Comparatif Nec Tn+Film 16ms / Samsung MVA 25ms: surprises !
Comparatif Nec Tn+Film 16ms / Samsung MVA 25ms: surprises ! - Hardware
Marsh Posté le 04-04-2003 à 15:06:44
Les topics que je peux lire ici depuis quelques temps laissent supposer que le meilleur choix actuel en 17' LCD (ou le meilleur compromis) est l'écran 16ms, notamment chez Nec (1701 et 1760).
Hors, en lisant un test très détaillé chez Anandtech ( http://www.anandtech.com/showdoc.html?i=1785&p=5 ) entre l'Hitachi CML174 (même dalle que le Nec) et le Samsung 172T, je suis sacrément refroidi. Voici le tableau comparatif:
Intensity range check
 172T (digital)  5, Looks good
 172T (analog)  5
 CML174 (digital)  4.5, close but slightly too bright
 CML174 (analog)  4.5
Black level adjustment
 172T (digital) 4, Black levels still slightly high
 172T (analog) 4
 CML174 (digital) 3.5, blacks lighter than on the 172T
 CML174 (analog) 3.5
Defocusing, blooming and halos check
 172T (digital) 5, None
 172T (analog) 5
 CML174 (digital) 5, None
 CML174 (analog) 5
Screen uniformity and color purity
 172T (digital) 5, Uniform
 172T (analog) 5
 CML174 (digital) 4, large bright patch present in lower half of screen
 CML174 (analog) 4
Dark screen (Glare Test)
 172T (digital) 4, slight glare
 172T (analog) 4
 CML174 (digital) 4, slight glare
 CML174 (analog) 4
Primary colors
 172T (digital) 4, unscaled hues display fine, but not perfect.
 172T (analog) 5
 CML174 (digital) 3.5, problems with achieving all colors correctly
 CML174 (analog) 4.5
Color Scales
 172T (digital) 3, Still difficulty with reds, although an improvement over the 191T
 172T (analog) 4
 CML174 (digital) 2, severe color inaccuracies, even after recalibration
 CML174 (analog) 3
16 intensity levels
 172T (digital) 4, Good, but not perfect
 172T (analog) 4
 CML174 (digital) 3.5, problems with red
 CML174 (analog) 4
Pincushion/barrel distortion
 172T (analog) 5
 CML174 (analog) 5
Geometric Linearity
 172T (digital) 5, no curvature
 172T (analog) 5
 CML174 (digital) 5, no curvature
 CML174 (analog) 5
Focus check
 172T (digital) 5, Uniform Focus
 172T (analog) 5
 CML174 (digital) 5, Uniform
 CML174 (analog) 5
Horizontal color registration
 172T (digital) 5, Level
 172T (analog) 5
 CML174 (digital) 5, Level
 CML174 (analog) 5
Vertical color registration
 172T (analog) 5
 CML174 (digital) 5, none
 CML174 (analog) 5
Fine line moiré pattern
 172T (analog) 5
 CML174 (analog) 5
Screen regulation
 172T (digital) 5, no problems
 172T (analog) 5
 CML174 (digital) 5
 CML174 (analog) 5
Streaking and ghosting
 172T (digital) 5, none
 172T (analog) 3, streaking present, but expected
 CML174 (analog) 3, similar to 172T
L'Hitachi (ou le Nec) respecte mal les couleurs extrêmes, le noir n'est pas pur, l'angle de vision n'est pas très bon, et la luminosité n'est pas uniforme. La dalle MVA du Samsung ne présente pas (ou peu) ces défauts. J'avais pu me rendre compte en quelques minutes de comparaisaon à la fnac de ces différences entre Tn+Film et MVA, et je trouve dommage qu'on n'en parle plus: si l'on met de côté la rémanence, les dalles MVA sont supérieures aux Tn+Film. Par exemple, je ne pourrais pas supporter que la luminosité ne soit pas uniforme, et que l'on voit des "néons" en bas de l'écran; la dalle 20ms Hyundai/Iiyama est connue pour ça, mais ce défaut n'est pas corrigé sur le Nec/Hitachi.
Reste la rémanence... Je joue de temps en temps à des jeux 3d, et je ne voudrais pas être gêné par la rémanence: n'est-elle réellement pas trop omniprésente sur les dalles MVA Samsung (171 et 172) ?
Message édité par Sister Ray le 04-04-2003 à 15:07:45
Marsh Posté le 04-04-2003 à 15:29:06
c deja perceptible sur le nec alors imagines sur le samsung...
Marsh Posté le 18-04-2003 à 20:12:58
Est ce que quelqu'un a vraiment tester le Samsung 172T et le Nec 1760NX ?
le Nec a un temps de reponse de 16ms et le Samsung <25ms, est ce que pour les jeux ont voit vraiment la difference, car je me doute que c'est un pas tout à fait un vrai 16 chez Nec.
car coté couleur d'apres ce que j'ai vu il n'y a pas photo, c'est le Samsung le meilleur
Certains ont testé des jeux qui bougent beaucoup ( genre UT2003 ) avec ces 2 TFT, est ce que ca gene la remanence ?
( J'hesite entre ces 2 là )
Marsh Posté le 19-04-2003 à 00:01:08
D'après les infos que j'ai pu récupéré à travers les tests et forums, la dalle 16ms (Nec, Hitachi) est plutôt optimiste, et la dalle <25ms du Samsung 172t plutôt pessimiste sur la rémanence réelle de ces écrans.
Donc comme luminosité + angles de vue + uniformité de l'éclairage supérieur sur le Samsung, et bien je dis:
Samsung 172t rules !  :D
La seule chose qui m'empêche de l'acheter, c'est qu'il n'est pas très récent, et que des nouvelles dalles Samsung sortiront d'ici cet été. Si elles demeurent en mva (bien meilleur que le tn+film d'après tout ce que j'ai pu voir), et qu'elles font 15ms, la concurrence n'aura plus qu'à pleurer !  :love:
Message édité par Sister Ray le 19-04-2003 à 00:03:46
Marsh Posté le 19-04-2003 à 11:16:39
Quelqu'un aurait une photo du Samsung 172T MM, c'est la version avec les enceintes, je voudrais voir si elles ne gachent pas son allure
Marsh Posté le 19-04-2003 à 14:39:16
Les enceintes (enfin les ridicules haut-parleurs pour ce que j'en pennse  :heink: ), sont situées sur le le pied (petite grille à gauche et à droite), ce qui est beaucoup plus esthétique que s'ils étaient sur l'écran.
Marsh Posté le 19-04-2003 à 14:45:42
ok Merci
Moi [:tete_de_mort] Pupuce
Marsh Posté le 21-04-2003 à 10:55:24
Il y a des photos de mon 172TM au bas de cette page : http://forum.hardware.fr/forum2.ph [...] subcat=111
Marsh Posté le 21-04-2003 à 11:16:47
Qu'en penses-tu RWM de ce moniteur pour les jeux ( si tu joues ) et pour les DVD ( ca je crois qu'il n'y a pas de probleme il est tres bon pour ca, ce moniteur )
Marsh Posté le 21-04-2003 à 11:27:44
Copie de ce que j'avais écris sur un autre post :
Si tu es dans un jeu en 1024 (CS par exemple) tu remarqueras une légère rémanence au début, qui surprend même, mais que l'on oublie très vite !
Si tu es en 1280 ou dans un jeu pas spécialement rapide, tu n'auras aucun problème de rémanence.
Conclusion : appart dans certains jeux rapide en 1024 (et aussi hors des jeux, lors des scroll rapides), la rémanence est imperceptible.
Marsh Posté le 21-04-2003 à 11:35:22
ok, merci
De toute façon, je jouerais en 1280*1024 lorsque le jeu le permettra et je le connecterais en DVI
Message édité par TETE DE MORT le 24-04-2003 à 23:41:47
