Plantage PC watchdog_timeout
Plantage PC watchdog_timeout - Matériels & problèmes divers - Hardware
Marsh Posté le 11-11-2022 à 15:32:20
J'ai remonté un ancien PC, cependant celui-ci n'arrête pas de planter avec le code "Clock Watchdog Timeout"
Je vous colle ici le message présent dans le minidump
Auriez-vous une idée ?
J'ai testé avec d'autres RAMs, une autre alimentation, une autre CG mais pas de changements.
Microsoft (R) Windows Debugger Version 10.0.25200.1003 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\110622-4265-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 19041 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Edition build lab: 19041.1.amd64fre.vb_release.191206-1406
Machine Name:
Kernel base = 0xfffff801`3e600000 PsLoadedModuleList = 0xfffff801`3f22a290
Debug session time: Sun Nov  6 20:22:04.803 2022 (UTC + 1:00)
System Uptime: 0 days 0:00:53.458
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff801`3e9f8fa0 48894c2408      mov     qword ptr [rsp+8],rcx ss:0018:fffff801`4247ec90=0000000000000101
0: kd> !analyze -v
*                        Bugcheck Analysis                                    *
CLOCK_WATCHDOG_TIMEOUT (101)
An expected clock interrupt was not received on a secondary processor in an
MP system within the allocated interval. This indicates that the specified
processor is hung and not processing interrupts.
Arguments:
Arg1: 0000000000000018, Clock interrupt time out interval in nominal clock ticks.
Arg2: 0000000000000000, 0.
Arg3: ffff9b0191340180, The PRCB address of the hung processor.
Arg4: 0000000000000002, The index of the hung processor.
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 2718
    Key  : Analysis.DebugAnalysisManager
    Value: Create
    Key  : Analysis.Elapsed.mSec
    Value: 22420
    Key  : Analysis.IO.Other.Mb
    Value: 7
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 32
    Key  : Analysis.Init.CPU.mSec
    Value: 453
    Key  : Analysis.Init.Elapsed.mSec
    Value: 40851
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 96
    Key  : Bugcheck.Code.DumpHeader
    Value: 0x101
    Key  : Bugcheck.Code.Register
    Value: 0x101
    Key  : WER.OS.Branch
    Value: vb_release
    Key  : WER.OS.Timestamp
    Value: 2019-12-06T14:06:00Z
    Key  : WER.OS.Version
    Value: 10.0.19041.1
FILE_IN_CAB:  110622-4265-01.dmp
BUGCHECK_CODE:  101
BUGCHECK_P1: 18
BUGCHECK_P2: 0
BUGCHECK_P3: ffff9b0191340180
BUGCHECK_P4: 2
FAULTING_PROCESSOR: 2
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  svchost.exe
STACK_TEXT:
fffff801`4247ec88 fffff801`3ea59672     : 00000000`00000101 00000000`00000018 00000000`00000000 ffff9b01`91340180 : nt!KeBugCheckEx
fffff801`4247ec90 fffff801`3e8d83ed     : 00000000`00000000 fffff801`39d0c180 00000000`00000246 00000000`00000d5d : nt!KeAccumulateTicks+0x1844a2
fffff801`4247ecf0 fffff801`3e8d8991     : 00000000`00000c00 00000000`000007f7 fffff801`39d0c180 00000000`00000001 : nt!KiUpdateRunTime+0x5d
fffff801`4247ed40 fffff801`3e8d2803     : fffff801`39d0c180 00000000`00000000 fffff801`3f2315f8 00000000`00000000 : nt!KiUpdateTime+0x4a1
fffff801`4247ee80 fffff801`3e8db1c2     : ffffd98e`b555cf50 ffffd98e`b555cfd0 ffffd98e`b555cf00 00000000`0000000c : nt!KeClockInterruptNotify+0x2e3
fffff801`4247ef30 fffff801`3e808a45     : 00000000`1ff3d1ea fffff801`3f2f39e0 fffff801`3f2f3a90 00000000`00000000 : nt!HalpTimerClockInterrupt+0xe2
fffff801`4247ef60 fffff801`3e9faa4a     : ffffd98e`b555cfd0 fffff801`3f2f39e0 00000000`00000001 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0xa5
fffff801`4247efb0 fffff801`3e9fafb7     : 00000000`00000000 fffff801`3f32f240 ffff9b01`9128b078 fffff801`3e8cd6aa : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
ffffd98e`b555cf50 fffff801`3e872125     : ffffd98e`b555d128 ffffd98e`b555d120 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
ffffd98e`b555d0e0 fffff801`3ec01433     : 00000000`00000000 ffffd98e`b555db80 00000000`00000001 00000000`00000001 : nt!KeFlushProcessWriteBuffers+0xa9
ffffd98e`b555d120 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!ExpGetProcessInformation+0x183
SYMBOL_NAME:  nt!KeAccumulateTicks+1844a2
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
IMAGE_VERSION:  10.0.19041.2006
STACK_COMMAND:  .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET:  1844a2
FAILURE_BUCKET_ID:  CLOCK_WATCHDOG_TIMEOUT_INVALID_CONTEXT_nt!KeAccumulateTicks
OS_VERSION:  10.0.19041.1
BUILDLAB_STR:  vb_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {95498f51-33a9-903b-59e5-d236937d8ecf}
Followup:     MachineOwner
Lien du fichier : https://uptobox.com/sbvf61o2mx1r
Message édité par chawat le 11-11-2022 à 15:43:28
