cai koi ca comme carte mere? - Carte mère - Hardware
Marsh Posté le 23-07-2002 à 11:31:09
C une DFI
Chipset
Intel 440BX AGPset
CPU Socket
Slot 1
CPU Supported
Pentium® III 500E-700E*/100MHz
Pentium® III 450-600MHz/100MHz
Pentium® II 350-450MHz/100MHz
Pentium® II 233-333MHz/ 66MHz
SEPP Celeron? 266-433MHz/66MHz
Memory
3 DIMM sockets
max. 384MB (unbuffered)
max. 768MB (registered)
Supports PC100 and ECC
PCI IDE
Dual PIO mode 3/4 EIDE channels up to 4 IDE devices
UltraDMA/33 transfer rate up to 33MB/sec
Super I/O
2 x NS16C550A compatible UARTs
1 x SPP/ECP/EPP parallel port
Rear Panel I/O Ports
2 x USB, 2 x DB-9, 1 x DB-25, 1 x PS/2 Mouse, 1x PS/2 Keyboard
Internal I/O Connectors
1x IrDA, 2x IDE, 1x Floppy, 1x ATX Power, 3 x Fan, 1 x SB-Link, 1 x WOL
Power Management
ACPI and OS direct power management
Wake-on events : RTC/Modem/LAN/KB/Mouse
Hardware Monitor
System, Processor Temperature, Voltage and Fan speed
Expansion Slots
1 AGP slot
3 PCI slots
2 ISA slots
1 PCI/ISA slot
BIOS
Award / 2Mbit
Form Factors
ATX, 4 layers
30.48cm x 17 cm
12.0 inch. x 6.7 inch.
Google rulezz ...
Marsh Posté le 23-07-2002 à 11:34:36
evode a écrit a écrit : C une DFI Chipset Intel 440BX AGPset CPU Socket Slot 1 CPU Supported Pentium® III 500E-700E*/100MHz Pentium® III 450-600MHz/100MHz Pentium® II 350-450MHz/100MHz Pentium® II 233-333MHz/ 66MHz SEPP Celeron? 266-433MHz/66MHz Memory 3 DIMM sockets max. 384MB (unbuffered) max. 768MB (registered) Supports PC100 and ECC PCI IDE Dual PIO mode 3/4 EIDE channels up to 4 IDE devices UltraDMA/33 transfer rate up to 33MB/sec Super I/O 2 x NS16C550A compatible UARTs 1 x SPP/ECP/EPP parallel port Rear Panel I/O Ports 2 x USB, 2 x DB-9, 1 x DB-25, 1 x PS/2 Mouse, 1x PS/2 Keyboard Internal I/O Connectors 1x IrDA, 2x IDE, 1x Floppy, 1x ATX Power, 3 x Fan, 1 x SB-Link, 1 x WOL Power Management ACPI and OS direct power management Wake-on events : RTC/Modem/LAN/KB/Mouse Hardware Monitor System, Processor Temperature, Voltage and Fan speed Expansion Slots 1 AGP slot 3 PCI slots 2 ISA slots 1 PCI/ISA slot BIOS Award / 2Mbit Form Factors ATX, 4 layers 30.48cm x 17 cm 12.0 inch. x 6.7 inch. Google rulezz ... |
okai newbie powaa j'ai rien pigé
cai bien comme carte?
Marsh Posté le 23-07-2002 à 11:40:20
Ca me fait penser à un truc: comment faire pour trouver la ref de sa CM si on plus de doc dessus? C'est mon cas
Je sais que j'ai un Duron 800 et j'aimerai bien savoir jusqu'où je peux aller niveau proc....
Marsh Posté le 23-07-2002 à 11:41:34
poor la carte je sais po ce kelle vaut, C du BX => a priori po de mauvaises surprises
Poor les doc, les sites des constructeurs proposent les doc users en pdf en plus des spec
Marsh Posté le 23-07-2002 à 12:03:02
drjones a écrit a écrit : Ca me fait penser à un truc: comment faire pour trouver la ref de sa CM si on plus de doc dessus? C'est mon cas ![]() Je sais que j'ai un Duron 800 et j'aimerai bien savoir jusqu'où je peux aller niveau proc.... |
http://sandra.sisoftware.co.uk
Marsh Posté le 23-07-2002 à 12:17:02
Citation : vieille |
Marsh Posté le 23-07-2002 à 11:27:44
Salut, petite question, cai koi comme carte mere ca?
![:D :d](https://forum-images.hardware.fr/icones/biggrin.gif)
P2XBL-REV.D1
Apparemment cai les references qu'il y a marqué dessus. Vous savez ce que c'est? la marque, details.. etc..? Apparemment ca marche avec des P3
