toshiba tecra 9000 - Matériels & problèmes divers - Hardware
Marsh Posté le 17-11-2005 à 12:33:22
et ben non justement en telechargent les drivers et tout ça ne marche pas
c'est pour ça qu'il me faut le cd de reinstallation d'origigine car le dxdig ne trouve pas la carte son ni everest
System Information
Time of this report: 11/12/2005, 09:17:59
Machine name: PORTABLECG
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: French (Regional Setting: French)
System Manufacturer: TOSHIBA
System Model: T9000
BIOS: TECRA9000 v1.30 TOSHIBA
Processor: Intel(R) Pentium(R) III Mobile CPU 1000MHz
Memory: 510MB RAM
Page File: 147MB used, 1102MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: Hardware-accelerated Direct3D 9 is not available because the display driver does not support it. You may be able to get a newer driver from the hardware manufacturer.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: S3 Graphics SuperSavage/IXC Toshiba
Manufacturer: S3 Graphics, Inc.
Chip type: S3 SuperSavage/IX
DAC type: S3 SDAC
Device Key: Enum\PCI\VEN_5333&DEV_8C2E&SUBSYS_00011179&REV_05
Display Memory: 16.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Écran par défaut
Monitor Max Res:
Driver Name: S3SSav.dll
Driver Version: 6.13.0010.1232 (English)
DDI Version: 7
Driver Attributes: Final Retail
Driver Date/Size: 10/19/2001 14:23:36, 308736 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: s3ssavm.sys
Mini VDD Date: 10/19/2001 14:23:36, 93184 bytes
Device Identifier: {D7B75DD3-CF6E-11CF-1976-0B20A7C2CB35}
Vendor ID: 0x5333
Device ID: 0x8C2E
SubSys ID: 0x00011179
Revision ID: 0x0005
Revision ID: 0x0005
Video Accel: ModeMPEG2_C ModeMPEG2_A ModeMPEG2_D
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Marsh Posté le 17-11-2005 à 14:05:49
c'est ceux la que tu as essayé ?
14/01/05 Sound Driver
Yamaha Windows XP 6.13.10.2152 World Wide
18/12/01 Sound Driver
Yamaha Windows XP 5.12.01.3141 World Wide
Marsh Posté le 17-11-2005 à 20:49:28
oui de chez toshiba et de chez yamaha
sound-xp-613102152
awi3157_xp
Marsh Posté le 18-11-2005 à 10:58:58
j'ai un 9100 avec une carte Yam AC-XG
tu peux peut etre essayé avec les drv du 9100.
Marsh Posté le 24-11-2005 à 12:38:30
Marsh Posté le 17-11-2005 à 09:47:12
bonjour
je suis la recherche du cd rom de reinstallation car je n'ai plus la carte son
