Changement de processeur sur un EASYNOTE R3280 - Carte mère - Hardware
Marsh Posté le 11-11-2007 à 19:52:35
voici des info en plus sur mon pros actuel :
Processors Information
Processor 1 (ID = 0)
Number of cores 1
Number of threads 1 (max 1)
Name AMD Turion 64 ML-28
Codename Lancaster
Specification AMD Turion(tm) 64 Mobile Technology ML-28
Package Socket 754
CPUID F.4.2
Extended CPUID F.24
Brand ID 10
Core Stepping SH8-E5
Technology 90 nm
Core Speed 800.2 MHz (4.0 x 200.0 MHz)
HT Link speed 800.2 MHz
Stock frequency 1600 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 8.0x
VID range 0.800 V - 1.500 V
Features XD
K8 Thermal sensor yes
K8 Revision ID 4.2
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02002005h
Max CPUID level 00000001h
Max CPUID ext. level 80000018h
Function eax ebx ecx edx
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00020F42 0x00000800 0x00000001 0x078BFBFF
0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00020F42 0x00000286 0x00000001 0xE3D3FBFF
0x80000002 0x20444D41 0x69727554 0x74286E6F 0x3620296D
0x80000003 0x6F4D2034 0x656C6962 0x63655420 0x6C6F6E68
0x80000004 0x2079676F 0x322D4C4D 0x4D410038 0x75542044
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x0000003F
0x80000008 0x00003028 0x00000000 0x00000000 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
Cache descriptor Level 1 I 64 KB 1 threads
Cache descriptor Level 1 D 64 KB 1 threads
Cache descriptor Level 2 U 512 KB 1 threads
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0xC001001E edx = 0x00000000 eax = 0x00000042
MSR 0xC0010015 edx = 0x00000000 eax = 0x00000000
MSR 0xC0010042 edx = 0x1E021616 eax = 0x02080000
MSR 0xC0010041 edx = 0x00004E20 eax = 0x00000200
Chipset
Northbridge ATI Xpress 200 (RS480) rev. 01
Southbridge ALI M1573 rev. 31
Memory Type DDR
Memory Size 512 MBytes
Memory Frequency 133.4 MHz (CPU/6)
CAS# 2.0
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 6
Bank Cycle Time (tRC) 8
DRAM Idle Timer 16
Command Rate 2T
Marsh Posté le 03-11-2007 à 23:39:10
salut
je voudrais changer le processeur de mon pc (un AMD Mobile Turion 64 model ML-28)
j aimerais savoir si cela est possible vu que le socket est le 754.
si l on peut installer d autres pros que ceux en format 754.
si le bios va prendre en charge le nouveau pros, si non comment faire pour le changer
merci de repondre a mes questions
je vous laisse le lien de la fiche technique du pc au cas ou vous auriez besoin de plus d info
http://support.packardbell.com/fr/ [...] 239&g=1400
