P4 mobile sur pc Bureau - Carte mère - Hardware
Marsh Posté le 17-01-2005 à 22:03:01
Do Gigabyte MB products support the mobile CPU for laptop?
Based on MB chipset specification and because the mobile CPU for laptop has totally different H/W design to desktop CPU, although some mobile CPU has the same pin-count of CPU socket, but we do not recommend you using mobile CPU with our MB products and will not guarantee any result.
Marsh Posté le 17-01-2005 à 10:37:49
Salut !
![:D :D](https://forum-images.hardware.fr/icones/biggrin.gif)
Est-il possible de mettre un processeur P4 mobile d'un portable sur un ordinateur normal et inverssement ?
