verifying dmi pool data lorsque je retire Disque dur secondaire - Matériels & problèmes divers - Hardware
Marsh Posté le 28-11-2009 à 11:50:46
| papijo45 a écrit : bonjour tout le monde,   |
Possible.
J'ai eu le même message quand j'ai voulu installer XP (en bootant sur un CD) sur un SSD, après l'avoir installé sur un disque standard, mais le message a disparu en changeant de lecteur de DVD (!).
J'avais trouvé ça:
DMI or DesktopManagement Interface is a layer of abstraction between system components and the software that manages them.
The System Management BIOS (SMBIOS) is an extension of the Basic Input Output System (BIOS) that formulates and delivers this information to the operating system. The pool data is the information.
In short, when the BIOS is "Verifying DMI pool data" it is verifying the table of data it sends to the operating system (Windows, etc.).
Usually this is being caused after a hardware change has been made,
did you changed any hardware lately? If so take a look at the steps below:
1. If you changed the hardware just before this problem occurred (e.g., installed a new hard disk drive), unchange it.
2. If you installed a new hard disk drive, set the motherboard CMOS Setup to Auto for the drive type. You may have to disconnect the drive first.
3. Enable "Reset Configuration Data" (may be "Force Update ESCD" in some CMOS Setups) in the motherboard CMOS Setup PNP/PCI configuration. (Rebooting will automatically disabled it after it has done its thing.)
4. The CMOS may be corrupted. Clear it.
5. Disconnect all drives not required to boot the computer. If this fixes it, reconnect one at time.
6. The floppy drive may be bad or not connected properly.
7. Reseat all expansion boards.
8. Pull all boards not required to boot the computer.
Marsh Posté le 28-11-2009 à 12:09:08
ok je vois que j'ai fais une petite betise...
je comprends un peu près mais dans les faits faut t-il que je flash le bios ou juste changer la ligne "Reset Configuration Data"?
| Citation : 4. The CMOS may be corrupted. Clear it.      |
cette phrase me fait peur en fait!
Marsh Posté le 28-11-2009 à 19:39:56
j'ai esssayé la méthode mais dans le bios section pnp/pci configuration  je n'ai pas la ligne "reset configuration data"  mais juste pci(1 2 ou 3) configuration avec marqué auto et jai le choix avec des chiffre. ca coince pour utiliser la technique! tu as cette option disponible dans ton bios toi?
si je clear cmos sans faire l'etape 3 rien ne va changer je suppose non?
Marsh Posté le 28-11-2009 à 21:32:10
Fais un clear cmos, de toutes façons ça ne peut pas faire de mal.
Marsh Posté le 28-11-2009 à 10:42:02
Je m'explique j'ai deux DD: un IDE (80Go) et un SATA (500Go) tout fraichement acheté sur lequel j'ai remis windows vista dessus.
Aujourd'hui, le soucis est que lorsque je veux virer le DD en ide le bios bloque au demarrage sur 'verifying dmi pool data"!
lorsque je le rebranche il me propose par contre de booter sur l'un ou l'autre des windows installé. je choisis donc celui le windows installé sur le SATA et tout marche nickel.
hypothèse: j'ai installé windows vista sur le sata lorsque j'etais sur windows de l'IDE et non en bootant au demarrage sur le DVD. cela aurait-il créé un conflit?
ma question est bete: je voulais savoir si je devais reinstaller le windows par la bonne méthode ou s'il y avait une petite bidouille pour reparer tt ca.
je vous remercie par avance.
ps:quand je disais "marcher nikel" j'ai certaine fois le pc qui bloque 3 4 seconde et j'entand le sata qui demarre en faisaint un bruit de lancement crescendo et 10 seconde plus tard le meme bruit mais decrescendo ce qui m'ennnuie pas mal car cela arrive aussi bien en etant sur le net ou un jeu video.
config:
vista
cpu e4500
carte mere ga p35 ds3r
