Redémarrage spontané
Redémarrage spontané - Matériels & problèmes divers - Hardware
Marsh Posté le 10-08-2005 à 08:50:47
Depuis quelques temps ma machine redémarre spontanément. Je suis sous Windows XP pro avec pare feux et antivirus à jour. Voici l'un des dump générés lors de ces redémarrage :
----- 32 bit Kernel Mini Dump Analysis
DUMP_HEADER32:
MajorVersion        0000000f
MinorVersion        00000a28
DirectoryTableBase  200fa000
PfnDataBase         81053000
PsLoadedModuleList  8055a420
PsActiveProcessHead 805604d8
MachineImageType    0000014c
NumberProcessors    00000001
BugCheckCode        10000050
BugCheckParameter1  fdfffff8
BugCheckParameter2  00000000
BugCheckParameter3  8054a832
BugCheckParameter4  00000000
PaeEnabled          00000000
KdDebuggerDataBlock 8054c060
MiniDumpFields      00000dff
TRIAGE_DUMP32:
ServicePackBuild      00000200
SizeOfDump            00010000
ValidOffset           0000fffc
ContextOffset         00000320
ExceptionOffset       000007d0
MmOffset              00001068
UnloadedDriversOffset 000010a0
PrcbOffset            00001878
ProcessOffset         000024c8
ThreadOffset          00002728
CallStackOffset       00002980
SizeOfCallStack       00000440
DriverListOffset      00003050
DriverCount           00000081
StringPoolOffset      000056a0
StringPoolSize        000011b8
BrokenDriverOffset    00000000
TriageOptions         00000041
TopOfStack            f6e99bc0
DebuggerDataOffset    00002dc0
DebuggerDataSize      00000290
DataBlocksOffset      00006858
DataBlocksCount       00000002
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a420
Debug session time: Sat Jul 30 11:31:15 2005
System Uptime: 0 days 0:08:17
start    end        module name
804d7000 806eb900   nt             Checksum: 00217A75  Timestamp: Wed Mar 02 01:59:37 2005 (42250FF9)
Unloaded modules:
b772c000 b7756000   kmixer.sys    Timestamp: unavailable (00000000)
b777e000 b77a8000   kmixer.sys    Timestamp: unavailable (00000000)
b8613000 b863d000   kmixer.sys    Timestamp: unavailable (00000000)
b863d000 b8660000   aec.sys     Timestamp: unavailable (00000000)
f7f86000 f7f87000   drmkaud.sys    Timestamp: unavailable (00000000)
b8bfd000 b8c0a000   DMusic.sys    Timestamp: unavailable (00000000)
f796f000 f797d000   swmidi.sys    Timestamp: unavailable (00000000)
f7d73000 f7d75000   splitter.sys    Timestamp: unavailable (00000000)
f7bbf000 f7bc4000   Cdaudio.SYS    Timestamp: unavailable (00000000)
f7d13000 f7d16000   Sfloppy.SYS    Timestamp: unavailable (00000000)
f7bb7000 f7bbc000   Flpydisk.SYS    Timestamp: unavailable (00000000)
Finished dump check
Quelqu'un aurait il une idée sur la cause de ce problème ?
Marsh Posté le 10-08-2005 à 09:15:10
:/ :bounce:
Uppp
Marsh Posté le 10-08-2005 à 09:23:36
 :heink: Multi ?  :whistle:
Ben comme d'hab, panel de tests à faire: memtest pour la ram, soft constructeur pour le disque dur, occt pour alim et T°.
www.ultimatebootcd.com
http://forum.hardware.fr/forum2.ph [...] ash_post=0
Marsh Posté le 10-08-2005 à 10:43:19
Je pense aussi que le matériel est en cause la dedans... je pencherais pour la mémoire vu que le module kmixer.sys n'est a priori utilisé par aucun de mes périphériques audio (après vérif dans le gestionnaire de périphs). Sinon a tout hasard est ce que quelqu un d'initié à la lecture des dump pourrait me dire comment interpréter le bugCheckCode et autre informations hésotériques de ce genre  ;)
Marsh Posté le 10-08-2005 à 11:46:26
:sol:Vois si tu trouves ton bonheur ici:
http://www.citrix4ge.de/tipps/bsod.htm
(Le "bugcheck" 50 correspond à PAGE_FAULT_IN_NONPAGED_AREA)
