then be inserted into your orgial 4GB Muvo2 and it will work without problems.
iglooblue , tThe Muvo2 1.5GB and 4Gb model firmware are not the same and that is why it was stating the 1.5Gb Muvos was not installed. According to Creative engineering for reason stated above they are keeping a tight lip on the 4Gb firmware and will not post it to their website. However, I have heard it is available through their Asian support site? If you have a firmware issue with your 4Gb Muvo2 the ONLY option Creative tech support is offering for now is to return it to Creative for repair. >>
donc si j'ai bien compris je pourrais grace un image faire la manipulation? qqun pourrais expliquer mieux?
PS j'en approfitte pour demander à qqun l'image de ce foutu microdrive  :jap:
car il se voit aussi que meme si je remets le microdive d'origine là aussi mon muvo me dit tj Media Error et tj sans possibilité de connexion sur le port USB  :(
Merci encore
Marsh Posté le 25-05-2004 à 10:50:25
Tu as du tomber sur une version mise a jour du MuVo². Cette version la possede un petit fichier sur le Microdrive qui protege le MuVo de l'extraction de la carte.
Si on extrait ce fichier avec le Md sans l'avoir fait un ghost(sauvegarde du disque) et remis ce dernier sur le disque de remplacement, ton MuVo² ne risque plus de marcher.
tu devrais voir sur Google si tu ne trouves pas un topic qui traite ce sujet plus profondement, je crois meme que dans la section photo ilya eu un autre topic qui traitait ce sujet la.
Message édité par theBride le 25-05-2004 à 10:51:31
Marsh Posté le 25-05-2004 à 11:15:32
oui j'ai lu le topic  :D
mais justement
si qqun pourrais faire cet image de sauvegarde et me l'envoyer ca va repartir non?
Marsh Posté le 25-05-2004 à 12:40:42
Marsh Posté le 25-05-2004 à 15:41:27
Marsh Posté le 25-05-2004 à 20:26:24
Message édité par Corvo le 25-05-2004 à 20:26:34
Marsh Posté le 26-05-2004 à 16:34:50
Marsh Posté le 27-05-2004 à 08:52:19
Marsh Posté le 27-05-2004 à 21:57:06
Marsh Posté le 02-06-2004 à 11:48:37
