ASUS CROSSHAIR V, SABERTOOTH, 990FX, AM3+, SLI [Topic Unique] - Carte mère - Hardware
Marsh Posté le 11-05-2011 à 20:55:26
        Firmware, Reading & Stuff :
#=> MotherBoard's Firmware Listing :
BIOS_CROSSHAIR_V_Formula-Z :
#> Firmware v2.201, Size 3,31Mb ; Release date 07/05/14
 1. Enhance compatibility with some USB device.
#> Firmware v2.101, Size 3,31Mb ; Release date 22/05/14
#> Firmware v2.002, Size 3,31Mb ; Release date 19/03/14
 1. Improve system stability.
#> Firmware v1.901, Size 3,31Mb ; Release date 24/01/14
#> Firmware v1.801, Size 3,3Mb ; Release date 19/12/13
 1. Fixed Intel LAN cannot be disabled.
#> Firmware v1.701, Size 3,3Mb ; Release date 28/11/13
#> Firmware v1.602, Size 3,3Mb ; Release date 16/10/13
#> Firmware v1.503, Size 3,31Mb ; Release date 01/08/13
 1. Fixed 'Power On By RTC' function failed.
#> Firmware v1.403, Size 3,3Mb ; Release date 10/05/13
 1. Fix HDD (+1TB) 'read error' under winXP on IDE mode.
#> Firmware v1.302, Size 3,25Mb ; Release date 31/01/13
 1. Fixed 'F8' function is abnormal under fastboot.
#> Firmware v1.201, Size 3,24Mb ; Release date 9/01/13
#> Firmware v1.101, Size 3,24Mb ; Release date 7/12/12
#> Firmware v1.002, Size 3,25Mb ; Release date 14/11/12
#> Firmware v0.901, Size 3,25Mb ; Release date 5/11/12
 1. Improve system stability ;
 2. Support new CPUs. Click Here.
#> Firmware v0.704, Size 3,23Mb ; Release date 29/09/12
#> Firmware Betâ v0.508b, Size 3,22Mb ; Release date 09/08/12
 1. Improve compatibility with Windows 8 OS ;
 2. Improve system stability ;
 3. Improve memory compatibility ;
 4. Enhance compatibility with some USB devices ;
 5. Fixed Nvidia GTX 680 hang when runing with UEFI driver.
#> Firmware v0.401, Size 3,16Mb ; Release date 01/08/12
#> Firmware v0.225, Size 3,15Mb ; Release date 01/08/12
 1. First released Bios.
_______________________________________________
BIOS_CROSSHAIR_V_Formula (& Thunderbolt Formula) :   [END OF BIOS RELEASE : 01/01/13]
#> Firmware v1.703, Size 2,43Mb ; Release date 24/10/12
#> Firmware v1.605, Size 2,42Mb ; Release date 11/10/12
 2. Enhance compatibility with some USB devices.
#> Firmware v1.503, Size 2,42Mb ; Release date 20/07/12
#> Firmware v1.402, Size 2,41Mb ; Release date 25/05/12
#> Firmware v1.301, Size 2,41Mb ; Release date 28/03/12
#> Firmware v1.102, Size 2,40Mb ; Release date 11/01/12
#> Firmware v1.003, Size 2,40Mb ; Release date 09/12/11
 1. Improve memory compatibility ;
 2. Improve system stability.
#> Firmware v0.903, Size 2,40Mb ; Release date 07/11/11
 3. Update CPU Level up function.
#> Firmware v0.813, Size 2,39Mb ; Release date 07/10/11
 1. Support some new CPUs.
#> Firmware v0.705, Size 2,39Mb ; Release date 07/09/11
 3. Fix USB 7/8 not work issue ;
 4. Fix system may hang when use with Adaptec ASR-5805 Raid card ;
 5. Add Spanish and Russian to BIOS setup ;
 6. Support some new CPUs.
#> Firmware v0.506, Size 2,14Mb ; Release date 02/07/11
 1. Improve system stability w/ some Fix & Correction.
#> Firmware v0.404, Size 2,14Mb ; Release date 07/06/11
BIOS_SABERTOOTH_990FX_v3 :
#> Firmware v2.501, Size 3,19Mb ; Release date 09/05/14
#> Firmware v2.301, Size 3,18Mb ; Release date 27/13/14
#> Firmware v2.103, Size 3,18Mb ; Release date 21/11/13
[#> Firmware v2.005, Size 3,18Mb ; Release date 16/10/13
#> Firmware v1.903, Size 3,19Mb ; Release date 01/08/13
#> Firmware v1.802, Size 3,12Mb ; Release date 28/05/13
 1. Improve system compatibility ;
 2. Fix HDD (+1TB) 'read error' under winXP, on IDE mode ;
 3. Support new CPUs. Click Here.
#> Firmware v0.305, Size 3,12Mb ; Release date 28/01/13
 1. Enhance compatibility with some USB devices.
#> Firmware v0.226, Size 3,12Mb ; Release date 10/12/12
BIOS_SABERTOOTH_990FX_v2 :
#> Firmware v2.501, Size 3,19Mb ; Release date 14/05/14
#> Firmware v2.301, Size 3,18Mb ; Release date 27/03/14
#> Firmware v2.104, Size 3,18Mb ; Release date 11/12/13
#> Firmware v2.103, Size 3,19Mb ; Release date 21/11/13
 1. Support new CPUs. Click Here.
#> Firmware v1.708, Size 3,18Mb ; Release date 10/05/13
 1. Fix HDD (+1TB) 'read error' under winXP, on IDE mode.
#> Firmware v1.503, Size 3,12Mb ; Release date 31/01/13
#> Firmware v1.302, Size 3,11Mb ; Release date 7/12/12
#> Firmware v1.201, Size 3,09Mb ; Release date 22/10/12
#> Firmware v1.101, Size 3,09Mb ; Release date 6/11/12
#> Firmware v0.906, Size 3,06Mb ; Release date 25/09/12
#> Firmware v0.802, Size 3,07Mb ; Release date 20/08/12
 1. Improve compatibility with Windows 8 ;
#> Firmware v0.707, Size 3,07Mb ; Release date 07/08/12
 3. Improve memory compatibility.
#> Firmware v0.601, Size 3,03Mb ; Release date 27/07/12
#> Firmware v0.304, Size 3,02Mb ; Release date 20/07/12
#> Firmware v0.219, Size 3,01Mb ; Release date 25/06/12
BIOS_SABERTOOTH_990FX :   [END OF BIOS RELEASE : 01/01/13]
#> Firmware v1.604, Size 2,35Mb ; Release date 24/10/12
 2. Support new CPUs, Click Here.
#> Firmware v1.503, Size 2,34Mb ; Release date 10/10/12
#> Firmware v1.304, Size 2,33Mb ; Release date 20/07/12
#> Firmware v1.208, Size 2,33Mb ; Release date 29/05/12
#> Firmware v1.102, Size 2,33Mb ; Release date 28/03/12
 2. Enhance compatibility with some USB devices ;
 3. Patch system hanged when use AM3 1090T or 1100T CPU.
#> Firmware v0.901, Size 2,32Mb ; Release date 14/12/11
#> Firmware v0.813, Size 2,32Mb ; Release date 17/11/11
#> Firmware v0.810b, Size 2,31Mb ; Release date 11/10/11
 1. Update AMD CPU AGESA Firmware.
#> Firmware v0.705, Size 2,31Mb ; Release date 16/09/11
 1. Enable support for Spanish and Russian Language ;
 2. Enable support for UEFI RAID Driver to support RAID partition above 2.2TB ;
 3. Enhance RAID0 performance with SB950 native SATA ports ;
 4. Enhance RAID expansion card compatibility.
#> Firmware v0.402, Size 2,07Mb ; Release date 07/06/11
BIOS M5A99FX Pro :
#> Firmware v2.501, Size 3,14Mb ; Release date 14/05/14
#> Firmware v2.301, Size 3,13Mb ; Release date 27/03/14
#> Firmware v2.201, Size 3,13Mb ; Release date 19/12//13
 1. Support new CPUs, Click Here.
#> Firmware v2.005, Size 3,13Mb ; Release date 16/10/13
#> Firmware v1.903, Size 3,14Mb ; Release date 01/08/13
#> Firmware v1.708, Size 3,13Mb ; Release date 14/05/13
#> Firmware v1.503, Size 3,08Mb ; Release date 31/01/13
 1. Fix 'F8' function is abnormal under fastboot.
#> Firmware v1.302, Size 3,07Mb ; Release date 07/12/12
#> Firmware v1.201, Size 3,06Mb ; Release date 13/11/12
#> Firmware v1.101, Size 3,06Mb ; Release date 02/11/12
#> Firmware v0.906, Size 3,03Mb ; Release date 25/09/12
#> Firmware v0.803, Size 3,05Mb ; Release date 20/08/12
#> Firmware v0.707, Size 3,05Mb ; Release date 07/08/12
 2. Improve memory compatibility ;
 3. Improve system stability.
#> Firmware v0.601, Size 3,04Mb ; Release date 27/07/12
 1. Enhance compatibility with some USB devices ;
 2. Fixed GTX 680 hang when runing with UEFI driver ;
#> Firmware v0.507, Size 3,03Mb ; Release date 27/06/12
#> Firmware v0.403, Size 3,02Mb ; Release date 29/05/12
#> Firmware v0.311, Size 3,02Mb ; Release date 22/05/12
#=> MotherBoard's Reading Stuff :
Reading For CROSSHAIR V Formula-Z :
#> French Complete User's Manual v7.71, Size 13,2Mb ; Release date 22/11/12
Reading For CROSSHAIR V Formula :
#> French Complete User's Manual v6.522, Size 11,68Mb ; Release date 04/07/11
Reading For SABERTOOTH 990FX v3 :
#> English Complete User's Manual v8.041, Size 12,04Mb ; Release date 16/01/13
Reading For SABERTOOTH 990FX v2 :
#> French Quick Start Guide v7.667, Size 658,59Kb ; Release date 01/11/12
#> French Complete User's Manual v7.335, Size 6,49Mb ; Release date 09/08/12
Reading For SABERTOOTH 990FX :
#> European Quick Start Guide v6.401, Size 1,57Mb ; Release date 15/07/11
#> French Complete User's Manual v6.401, Size 6,84Mb ; Release date 12/07/11
Reading For M5A99FX Pro :
#> French Complete User's Manual v7.383, Size 14,77Mb ; Release date 09/08/12
Marsh Posté le 11-05-2011 à 22:40:53
La Galerie Photo ROG :
_____________________________________________________________________________________________________________________________
Marsh Posté le 11-05-2011 à 23:33:32
La Galerie Photos TUF :
Marsh Posté le 12-05-2011 à 00:06:53
Le déballage en Photo :
Marsh Posté le 12-05-2011 à 00:17:16
First, drapal et iwh.
Me botte bien la V formula... Et la mAtx pour ma copine ![]()
Marsh Posté le 12-05-2011 à 00:19:44
j'hésite à mettre à titre provisoire ou permanent au choix, la M5A99X dans le listing, qu'en pensez vous ?... pas rog mais SLI quoi ![[:gratgrat] [:gratgrat]](https://forum-images.hardware.fr/images/perso/gratgrat.gif)
bon là .. Faut que j'y aille ![]()
Marsh Posté le 12-05-2011 à 00:24:54
| NoradII a écrit : Ce "TOPIC UNIQUE" servira de base à tout renseignements, aides, BIOS, Questions/réponses et BDD d'overclock sur ces Carte-mère, Que seront les ASUS ROG Crosshair V et leur condisciple la TUF SaberTooth.  |
Quelle motivation
| NoradII a écrit : Réservation !!! Ceci est une réservation la mise en page alpha interviendra dans les 15 jours qui viennent   |
On réserve alors
| NoradII a écrit : Prière d'attendre 0h00 ce soir, avant tout POST ou QUOTE  |
C'est bon maintenant
| NoradII a écrit : merci  |
 ![[:anonymouse] [:anonymouse]](https://forum-images.hardware.fr/images/perso/anonymouse.gif)
| NoradII a écrit : j'hésite à mettre à titre provisoire ou permanent au choix, la M5A99X dans le listing, qu'en pensez vous ?... pas rog mais SLI quoi   |
"Les ASUS ROG & la SaberTooth AM3+" devrait suffire
Les gens trouveront bien le détail tous seuls ![]()
| Spoiler : en lisant tes Posts   |
Marsh Posté le 12-05-2011 à 00:26:56
on change pas une équipe qui gagne, niveau post
mais arrête de poster que je me pieute, st'eup' a chaque fois j'ai envie de répondre
désolé ... trop fatigué.. dit n'imp' ![]()
Marsh Posté le 12-05-2011 à 08:28:29
j'drapal et je plussoie pour la M5A99X, elle devrait être bien vu mon budget, à moins que la sabertooth soit à moins de 150€ ![]()
Marsh Posté le 12-05-2011 à 08:54:41
La M5A99X c'est du 990X par contre, faudra éditer le titre...
Marsh Posté le 12-05-2011 à 09:50:02
faut ajouter ça:
Marsh Posté le 14-05-2011 à 02:45:10
ben quoi ![[:zaipetruredfadeiping] [:zaipetruredfadeiping]](https://forum-images.hardware.fr/images/perso/zaipetruredfadeiping.gif)
| guigs23 a écrit : faut ajouter ça:   |
oui ça arrive, mais bon p'têt pas en 17" l'image quand même ![]()
Marsh Posté le 14-05-2011 à 12:11:49
Non non, mais c'était pour avoir l'original j'éditerais mon post quand tu auras mis à jour le topic.
Marsh Posté le 14-05-2011 à 13:02:46
| guigs23 a écrit : Non non, mais c'était pour avoir l'original j'éditerais mon post quand tu auras mis à jour le topic.  |
ok c'est partis ![]()
Marsh Posté le 19-05-2011 à 10:19:39
http://www.republic-of-gamers.fr/F [...] Sabertooth
Marsh Posté le 22-05-2011 à 18:42:29
un soucis sur le Topic m'oblige à retarder la création du first post.
le fait est que je ne suis pas satisfait de cet Alpha en release ![[:o_doc] [:o_doc]](https://forum-images.hardware.fr/images/perso/o_doc.gif)
Marsh Posté le 22-05-2011 à 18:46:35
Prends le temps nécessaire
Ça presse pas
Marsh Posté le 22-05-2011 à 20:23:11
Bon, il arrive ce fp ? Nan mais c'pas possible, NORADII, t'en branle pas une ![]()
Marsh Posté le 22-05-2011 à 22:43:38
| l0g4n a écrit : Bon, il arrive ce fp ? Nan mais c'pas possible, NORADII, t'en branle pas une   |
 Arf, Ou pas en fait..
Marsh Posté le 22-05-2011 à 22:46:57
| NoradII a écrit :    |
Mais je te taquine ![]()
Marsh Posté le 22-05-2011 à 22:47:27
ReplyMarsh Posté le 22-05-2011 à 23:57:36
qui taquine qui taquine qui ![]()
Marsh Posté le 23-05-2011 à 20:23:41
ReplyMarsh Posté le 24-05-2011 à 16:49:01
Y a des grosses différences entre les Digi+ VRM de la Sabertooth et l'Extreme Engine Digi Vrm de la CVF ou bien ça reste un argument marketing ?
Je préfère les couleurs de la sabertooth et les fonctionnalités de la CVF, dommage qu'il y ait pas de série workstation qui aurait réuni le meilleur des mondes
 , mais c'est déjà un joli line-up de lancement.
Marsh Posté le 24-05-2011 à 18:44:47
je viens de jeter un oeil sur le site asus
ça y est la sabertooth entre autre est référencé sur les link de download (menu déroulant dans section mobo du support)
la section est vide pour le moment, mais en gros quand il commence à mettre ça en place, dans les 3 semaines qui suivent en général t'arrive à pécho le matos en boutique
le bulldo est ptet pas là, mais mi juin devrait y avoir la sabertooth dans le desktop avec mon actuel phenom II  ![]()
Marsh Posté le 25-05-2011 à 13:26:47
bon NORADII tu es ou?
Marsh Posté le 25-05-2011 à 13:42:46
je crée des images pour le first post, comme dit plus haut, j'ai fait un essai avec les images trouvées plus haut, mais sans convenance, donc ça arrive
Marsh Posté le 25-05-2011 à 13:50:20
ReplyMarsh Posté le 25-05-2011 à 13:53:25
je fait en sorte de ne pas (trop
 ) décevoir aussi
Marsh Posté le 11-05-2011 à 20:54:38
BIENVENUE À TOUS SUR CE TOPIC UNIQUE DU HAUT DE GAMME AM3+ D'ASUS !
Intro :
Ici prends place : consommables, descriptifs, photos, retours, reviews et suivit des MàJ des produits HDG ASUS 990FX, ROG et TUF.
Les descriptifs et évolutions :
=> Différence avec la CROSSHAIR V Formula :
+ DDR3-2400 (OC)
+ Quad-SLI technology
+ 1x PCIe X1
+ 1x sATA-III
+ 1x e-sATA-III
+ SupremeFX III
+ 2 Phases for Memory
+ VRM Digi+ II
+ 1x "ROG Connect" switch (BackPlate)
+ 1x TPM connector
+ 1x sATA-III
+ 1x DirectKey Button
+ 1x DRCT header
+ ASUS "CrashFree BIOS" 3
+ ASUS EPU
+ ASUS Q-Code
+ ASUS Q-DIMM
+ ASUS Q-Shield
+ ASUS Q-Slot
+ AI Suite II
+ Disk Unlocker
+ USB 3.0 Boost
+ 64Mb Flash ROM
+ GameFirst II
+ ASUS WebStorage
- x1 PCIe card Intel Gigabit LAN & SPDIF (Since CVF w/ ThunderBolt)
- 1x PCI
- SupremeFX X-Fi 2
- Voltiminder LED
- CPU Level Up
- Core Unlocker
- ClrCMOS header
- "CPU Level Up" button
+ x1 PCIe card Intel Gigabit LAN & SPDIF
=> Différence avec la SABERTOOTH 990FX :
+ 3x PCIe 3.0 x16 (16/16 or 16/8/8) (since TUF V2)
+ ASMedia® sATA controller
* 2x sATA-III
* 2x e-sATA-III
+ ASMedia® USB3 controller
* 4x USB3 BackPlate
+ Realtek® 8111F GbLan
+ 2x USB3 (BackPlate)
+ 2x e-sATA-III (BackPlate)
+ 1x USB BIOS Flashback Button (BackPlate)
+ 1x TPM connector
+ 2x sATA-III
+ 1x CPU OPT PWM Fan connector
+ 1x Chassis PWM Fan connector
+ 1x DRCT header
+ ASUS DIGI+ Power Control Utility
+ Remote GO!
+ USB BIOS Flashback
+ Ai Charger+
+ Network iControl
+ USB 3.0 Boost
+ DirectKey
+ 64Mb Flash ROM
+ SLP v2.1
+ SM BIOS v2.7
+ F12 PrintScreen,
+ F3 Shortcut Function
+ ASUS DRAM SPD memory information
- 1x PCIe 2.0 x1 (since TUF V2)
- JMicron® sATA controller
* 2x sATA-II
* 1x e-sATA-II (BackPlate)
* 1x Power e-sATA-II (BackPlate)
- VIA® FireWire controller
* 2x IEEE_1394a
- ASUS Dual Processors DIGI+ VRM
- ASUS DIGI+ VRM Utility
- 2x USB2 (BackPlate)
- 1x Optional PWM Fan connector
* 2x sATA-III
* 2x e-sATA-III
* 4x USB3 BackPlate
+ 1x TPM connector
+ 2x sATA-III
+ 1x DRCT header
+ Remote GO!
+ Ai Charger+
+ Network iControl
+ USB 3.0 Boost
+ DirectKey
+ 64Mb Flash ROM
+ SLP v2.1
+ SM BIOS v2.7
+ F12 PrintScreen,
* 2x sATA-II
* 2x IEEE_1394a
Reviews CROSSHAIR V Formula :
Awards :
Review SABERTOOTH 990FX :
Awards :
__________________
Review M5A99FX Pro:
Awards :
Rappel sur les "nouveautés" :
/!\ Important /!\ Rappel sur les Compatibilités & Incompatibilités du socket AM3+ /!\ Important /!\
Caractéristiques des Lignes SPP AMD 9x0 :
990FX > 2x (X16) or 4x (X8)
+ 6x (X1)
+ 1x (X4)
990X > 1x (X16) or 2x (X8)
+ 6x (X1)
970 > 1x (X16)
Caractéristiques des Lignes MCP AMD 9x0 :
SB950 > 4x (X1)
+ 14x USB2
+ 6x sATA-III w/ RAID0/1/5/10
+ PCI bus
SB920 > 2x (X1)
+ 14x USB2
+ 6x sATA-III w/ RAID0/1/10
+ PCI bus
- Les présentations faites, Place à vos participation !
Message édité par NoradII le 17-12-2013 à 03:20:10
valid.x86.fr/575505 /842925 /902578
