Flash... comment?
Flash... comment? - Carte mère - Hardware
Marsh Posté le 14-05-2003 à 17:25:36
salut
je veux flasher mon bios pour qu'un Xp 2000 soit reconnu
voila le liser moi du zip contenant les fichiers pour le flash
je pige pas tout...
             K7V8366A KuDoz 7 BIOS V3.8LCP release note
This disk contains three files:KD7_V38.BIN,README.TXT and AWDFLASH.EXE
1.The checksum of KD7_V38.BIN is 7C66(Hex);
2. How to use AWDFLASH.EXE utility:
   This is a flash memory write/read utility.
IMPORTANT NOTE:
   The AWDFLASH utility could not correctly run in windows (virtual 8086)
   MS-DOS mode. It must be proceeded with the following steps:
      1.Create a bootable system floppy diskette by typing "FORMAT A:/S"
        from the dos prompt under DOS6.XX or WINDOWS9X environment.
      2.Boot system with diskette.
      3.Then run the AWDFLASH utility.
Usage:
      AWDFLASH [BIOSfile1] [BIOSfile2] [/<sw>[/<sw>...]]
     BIOSfile1: New BIOS Name For FLASH Programming
     BIOSfile2: BIOS File For Backing-up the Original BIOS
 <command> function definition:
      cc: clear CMOS;        cp: clear PnP;
      cd: clear DMI.
/sn: No Original BIOS Backup. If this option is chosen:
      Be sure your new BIOS is compatible with your MB. If not, the system
        are damaged.
/sy: Backup Original BIOS to Disk File.
Examples:
        AWDFLASH ****.BIN /py/sn/cd/cp
Warning:
   Avoid power-off incidently in upgrading procedure, or system would fail
   to reboot!
UPDATE DATE:03/27/2003
en gros une fois sous DOS on fait koi? on tape koi?
Marsh Posté le 14-05-2003 à 17:42:07
Marsh Posté le 14-05-2003 à 17:47:09
salut
j'avais pigé ca
mais c'est cette partie:
     cd: clear DMI.
       are damaged.
Examples:
fo ke je tape koi??
Marsh Posté le 14-05-2003 à 18:04:20
rien, c'est pour eviter qu'il te pose des questions avant le flashage. tapes simplement "AWDFLASH KD7_V38.BIN" et ca ira tres bien
