[Topic Unique] ASUS P4PE [BIOS 1004 Final] !!!
!!! [Topic Unique] ASUS P4PE [BIOS 1004 Final] - Carte mère - Hardware
Marsh Posté le 08-04-2003 à 00:40:41
Lien directe du dernier bios officiel:
ftp://ftp.asus.com.tw/pub/ASUS/mb [...] pe1004.zip
Suite du topic de AkhnotPierrot:
                                                       http://membres.lycos.fr/cybermatos/P4PE.jpg
Introduction
The P4PE socket 478 motherboard is the world's first solution able to support the next-generation P4 processor up to 3GHz and beyond and Intel Hyper-Threading Technology. Leveraging the Intel 845PE chipset to support DDR333 memory, P4 CPUs on 533MHz FSB and advanced technology such as Serial ATA and Gbit Ethernet, the P4PE delivers a full-value, high-performance solution for today's most demanding tasks.
Serial ATA (optional)
Serial ATA is the next generation ATA specification that provides scalable performance for today and tomorrow. With up to 150MB/s data transfer rate, Serial ATA is faster than current Parallel ATA, while providing 100% software compatibility.
Gigabit LAN Ready (optional)
The P4PE with BroadCom® Gigabit LAN, delivers transfer speeds up to ten times faster than conventional 10/100 Ethernet connections. Gigabit LAN is the networking standards for the future and is ideal for handling large amounts of data such as video, audio, and voice.
SoundMAX Digital Audio System (optional)
The SoundMAX Digital Audio System is the industry's highest performance and most reliable audio solution for business professionals, audiophiles, musicians, and gamers. SoundMAX Digital Audio System can output 5.1 channel surround sound and features state-of-the-art DLS2 MIDI synthesizer with Yamaha DLSbyXG sound set, 5.1 Virtual Theater? and supports all major game audio technologies including Microsoft DirectX? 8.0, Microsoft DirectSound 3D?, A3D, MacroFX, ZoomFX, MultiDrive 5.1, A3D and EAX.
CrashFree BIOS
CrashFree BIOS allows users to restore BIOS data from a floppy diskette even when BIOS code and data are corrupted during upgrade or invaded by virus. Unlike other competing vendors's products, ASUS motherboards now enable users to enjoy this protection feature without the need to pay an optional ROM.
C.P.R. (CPU Parameter Recall)
When the system hangs due to overclocking failure, there is no need to open the case to clear CMOS data. Simply restart the system and the BIOS will automatically restore the CPU default setting for each parameter.
ASUS Post Reporter
During the computer POST (Power On Self-Test), ASUS POST Reporter provides friendly voice warnings through internal or external speaker, clearly explaining system errors for quick and easy optimization. The bundled Winbond Voice Editor software allows uses to add customized system voice warnings and multi-language support.
ASUS Multi-Language BIOS
ASUS provides friendly localized BIOS setup menu to help you configure your system as easy as possible.
ASUS EZ-Flash
With ASUS EZ Flash, you can update BIOS before entering operating system. No more DOS-based flash utility and bootable diskette required.
ASUS Q-Fan technology
ASUS Q-Fan technology intelligently adjusts fan speeds according to system loading to ensure quiet, cool and efficient operation.
IEEE 1394 interface (optional)
IEEE 1394 interface provides high speed digital interface for audio / video appliances such as digital television, digital video camcorders, storage peripherals & other PC portable devices.
AGP Warning LED
ASUS has designed into this motherboard an AGP Warning LED. The AGP Warning LED automatically stops you from turning on your system with incompatible voltage AGP (3.3V) cards, and protects from permanently damaging your motherboard.
Overclocking
ASUS P4PE offers robust overclocking options to maximize your system performance.
-Flexible CPU Core Voltage Adjustments in 0.025V increments over defaults
-SFS (Stepless Frequency Selection) from 100MHz up to 200MHz at 1MHz increments
-Adjustable FSB/DDR ratio. Fixed AGP/PCI freqencies
-C.P.R. (CPU Parameter Recall)
-Rock-solid stability
ASUS Reliability
All ASUS motherboards are designed and tested to meet the highest quality standards. Responsive customer support and frequent BIOS and driver updates ensure that you're getting the fastest, most reliable performance - all the time. All ASUS motherboards are also backed by a 3-year limited warranty.
Comprehensive Software Bundle
All ASUS motherboards include a valuable software bundle of popular third party programs that enable you to enjoy the full capabilities of your ASUS product:
Trend® Micro PC-cillin 2002 anti-virus program
ASUS® PC Probe for system monitoring
InterVideo® WinCinema (P4PE Gold Version Only )
ASUS P4PE classique:
http://membres.lycos.fr/cybermatos/asus-p4pe.jpg
ASUS P4PE Black-Pearl:
http://membres.lycos.fr/cybermatos/P4PE%20Black-Pearl.jpg
-Tous les drivers et utilitaires Asus:
http://www.asus.com.tw/support/dow [...] Name=Tools
-Lien FTP directe pour telecharger le dernier BIOS:
ftp://ftp.asuscom.de/pub/ASUSCOM/ [...] 45pe/P4PE/
-Intel Chipset Software Installation Utility:
http://downloadfinder.intel.com/sc [...] ductID=816
-Intel Application Accelerator:
http://downloadfinder.intel.com/sc [...] ductID=663
-Pack tout en un,des derniers drivers pour la P4PE (un grand merci à Mei ;)):
http://mei.planet-d.net/Pack_de_pilotes_ASUS_P4PE.exe (46.4Mo)
===Contenu de cette Release (V0.2)===
-Asus Acpi bios flash memory writer V2.21
-Asus Probe V2.20.00
-AsusUpdate V3.45.03
-Promise Array Management Version 3.2.1 Build 8 Release 11/05/02
-Promise FastTrak 376 Driver 1.00.0.15
-Broadcom BCM440x Software Release Build 6.5.4
-Broadcom BCM570x Software Release Build 6.6.7
-Analog Devices SoundMAX NT4 Driver 4.02.00.0066
-Analog Devices SoundMAX WDM Driver 5.12.01.3538
-Intel(R) Application Accelerator 2.3
-Intel(R) Chipset Identification Utility 2.81
-Intel(R) Chipset Software Installation Utility Version 5.00.1012
Message édité par cybermatos le 29-04-2003 à 20:31:55
Marsh Posté le 08-04-2003 à 09:47:09
DRAPAL :)
J'ai commencé un régime, renoncé à l'alcool, je mange léger, et en quatorze jours j'ai perdu deux semaines.
Marsh Posté le 08-04-2003 à 10:35:05
bon une petite question avec votre P4PE comment flasher vous votre bios ? sous windows avec l'utilitaire d'asus ?
sinon voila un lien ou on peut télécharger tous les mises à jour des utilitaires Asus :  http://www.asus.com.tw/support/dow [...] Name=Tools
PS : c'est sur que SAT08 et autres ont bien polluer le précédant topic et c'était obligé qu'il ferme
Message édité par nico42 le 08-04-2003 à 10:36:31
Marsh Posté le 08-04-2003 à 11:30:07
Yes je le flash avec ASUS UPDATE!! :)
Marsh Posté le 08-04-2003 à 11:49:56
tu devrais mettre le lien vers les utilitaires Asus sur ton premier message car moi j'ai chercher longtemps avant de le trouver
Marsh Posté le 08-04-2003 à 12:32:36
good idea!! :)
Marsh Posté le 08-04-2003 à 12:55:07
Pourquoi ne pas utiliser simplement l utilitaire intégré à la carte mère pour flasher son BIOS ? ( EZ flash)...
Il suffit de mettre le bios sur une disquette et le tour est joué....Déjà utilisé sur la P4B533,je ne pense pas qu il y ait une grosse différence avec la PEP4...
J
Marsh Posté le 08-04-2003 à 15:05:10
cybermatos tu peut reprendre l'exemple du topic de l'asus p4g8x pr faire celui ci cest vraiment pas mal fait et merci pr le lien par mp
Marsh Posté le 08-04-2003 à 15:14:38
Là j'ai pas trop le temps,mais je compte bien refaire la tronche du topic,parceque c'était n'importenawak sur le topic de Akhnot,tout était confu et ça parlait également de P4B533... :D
Je m'en occuppe ce soir!! :)
Message édité par cybermatos le 08-04-2003 à 15:15:10
Marsh Posté le 08-04-2003 à 15:16:00
moui car la le premier topic fait un peu la trnche quand meme :lol: :D
Marsh Posté le 08-04-2003 à 15:39:26
Attention t'es plus modo n'oublie pas.Plus de hors-sujets ou tu risques de te faite teletubbiser par Slyde!!  [:nicodonald]
Message édité par cybermatos le 08-04-2003 à 15:41:24
Marsh Posté le 08-04-2003 à 16:46:04
moi je flash tout sous windows que ce soit des betas, des nouveaux, des plus vieux,... tout passe sans broncher  [:chromium]
Mais le Ezflash est qd meme bien qd on a po win installer et que l'on a plus de disquette de boot crée  :love:
Par contre je voudrais qd meme bien si le fameux recovery boot fonctionne aussi bien que ce que l'on dit.
Personne veut lancer un flash et éteindre son pc pdt le flash?
Allez c pour la bonne cause  :whistle:  puis vous aurez tjrs le sav si vous voulez  :o
L'air de rien je monte un pc en fin de semaine avec P4 2.53 mais je ne prend pas de ASUS P4PE mais une MSI, ca va bien aussi. J'espere que ce P4 sera mieux que le mien au niveau o/c car 2.53 @ 2.75 c nul, si il va mieux hop j'échange  :p  en + ma PC3200 Winbond s'ennuye en 380  :cry: alors qu'elle tient le 400 en 2-2-2  :love:
Marsh Posté le 08-04-2003 à 18:25:50
J'ai redonné un peu de couleurs au topic!! :)
Si vous avez des suggestions à me faire,ou des informations interressantes à faire figurer,n'hesitez pas!!  :)
Message édité par cybermatos le 08-04-2003 à 18:26:29
Marsh Posté le 08-04-2003 à 18:28:55
| AMD Ryzen 7 7700X 8C/16T @ 4.5-5.4GHz - 64GB DDR5-6000 30-40-40 1T - AMD Radeon RX 7900 XTX 24GB @ 2680MHz/20Gbps |
Marsh Posté le 08-04-2003 à 19:02:45
(drapal)
pour le flaschage de bios, j'utilise asus update sous windows, lorsque j'ai du passé du bios beta 12 au 1002 j'ai été obligé de faire shift+f2 et ça a marché niquel :) (flemme de passé sous dos)
Functional Troubleshooting Bizzard
Marsh Posté le 08-04-2003 à 19:13:55
http://forum.hardware.fr/icones/flag1.gif
Marsh Posté le 08-04-2003 à 19:33:57
Sat08, Pentuim4 on vous attend  :hello:
Marsh Posté le 08-04-2003 à 19:37:39
ftb91 a écrit :
(drapal)
Sinon il y a l'option downgradable a cocher pour downgrader le bios sous windows avec asus update ;)
Marsh Posté le 08-04-2003 à 20:01:09
g pas du voir cet option ?? :/
tant pis pour lemoment mon pc tourne avec le bios d'origine et vu les emmerdes que g eu, j'attend le prochain bios non beta
pour le HT, sur mon bios c'est activé et bien reconnu par xp :D
Marsh Posté le 08-04-2003 à 20:04:18
Au niveau du menu pour choisir ou prendre le bios tout en bas il y a option et c la ;) enfin sur la version 3.45.03
A plus
Marsh Posté le 08-04-2003 à 20:42:12
Ben il est sur le CD de la P4PE !!!
Et en plus d'aller chercher des nouvelles versions de BIOS, il peut aussi aller chercher des nouvelles versions de lui-même.
Donc y'a même pas à savoir où on le trouve.
(drapal au fait :D)
Marsh Posté le 09-04-2003 à 08:52:40
(drapal au fait :D)
Tu sais tous les utilitaires sont régulièrement mis à jour, ce qui peut aider, sinon, parfois tu perd le CD d'utilitaires :o
Marsh Posté le 09-04-2003 à 11:21:14
salut ^^
moi g des chtit blem avec cte carte  enfin pa méchant mais a force ca soule...
quand je lis un mp3 avec winamp certaine fois ca saute en faisant un claquement...normal? :heink:
Marsh Posté le 09-04-2003 à 11:40:56
:hello: (drapeau)
Je sais pas si certains s'en sont rendus compte, mais avec 2 barrettes de 256 corsair DDR 400 cas 2 :
_ barrettes placées en slot 1 et 2 : je n atteignais meme pas le cas 2 à 400
_ barrettes placées en slot 1 et 3 : je suis en 2-3-2-6 à 426
Voila
Message édité par ohmummy le 09-04-2003 à 11:45:30
Marsh Posté le 09-04-2003 à 11:42:20
shilinoana a écrit :
salut ^^
tu utilises quoi comme sortie audio?
Marsh Posté le 09-04-2003 à 11:47:26
OhMummy a écrit :
:hello: (drapeau)
Voila
Lool... moi Slot1²2 : 2-2-2-5 le reste a fond a 192Mhz a 2.5V
Les trois, 184 2-2-3-6 le reste a fond a 2.5V... apres faut dire que je suis limité par ma PC2700 :(
Marsh Posté le 09-04-2003 à 11:48:44
oula faudrait que je verif ca moi vu que je v avoir mon new p4 et que g de la super ram ca pourrait jouer un role important ca  :love:
Marsh Posté le 09-04-2003 à 12:00:11
J'ai la meme ram que toi, sauf que j'ai 2x256Mo...
Normallement cette RAM tiens 200 2-2-2-5 tout aggressif en RAM/Chipset dans le BIOS a 2.6V... (soit ca tension nominale)
Apres avec 2x512Mo je ne sais pas... Mais ca doit le tenir quand meme. Si tu as un 2.4B de bonne facture ta ram te limitera que si tu veut garder tes timings super agressifs et etre desynchro au max.
Marsh Posté le 09-04-2003 à 12:01:43
bah la normal  la fiche verte pkoi?
Marsh Posté le 09-04-2003 à 12:07:18
non g un 2.53 mais qui monte pas au dessus de 2.75 de maniere stable avec prime95  :heink:  de + les radeon 9700 font leur difficile mais je c que la ram tient effectivement 400 tout a donf g deja teste. Mais je dois acheter un new 2.53 pour un gars et je suppose qu'il va mieux s'oc donc hop je change vu que le gars a horreur de l'oc  :sol:
Je voudrais les 3ghz car ca fe rond ca au -  :whistle:
Marsh Posté le 09-04-2003 à 12:07:38
ta mis les derniers drivers a jour?
Marsh Posté le 09-04-2003 à 12:08:33
c pa les drivers...c bizar ds les jeu ca saute pa mais winamp ca saute des fois...
Marsh Posté le 09-04-2003 à 12:18:57
au faite je fai un tour sur asus ya pas les drivers...mem sur le site de soundMAX jtrouve pa la page... :(
Marsh Posté le 09-04-2003 à 12:24:15
mais ta vraiment du chercher longtemps toi dis donc  :sarcastic:  :pfff:
ftp://ftp.asus.com.tw/pub/ASUS/mi [...] m_3520.zip
je suis trop gentil avec ca  :o
Marsh Posté le 09-04-2003 à 12:25:29
arf le lien ftp ne marche pa ct pour ca que g pa chercher deds  merci ! le lien direct flashget il aime mieux  :hello:  ;)
Marsh Posté le 09-04-2003 à 12:26:28
ce ne sont pas les dernier... les derniers sont les 3533... a cherche dans le site support ASUS, rayon P4S8X-X :D
edit : bah non ya les 3538 now !!!
ftp://ftp.asus.com.tw/pub/ASUS/mi [...] 0_3538.zip
Message édité par MEI le 09-04-2003 à 12:28:54
Marsh Posté le 09-04-2003 à 12:31:56
Bienvenue dans le club des possesseurs de 2.53 c1 flemmards..
(2.75 pour moi  maxi quelque soit le voltage...)
Marsh Posté le 09-04-2003 à 12:33:43
drapal
Marsh Posté le 09-04-2003 à 12:35:35
Hey les gars, ca vous dirais que je fasse un pack avec tout les derniers drivers/utils pour la P4PE ???
Non parce que vu comme j'ai galerer pour tout trouver je me disais que ca pourrais etre utile.
Marsh Posté le 09-04-2003 à 12:38:08
Te moque pas,mon ancien P4 2.8GHZ ne passait au delà de 2.9GHZ quelque soit le vcore,type de barette.... Heureusement comme je bosse dans une boîte qui vends plein de matos,j'ai pu faire un échange en standard...   :sol:
