Peut-on m'aider a Flasher le bios d'une KR7A Raid ?
Peut-on m'aider a Flasher le bios d'une KR7A Raid ? - Matériels & problèmes divers - Hardware
Marsh Posté le 06-12-2004 à 19:03:08
Salutation,
Voila j'explique mon probleme...
BIOS Date: 12/27/01
BIOS Type: Award Modular BIOS v6.00PG
BIOS ID:   12/27/2001-VT8366A-8233-6A6LVA1AC
OEM Sign-On: GREEN AGP/PCI SYSTEM
Chipset:   VIA 82C3099 rev 0
Superio:   Winbond 697HF rev 6 found at port 2Eh
OS:        WinXP SP1
CPU:       Unknown CPU Type 1000 Mhz MAX: 1500 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size:      256K
Memory Installed:   512 MB
Memory Maximum:     1024 MB
Memory Slot 01:     0 MB
Memory Slot 02:     256 MB
Memory Slot 03:     256 MB
Memory Slot 04:     0 MB
Voila les infos que j'ai réussi a extraire de mon BIOS ... maintenant je vais sur le site de Abit (constructeur de ma CM) et je trouve :
kr7a6n.exe    Bios Issue Date:2001/12/27
BIOS ID: 6N
This is first release for KR7A-133 / KR7A-133RAID. The BIOS is for all KR7A / KR7A-RAID / KR7A-133 / KR7A-133RAID.
Support AMD Athlon XP 2000+ CPU, and fix AMD Duron 1.2/1.3G CPU bootup failed issue.
Fix ATA-66 HDDs under Windows XP compatible issue.
Fix unable to enter S1 mode under Windows 2000 system and unable to be wakened up by PCI LAN card from S4 mode under Windows 98SE.
HPT 37x BIOS version 2.0.1024.The RAID function is for KR7A-RAID only. This BIOS version is also for non RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
Ceci est la version du Bios que je possède déja, maintenant je voudrai savoir si ce Bios ci est compatible avec mon épave qui me sert de CM :
kr7acx.exe    Bios Issue Date:2002/11/18
BIOS ID: CX
Fixes the compatibility issue where the ATI Radeon 9700 Pro fails to boot up with a certain power supply unit - TC-350P. With this power supply, the 9700 Pro will fail to boot up, requiring a reset button push to show the boot screen.
HPT 372 BIOS Version 2.32. The RAID function is only for KR7A-RAID / KR7A-133R. The BIOS is suitable for non-RAID boards and it will automatically disable HPT BIOS when non-RAID boards are recognized.
BIOS Compile Date: 11/18/2002
Les 2 Bios sont dans la section KR7A Raid mais j'ai peur de me planter avec les version des bios parce que dans ce cas c'est la fin de ma Carte Mère...je cherche a le flasher car j'ai des problemes avec ma CM qui undercloke mon Procésseur 1533 Mhz (Atlon 1800+) en un Unknow Processor 1000 Mhz
merci de m'aider (un peu au moins ;) )
(Désolé pour la LLLLOOOONNNNGGGGUUUUEEEEUUUURRRR du message !)
Message édité par Megazord le 06-12-2004 à 19:39:09
Marsh Posté le 07-12-2004 à 10:10:21
Personne ne sais ? (c'est pour remonter le sujet parce que il est parti loin loin loin)
Marsh Posté le 07-12-2004 à 11:45:15
tu as bien reglé ton fsb ou sur ta carte mere ou ds le bios?
1800= 11.5 x 266 mhz
Marsh Posté le 07-12-2004 à 12:25:41
Désolé j'ai oublié de tout préciser : en fait dépassé le 1000Mhz (à partir de 1050) le PC ne boot plus il commence le boot et s'arrête et je ne peux plus rien faire, a partir de 1400 Mhz le Boot ne va même pas jusqu'au compte de la RAM ! Et là n'ayant plus accès au menu du bios (en dessous de 1400 je peux donc je peux le remettre a 1000Mhz pour démarrer) je suis obligé de retirer la pile mémoire Bios et la remettre pour qu'il refasse de nouveau un boot normal avec écrit Unknow Processor 1000 Mhz.
Message édité par Megazord le 07-12-2004 à 12:40:56
Marsh Posté le 07-12-2004 à 13:20:33
je repete, tu as bien reglé ton fsb ou sur ta carte mere ou ds le bios?
1800= 11.5 x 266 mhz (113 mhz ds le bios)
comment tu regle le fsb tu as pas de jumper sur ta carte mére?
Message édité par copsc le 07-12-2004 à 15:22:37
Marsh Posté le 07-12-2004 à 13:37:53
1800 = 11.5 x 266 Mhz ??
c'est un peu trop pour mon proc ! surtot que 11.5 x 266 ca fait plus de 3000 Mhz...
deplus c'est un 1800+ donc il est cadencé a 1533 Mhz maxi
1533 = 11.5 x 133
Je vais voir si je peux faire une modification de tout ca je te fait part de ce qui c'est passé, en tout cas ça serai bon que ca marche parce que cela m'arrangerai de ne pas avoir besoin de flasher mon bios...
Marsh Posté le 07-12-2004 à 13:39:26
t'aurais pas un ti jumper sur la carte qui passe le FSB de 100 à 133 (200 - 266) ?
Marsh Posté le 07-12-2004 à 13:47:50
Alors voila :
j'ai mis mon FSB a 133 et j'ai mis le multiplicateur a 11.5 donc j'ai 1533Mhz...et la le PC ne s'allume même plus ! j'ai encore une fois dû retiré la pile mémoire bios pour pouvoir le démarrer...
"t'aurais pas un ti jumper sur la carte qui passe le FSB de 100 à 133 (200 - 266) ?"
Qu'est-ce donc ?(Désolé pour la bouletitude de cette question lol)
Marsh Posté le 07-12-2004 à 13:54:57
Certaine carte mère était obligée de passer par un jumper pour le choix fsb 100 ou 133.
Mais il semble que cela ne soit pas le cas pour la tienne.
Pour info à partir de la version B5 :
Support AMD Athlon XP CPU, 0.18 micron process Palomino up to 2100+ and 0.13 micron process Thoroughbred up to 2000+.
Si ton 1800+ est récent c'est surement un 0,13...
http://www.abit-usa.com/products/m [...] 1&model=87
Message édité par nicolo le 07-12-2004 à 13:57:11
Marsh Posté le 07-12-2004 à 14:05:01
Wé ok pour ma carte mère elle passe sans rien utiliser de 100 a 250 au niveau du FSB et elle a un multiplicateur de 5 a 12.5
Pour ce qui est de ce que l'on trouve sur le site Abit j'ai déja un peu regardé, dans la section KR7A-Raid on a la liste des bios (c'est dailleur le lien que tu donne)
 Donc moi j'aimerai savoir si l'un de ces Bios est compatible avec ma carte mère (car desfois le type de carte mère (KR7A) ne suffit pas a prouver la compatibilité entre le nouveau bios et la version de la CM...
 Tu donne une info sur les derniers Bios (a partir du B5) a quoi elle correspond ? pour moi ça annonce une compatibilité avec les proco jusqu'au 2100+ en 0.18 micron et 2000+ en 0.13 mais je ne suis pas sûr... mon proc etant un 1800+ y a t-il une importance a cet info ?
Marsh Posté le 07-12-2004 à 14:10:03
Je pense en effet que cela ai de l'importance...
Pour ce qui est de la compatibilité de ta carte avec ce bios je ne vois pas pourquoi tu doute ???
KR7A-RAID BIOS CX  ===> Si ta carte est bien celle ci, doit pas y avoir de problèmes.
   Version: CX  Released Date: 2002-11-18
Marsh Posté le 07-12-2004 à 14:14:20
aurais tu peur de flasher ton bios ??? aujourd'hui pas de risques
Marsh Posté le 07-12-2004 à 14:17:57
Ok bah je pense que je vais mi mettre alors...en espérant que ca résolve le probleme....
KR7A-RAID BIOS 6N  c'est ca qu'il y a pour l'instant dans la mienne, le CX c'est le dernier Bios mis en ligne par Abit pour la KR7A - Raid
Ca devrais pas poser de problemes ???
Marsh Posté le 07-12-2004 à 14:32:40
Je ne pense pas, dans le cas contraire, fait une sauvegarde de l'actuel si tu peux et créer deux disquettes.
Une avec le nouveau bios
Une avec l'ancien
Et eventuellement une avec une autre version pendant que tu y est.
Mais je ne pense pas que tu en ai vraiment besoin.
Message édité par nicolo le 07-12-2004 à 14:33:27
Marsh Posté le 07-12-2004 à 14:34:27
"aurais tu peur de flasher ton bios ??? aujourd'hui pas de risques"
Bah wé ! a l'époque le flashage de Bios c'était pas sans risque ! si tu massure qu'il y a pas de risque je vais me lancer !
Marsh Posté le 07-12-2004 à 14:37:11
"Mais je ne pense pas que tu en ai vraiment besoin."
J'aimerai aussi ne pas en avoir besoin car j'ai peur de tout casser ! mais avec ce probleme de processeur underclocké je suis à bout alors j'essaye tout ce qui pourrai faire Booter mon PC a 1533 et plus a 1000Mhz parce que même si un 1800+ c'est dépassé...un proco a 1Ghz c'est bon pour la poubelle !
Message édité par Megazord le 07-12-2004 à 14:37:49
Marsh Posté le 07-12-2004 à 14:37:17
nicolo a écrit[/nom]aurais tu peur de flasher ton bios ??? aujourd'hui pas de risques
bas oui pour toi tu as 1 gigabyte dualbios :pt1cable:
+ @bios,est pas bessoin de disquettes
Message édité par copsc le 07-12-2004 à 14:38:34
Marsh Posté le 07-12-2004 à 14:55:20
mais j'ai déjà flashé au moins une bonne vingtaine de carte mère différentes et certaines assez anciennes (98) et jamais eu un problème, je l'ai même fait une sur autre gigabyte qui n'avait plus de clavier donc en mode tout automatique par script et encore sans problème.
Marsh Posté le 07-12-2004 à 15:15:49
Flashage réalisé et Procésseur reconnu par la CM....c'est pas trop tot !
maintenant mon PC reboote toutes les 5 minutes (je vais le detruire !)
Marsh Posté le 07-12-2004 à 15:17:52
Pourtant j'ai vérifié : il est a 32°C !! c'est vraiment pas beaucoup a savoir que mon vieu proco a 700Mhz etait a 75°C quand je l'overclockais a 1000Mhz !
la ca fait 4 min qu'il est Booté mais seulement a 1150Mhz jessaye de voir si il reste stable....
Marsh Posté le 07-12-2004 à 15:18:22
le fsb il est as combien?
Marsh Posté le 07-12-2004 à 15:23:07
Dis donc 1150 c'est bien 11,5 x 100 ?
Essaye un load Optimized defaults
Marsh Posté le 07-12-2004 à 15:23:33
et as tu bien éteint ton PC après le flash
Marsh Posté le 07-12-2004 à 15:26:17
nicolo a écrit]Dis donc 1150 c'est bien 11,5 x 100 ?
+ 1
ta frequence c'est 11.5 x 133 mhz ds le bios
Message édité par copsc le 07-12-2004 à 15:26:49
Marsh Posté le 07-12-2004 à 15:26:28
si tu avais le temps de faire un cou de CPU-Z et nous publier la copie d'écran se serait cool.
Marsh Posté le 07-12-2004 à 15:28:04
Bon là ca fait plus de 10 minutes qu'il est démarré et j'ai lancé UT2004 avec tous les grafisme a fond pour voir si il rebootait a plein régime et ya pas eu de probleme.
je vais essayé de faire un Load Optimized Defaults mais j'avais bien arrété le PC apres donc on verra apres le LOD
Marsh Posté le 07-12-2004 à 15:29:40
comme nicolo fais 1 cpu-z
stp
Marsh Posté le 07-12-2004 à 15:36:27
Alors j'ai fait un Load Optimized Default et ca a mit tout seul Athlon 1800+ et toutes les options etc... et apres en sortant du menu Bios bah il voulais plus démarré donc encore retirage de pile Bios et maintenant je suis sous 1150Mhz en 100x11.5 et ca m'a l'air stable mais j'ai toujours une perte de 383 Mhz...
Marsh Posté le 07-12-2004 à 15:37:28
Missa pas très doué ! Ne pas savoir faire un "CPU-Z" !!! ça marche comment ? (si ca se trouve je sais faire et je connais pas le nom lol)
Marsh Posté le 07-12-2004 à 15:40:03
ici si tu l'as pas
http://www.materiel.be/listnews.php?start=12#news7928
Message édité par copsc le 07-12-2004 à 15:40:58
Marsh Posté le 07-12-2004 à 15:41:57
Ca va je me suis pas trompé c'était ce que j'était en train de faire avant de recevoir ton post !je le fait et je vous donne les infos !
Marsh Posté le 07-12-2004 à 15:45:40
http://img95.exs.cx/img95/484/p7gcpuz.jpg
Marsh Posté le 07-12-2004 à 15:46:09
une tite dernière la ram c'est quoi au passage, tu peux avoir l'info avec CPU Z aussi je crois
Rien que la ont voit que le flash etait obligatoire... 0,13µ
Message édité par nicolo le 07-12-2004 à 15:47:27
Marsh Posté le 07-12-2004 à 15:46:41
passe sur l'onglet memory et repost et SPD j'oubliai
Message édité par nicolo le 07-12-2004 à 15:49:28
Marsh Posté le 07-12-2004 à 15:51:09
http://img95.exs.cx/img95/2889/x2gcpuz2.jpg
Marsh Posté le 07-12-2004 à 15:52:23
http://img95.exs.cx/img95/6679/u6ncpuz3.jpg
Marsh Posté le 07-12-2004 à 15:53:01
FSB+33 Mhz ??? kesako
Marsh Posté le 07-12-2004 à 15:53:33
tu veux l'autre slot de 256 de ram pour le SPD ?
Message édité par Megazord le 07-12-2004 à 15:53:49
Marsh Posté le 07-12-2004 à 15:55:45
"FSB+33 Mhz ??? kesako"
Tiens tu as raison... qu'est ce que c'est ce truc ? c'est en rapport avec la frequence de ma Ram...
Marsh Posté le 07-12-2004 à 15:57:31
yes
