[Topic Unique]: Epox Série 9NPA+Ultra/SLI (Athlon64-Nforce4 )
[Topic Unique]: Epox Série 9NPA+Ultra/SLI (Athlon64-Nforce4 ) - Carte mère - Hardware
Marsh Posté le 11-04-2005 à 16:39:22
http://img246.echo.cx/img246/7195/sanstitre8st.jpg
EPOX Série 9NPA+Ultra
http://www.epox.org/cms/images/stories/boards/9npa.jpg
Caractéristiques Technique:
CPU Socket
Support Socket-939 based AMD Athlon-64/ Athlon-64 FX up to 4000+ with 2.0GT/s Hyper Transport
 Chipset
nVidia nForce4 Ultra AGPset
 Memory
4x 184-pin DDR SDRAM DIMM sockets
Supports single- / doublesided 2.5v DDR-266/333/400 DIMMs in 64/128/256/512 MB Modules
Supports up to 4 GB System Memory
Dual Channel Architecture
 Expansion Slots
3x PCI Express (x1) connectors compliant with PCI Express 1.0
1x PCI Express (x16) connector compliant with PCI Express 1.0
Three PCI connectors compliant with PCI v2.2
 Onboard PCI/IDE
Two IDE ports (up to 4 IDE devices) with UDMA-33, ATA-66/100/133 support from embedded IDE controller.
 I/O
Onboard Winbond W83627THF LPC bus I/O controller
Legacy peripheral interface for PS/2 keyboard & mouse, FDD, Parallel, Two Serial, Game and IrDA (version 1.0 compliant)
1394A: Two ports (400 Mbps)
Smartfan™ function for noise / temperature control of CPU cooler automatically based upon temperature
 USB
Ten USB connectors compliant with USB2.0 from embedded USB controller (4 connectors at rear panel)
 S-ATA
Four S-ATA ports from nForce CK8-04 up to 150MBps bandwidth with RAID 0,1 0+1, JBOD support
 Integrated Audio
Selectable 2, 6 or 8-CH audio from onboard Realtek ALC850 AC'97 version 2.3 compliant CODEC width 18-bit ADC and 16-bit DAC resolution
Support AUX-in, CD-in, S/PDIF-in and S/PDIF-out
Rear Panel audio jacks configuration:
For 2-channel mode; stereo Line-out (Lime), stereo Line-In (Light blue) and Mic-In (Pink)
For 6-channel mode; Front stereo-out (Lime), Rear stereo-out (Light blue), Center and Sub-woofer (Pink)
For 8-channel mode; stereo Line-In (Light blue), Mic-In (Pink), Front Stereo-out (Lime), Rear stereo-out (Black), Center and Sub-woofer (Orange) and Side stereo-out (Gray)
Support Front panel audio for Mic-In and stereo Line-Out only. (Front panel Line-out electrically shared with rear panel Line-out).
Support Auto Jack Sensing for fool-proof audio device installation
Coaxial S/PDIF-out available on rear panel
 LAN
1Gb Ethernet from onboard Cicada CIS8201 Gigabit Ethernet PHY
Embedded Nvidia Firewall with Active Armor (SNE)
 BIOS
4MB Flash EEPROM with Award Plug&Play BIOS
Support EZ Boot for fast bootable device selection
Support Magic Health for system hardware status report during system boot-up
 Special Features
Onboard Post-Port LED display
KBPO (Keyboard Power On)
Wake-On-LAN
Supports USB resume in S3
Support CPU over heat protection
 Power BIOS
Support Asynchronous clocking mode between FSB and AGP/PCI
BIOS adjustable CPU clock and voltage, DIMM frequency and voltage settings.
 Powerfull utilities for Windows
USDM (Unified System Diagnostic Manager) for system hardware monitoring
Magic Flash for BIOS update without requiring a DOS Flash utility and/or bootable diskettes
Magic Screen for personal bootup screen design
 Usefull Software Bundle
Symantec Norton Anti Virus system security
Wasay Pro Magic for system backup
 Form Factor
305mm x 245mm x 40mm, ATX Size
EPoX EP-9NPA+SLI
http://nokytech31.free.fr/epox9npa+sli.jpg
Caractéristiques Techniques:
CPU Socket
* Support Socket-939 based AMD Athlon-64/ Athlon-64 FX up to 4000+ with 2.0GT/s Hyper Transport
Chipset
* nVidia nForce4 SLI Host Controller
Memory
* 4x 184-pin DDR SDRAM DIMM sockets
* Supports single- / doublesided 2.5v DDR-266/333/400 DIMMs in 64/128/256/512 MB Modules
* Supports up to 4 GB System Memory
* Dual Channel Architecture
Expansion Slots
* 1x PCI Express (x1) connectors compliant with PCI Express 1.0
* Two PCI Express (x16) connectors compliant with PCI Express 1.0a to support SLI technology
* Three PCI connectors compliant with PCI v2.2
* One SLI riser control card connector
Onboard PCI/IDE
* Two IDE ports (up to 4 IDE devices) with UDMA-33, ATA-66/100/133 support from embedded IDE controller.
I/O
* Onboard Winbond W83627THF LPC bus I/O controller
* Support Hardware Monitoring function such as fan speed and CPU temperature
* 1394A: Two ports (400 Mbps)
* Smartfan™ function for noise / temperature control of CPU cooler automatically based upon temperature
* PS/2 keyboard and mouse, FDD, Parallel, one Serial, Game and IrDA (v1.0 compliant)
USB
* Ten USB connectors compliant with USB2.0 from embedded USB controller (4 connectors at rear panel)
S-ATA
* Four S-ATA ports with up to 150 MBps bandwidth from Silicon Image Sil-3114 with RAID 0/1/5/10 support and Port Multiplier function for expansion to external S-ATA HDD array
* Four S-ATA ports from nForce CK8-04 up to 150MBps bandwidth with RAID 0,1 0+1, JBOD support
Integrated Audio
* Selectable 2, 6 or 8-CH audio from onboard Realtek ALC850 AC'97 version 2.3 compliant CODEC width 18-bit ADC and 16-bit DAC resolution
* Support AUX-in, CD-in, S/PDIF-in and S/PDIF-out
* Rear Panel audio jacks configuration:
  o For 2-channel mode; stereo Line-out (Lime), stereo Line-In (Light blue) and Mic-In (Pink)
  o For 6-channel mode; Front stereo-out (Lime), Rear stereo-out (Light blue), Center and          Sub-woofer (Pink)
  o For 8-channel mode; stereo Line-In (Light blue), Mic-In (Pink), Front Stereo-out (Lime), Rear stereo-out (Black), Center and Sub-woofer (Orange) and Side stereo-out (Gray)
* Support Front panel audio for Mic-In and stereo Line-Out only. (Front panel Line-out electrically shared with rear panel Line-out).
* Support Auto Jack Sensing for fool-proof audio device installation
* Coaxial S/PDIF-out available on rear panel
* Optical output available on rear panel
LAN
* 1Gb Ethernet from onboard Cicada CIS8201 Gigabit Ethernet PHY
* Embedded Nvidia Firewall with Active Armor (SNE)
BIOS
* 4MB Flash EEPROM with Award Plug&Play BIOS
* Support ACPI S3 (Suspend To RAM) mode in ACPI compliant O/S
* Support EZ Boot for fast bootable device selection
* Support Magic Health for system hardware status report during system boot-up
* Award Plug&Play BIOS
Special Features
* Onboard Post-Port LED display
* KBPO (Keyboard Power On)
* Wake-On-LAN
* Supports USB resume in S3
* Asynchronous clocking mode between FSB PCI/PCI-E
* Support CPU over heat protection
* Piston V, True 5 individual phase switching power design for cooler PWM and extreme stability
* onboard Ledion Led system to show the status of important system components
* EZ Button, power and reset button onboard for easy setup and debugging
* Support CPU, Chassis and Power FAN speed control
* This Board supports nVidia's nTune™ tweak tuning utility
* Post-Port LED Temperature functionality after POST
Power BIOS
* Support Asynchronous clocking mode between FSB and AGP/PCI
* Programmable FSB and PCI Clock output frequency with 1MHz fine tuning
* Support BIOS adjustable CPU multiplier & Core voltage, FSB clock, PCI-E x16 voltage & clock, Chipset voltage, DIMM frequency and voltage settings
* USDM (Unified System Diagnostic Manager) for system hardware monitoring
* Magic Flash for BIOS update without requiring a DOS Flash utility and/or bootable diskettes
* Magic Screen for personal bootup screen design
Accessoires
* - Power Pack containing:
   o Mini heatsinks (8pcs)
   o Screwdriver
   o Thermo stick
   o Powerpack guide
* USB bracket
* Game + COM2 bracket
* IEEE1394 x2 ports bracket
* SP-ATA Kit (S-ATA to IDE drive converter)
* 1x IDE Round cable
* 1x FDD Flat cable
* 2x SATA data + power
* Manual (EN)
* Jumper settings leaflet (color)
* Driver CD with bundled software and utilities EPOX casebadge sticker
* I/O SHIELD
Form Factor
* 305mm x 245mm x 40mm, ATX Size
Bundle:
Version Ultra
http://www.hardocp.com/images/articles/1110947296JRtuA4xYEq_1_3_l.jpg
http://www.hardocp.com/images/articles/1110947296JRtuA4xYEq_1_4_l.jpg
Version SLI
http://www.ocworkbench.com/2005/epox/9npa+sli/Picture%203257%20copy.jpghttp://www.ocworkbench.com/2005/epox/9npa+sli/Picture%203256%20copy.jpg
Sites Officiels:
Epox Europe: http://www.epox-europe.com/
EP série: http://www.epox-europe.com/product [...] _type_id=2
Bios: http://www.epox-europe.com/downloa [...] uct_id=271
Drivers: http://www.epox-europe.com/downloa [...] uct_id=271
           http://www.epox-europe.com/downloa [...] uct_id=297
Nvidia: http://www.nvidia.com/content/drivers/drivers.asp
Tests:
EP 9NPA+Ultra
http://www.hardocp.com/article.html?art=NzQ4
http://www.xbitlabs.com/articles/m [...] -9npa.html
http://www.clubic.com/article-1838 [...] rce-4.html
http://www.syndrome-oc.net/article [...] =59&page=1
http://www.thecrucible.ca/reviews/9npa/index.php
http://www.tomshardware.fr/article [...] &NumPage=8
http://www.anandtech.com/mb/showdoc.aspx?i=2465
EP 9NPA+SLI
http://www.tbreak.com/reviews/article.php?id=362
http://www.ocworkbench.com/2005/epox/9npa+sli/g1.htm
http://www.tomshardware.fr/article [...] &NumPage=7
Forums
http://www.nokytech.net/forum/show [...] ge=1&pp=15
http://www.xtremesystems.org/forum [...] hp?t=49475
Problèmes & Remarques
Message édité par rlote le 08-07-2005 à 09:55:04
Marsh Posté le 11-04-2005 à 23:04:52
Quelques Images:
http://www.cdrinfo.com/Sections/Articles/Sources/CeBIT_2005/Images/Epox/IMG_1216.jpg
EPOX 9NPA+Ultra
http://www.syndrome-oc.net/img/articles/9npaultra/boite.jpg
http://www.syndrome-oc.net/img/articles/9npaultra/led1b.jpg
http://img186.echo.cx/img186/3904/picture20248920copy6ww.jpg
EPOX 9NPA+SLI
http://www.tbreak.com/reviews/imageview.php?image=9384http://www.tbreak.com/reviews/imageview.php?image=9383
http://www.tbreak.com/reviews/imageview.php?image=9382
http://www.cdrinfo.com/Sections/Articles/Sources/CeBIT_2005/Images/Epox/Original%20Files/IMG_1202.JPG
Message édité par rlote le 09-05-2005 à 16:22:46
Marsh Posté le 12-04-2005 à 18:20:00
OVERCLOCKING & BENCHMARCK
BIOS
L'Epox propose un Bios complet pour l'Overclocking, notamment au niveau des tensions.
FSB: 200 à 400
Vcore: jusquà +0.35V
Vddr: jusqu'à 3.1v
Vchipset: 1.5v à 1.8v
Les régalges des timings ram sont très complet.
Le Bios :
http://img158.echo.cx/img158/5008/bios15yj.th.jpghttp://img209.echo.cx/img209/1730/az5ni.th.pnghttp://img108.echo.cx/img108/9166/as5sb.th.png
HT à 476
http://img186.echo.cx/img186/8703/9npa476812xs.th.gif
Message édité par rlote le 09-05-2005 à 16:33:06
Marsh Posté le 14-04-2005 à 10:14:36
Suite aux nombreux problèmes rencontrés avec la Gigabyte GA-K8NF9, je voulais passer à la DFI UltraD :love: , mais n'étant pas dispo, le vendeur me conseille l'Epox, en mettant le point sur la stabilité et les bonnes prestations à L'OC, ne pouvant attendre pour la DFI, je me suis laissé tenté par l'Epox.
Après quelques jours d'utilisation, je dois dire que je ne suis pas déçu de mon choix, stabilité exemplaire, bonne en OC, bref c'est du tout bon ...
Ma Config:
Boitier CoolerMaster Centurion 5
Hiper 480W typeR red
Epox 9NPA+Ultra
AMD Athlon 64 3500+ 0.13u + CoolerMaster Hyper48
Geil Ultra Platinum PC 4400
Point Of View 6600 GT + Zalman VF700Cu
Maxtor Sata 160Go 8mo + Maxtor Sata 300go 16mo
Graveur DVD Pioneer 107D
Lecteur DVD LG
Rhéobus CoolerMatser Aérogate 4
Mes Scores:
http://img211.echo.cx/img211/4158/sanstitre2kc.th.pnghttp://img115.echo.cx/img115/1946/verest4wo2vp.th.jpghttp://img156.echo.cx/img156/8810/3dmark20033xw.th.jpghttp://img59.echo.cx/img59/4193/3dmark20058xg.th.jpg
Message édité par rlote le 08-07-2005 à 09:57:26
Marsh Posté le 15-04-2005 à 22:27:23
elle gere trop c'te mobo! :love:
Mais comment je deteste le vert!
mon feedback : http://forum.hardware.fr/hfr/Achat [...] 3802_1.htm
Marsh Posté le 16-04-2005 à 03:22:39
tu peux essayer de trouver le fsb max avec un coeef de 5x?
desynchro 100
Message édité par darknico le 16-04-2005 à 03:33:33
Marsh Posté le 16-04-2005 à 09:43:30
je la trouve pas si buggées que ca la K8NF-9
chez moi, tout fonctionne nickel (à part les sondes) et coté o/c y'a pas de souci
A 64 3200 Winchester 2000Mhz @ 2550Mhz
FSB 255 * 10
DDR 166 à 209Mhz
1T
trés stable ( 2h Torture OCCT et 2h Prime95 sans soucis, Test OCCT : OK )
CPUmark : 295
SuperPi 1M : 31secondes
3Dmark 2003 : 9430
3Dmark 2005 : 4121
Mais c'est vrai qu'elle à l'air bien comme CM
j'ai jamais essayé EPOX
Marsh Posté le 16-04-2005 à 12:35:34
La gigabyte je crois que c'est toi et ta chance, j'en ai eu 3 en tout, la 1ere était nickel(1ere série), les 2 autres laisse tomber, et si tu regardes bien sur le topic de la gigabyte, tous ceux comme moi qui l'avait acheté au début l'ont abandonné par la suite....
darknico: ok je test ça, mais je pense pas que le test sur ma config soit tres fiable...
Moi j'OC toujours synchro pour de meilleures perf
Message édité par rlote le 16-04-2005 à 12:36:48
Marsh Posté le 16-04-2005 à 20:07:15
ouep mais ta des tccds c pour sa
c pour savoir se que sa vaut par rapport a la dfi
merci bien
Marsh Posté le 16-04-2005 à 22:06:40
J'ai pas de TCCD mais des TCCC, si c'était des TCCD j'aurai pu monter beaucoup plus haut ;)
Pour la comparaison avec la DFI, je ne sais pas, c'est trop tôt pour comparer mais c'est clair que la DFI est une référence et a des options plus poussé pour l'OC, exemple le voltage de la ram que tu peux monter à 4volts contre 3.1v pour l'Epox
Message édité par rlote le 28-04-2005 à 20:41:39
Marsh Posté le 16-04-2005 à 22:47:10
Pour la comparaison avec la DFI, je ne sais pas, c'est trop tôt pour comparer mais c'est clair que la DFI est une référence et a des options plus poussé pour l'OC, exemple le voltage de la ram que tu peux monter à 4volts contre 3.1v pouyr l'Epox
oui je sais
masi j aimerais savoir si sa boot au max bios sur l epox comme sur la dfi
Marsh Posté le 17-04-2005 à 17:48:47
tu peux nous dire quel est le vcore par default
certain avait des probleme a ce niveau
Marsh Posté le 17-04-2005 à 22:44:52
Pour la ram 2.5v
Marsh Posté le 17-04-2005 à 23:16:14
le vcore pas le vddr ;)
vcore>>cpu
Marsh Posté le 17-04-2005 à 23:30:17
lol je sais mais je viens juste de remarquer que j'avais une barette completement foireuse avec 90 000 erreurs sous memtest :ouch:, je suis trop deg
2.5v le cpu
Message édité par rlote le 17-04-2005 à 23:30:42
Marsh Posté le 18-04-2005 à 01:08:42
2.5v le cpu
sa fait beaucoup 2.5v sur le cpu
1.5v? :D
Marsh Posté le 18-04-2005 à 01:09:12
1.5v? :D
ah ue ta un  0.13 normal donc
Marsh Posté le 20-04-2005 à 01:39:28
:o  :pfff:  :pt1cable:Décidement je suis vraiment largué en ce moment, mon pb de ram m'a vraiment retourné le cerveau
Bon c'est bien 1.5v pour un athlon 3500+ 0.13u
2.5v la ram
1.5v le Chipset
Je viens de passer commande, pour des Geil Ultra Platinum PC4500 550mhz QUI SUPPORTE 3.1V comme la mobo, j'espère que j'ai fais le bon choix, restera que l'alim... j'espère qu'elle tiendra le coup  ;)
Bon j'ai commencé à essayer de booter au FSB max, j'ai mis 400 (max de la mobo) 100 pour la ram et HT x2, mais elle a pas voulu booter, je n'ai pas eu le temps de faire d'autres tests...
Par contre j'ai besoin d'un petit renseignement, je boot facile à 2,64 Ghz pour le proco, j'aimerai passer à 2.7Ghz, le problème c'est que j'ai poussé le Vcore à 1.625v et que sa plante au chargement de windows, la question: est ce que c'est risqué d'augmenter encore le voltage????
Message édité par rlote le 28-04-2005 à 21:05:46
Marsh Posté le 20-04-2005 à 01:45:22
2.7v la ram
1.5v le Chipset
quel cooling?
pas en air c pas conseille
Message édité par darknico le 20-04-2005 à 02:36:40
Marsh Posté le 20-04-2005 à 11:47:32
Hyper 48, et comme j'en vois beaucoup qui sont à 1.7v en aircooling, je me posais la question ???
Marsh Posté le 20-04-2005 à 13:42:32
sa chauffe vraiment aussi a 1.7v
rien que de passer de 1.4 a 1.5 je vois bien la diffde temp chez moi
Marsh Posté le 20-04-2005 à 14:34:09
Je viens de voir ta config là, tu tournes avec quoi exactement en ce moment avec ton 3000+.
Apparement mes Geil pc 4400 sont partis elles devraient pas tarder, j'ai hate de leur mettre un petit 3.1v dans la tronche :D
Marsh Posté le 23-04-2005 à 17:55:12
rad box
watercooling
bon j ai la mienne vcore default 1.47v :cry:   :heink:
la cm est stable a 390 de fsb sans probleme sa boot plus apres
mais sa doit monter sous windows
Marsh Posté le 27-04-2005 à 08:00:31
Bonne idée que ce topic unique sur cette merveilleuse carte mére  ;)
Marsh Posté le 27-04-2005 à 11:51:34
Oui, mais il n'y a pas beaucoup d'utilisateurs apparement sur ce forum, contrairement au topic sur Nokytech....
Sur clubic, il y a un test de plusieurs carte mère Nforce4, avec entre autre l'Epox et la DFI, et quand on lit ce test, ya rien à dire, c'est vraiment pathétique, je sais pas qui rédige ces tests et d'où proviennent les mobos mais on a vraiment l'impression qu'ils testent des modèles différents de ce que l'on trouve dans le commerce ou alors c'est vlà les poisseux qui tombent toujours sur des cartes déféctueuses (cf: 225 max FSB)font pitié grave :pfff:
Ou bien l'Epox qui est instable, il y a bien un souci avec le 1T mais à hautes fréquences surement pas à 220.... :o La carte est reconnue pour être une référence en stabilité...
Bref clubic sa part en c......, et y en a qui commence à le dire sur le forum du site...
Message édité par rlote le 27-04-2005 à 14:18:58
Marsh Posté le 28-04-2005 à 06:50:31
non mais ils sont pas doue en overcloking c connu mais ils font rien pour remedier a sa.................
genre la dfi qui depasse pas 210 de fsb  :lol:
220 l epox mdr je tape les 450 par clockgen :lol:
Marsh Posté le 23-05-2005 à 14:58:16
Un nouveau test chez Hardware.fr
http://www.tomshardware.fr/article [...] &NumPage=1
Message édité par rlote le 23-05-2005 à 18:53:50
Marsh Posté le 28-05-2005 à 23:33:21
Si quelqu'un a réussi a monter un raid 0 ou 1 avec le port ide, qu'il me fasse signe, car ici impossible .
Marsh Posté le 30-05-2005 à 01:13:45
Tu utilises quoi pour monter ton Raid ??
Nouveau Bios Beta estampillé 5525:
http://www.lejabeach.com/Epox/9npa [...] ubios.html
Message édité par rlote le 30-05-2005 à 01:25:22
Marsh Posté le 08-06-2005 à 18:18:38
Nouveau test de l'Epox 9NPA+SLi chez Tom's Hardware
Marsh Posté le 09-06-2005 à 12:06:09
la mobos boot as fsb 300 , +0.175 , , htt x3 , mais écran blue sous win
le chipset faut le mettre à quel voltage, j'ai mis mes réglages tccd DFI sa marche pas  :cry:
Marsh Posté le 09-06-2005 à 12:12:01
Salut Kenshiro  :D
T'as pensé que t'allais avoir plus de renseignements ici que sur Nocky t'as rêvé toi  :D
Comme j'ai dis le max de mon cpu c'est 2.5ghz stable, il boot jusqu'à 2.65ghz environ, mais j'ai pas réussi à taper plus de 260 synchro après je crois que mes rams ne suivent plus c'est des Geils Pc 4400, enfin peut être qu'un new bios nous aidera on verra bien  :ange:
Message édité par rlote le 09-06-2005 à 12:20:38
Marsh Posté le 09-06-2005 à 12:19:36
arf pourtant dans les screens elles montent à + de fsb 300  :cry:
Message édité par seiyar le 28-06-2005 à 08:56:57
Marsh Posté le 09-06-2005 à 12:20:03
rlote a écrit :
Salut Kenshiro  :D
grilled
Marsh Posté le 09-06-2005 à 12:21:43
:D
j'ai booter une fois à 278 fsb mais timing ram 3/6/6/11 laisse tomber
Message édité par rlote le 09-06-2005 à 12:22:32
Marsh Posté le 17-06-2005 à 21:46:38
pas de succés ce tomic :D
Marsh Posté le 18-06-2005 à 17:01:31
On va lui en redonner t'inquiètes pas  :D
Donc hier un ami à moi est venu avec ses A-data Vitesta 4800 pour une petite batterie de tests.
Donc tout ce que je peux dire c'est que sa à rien à voir avec mes geils, ces barettes sont :love:
j'ai taper 280 synchro en 2.5/3/3/6 1T donc pas de souci réel haut FSB et 1T, puis je suis passé à 290 synchro en 2.5/3/3/6 1T mais mon proco ne suivait plus, il tournait à 2.61ghz avec un coeff 9 vu qu'en X8 il veut rien savoir. La bande passante sur everest dépassait les 8000 mo en lecture  :)
J'ai pas pu screener sauf à 280 en 2.5/4/4/8 1T, pas eu beaucoup de temps hier soir  :??:
http://img273.echo.cx/img273/7039/adata1pq.jpg
Message édité par rlote le 18-06-2005 à 17:03:18
Marsh Posté le 28-06-2005 à 08:57:27
sa roxxxxx :love:
Marsh Posté le 29-06-2005 à 00:27:52
Dis toi j'ai fais plus de 8000mo à 290 synchro en 1T :love:
Marsh Posté le 06-07-2005 à 20:10:45
Voir le nouveau roundup de cartes mères sur anadtech.com
L'Epox arrive 1ère à égalité avec la DFI.
J'étais surpris de voir que l'Epox a 3 ans de garantie chez TopAchat. C'est une erreur, vous croyez ?
