qui a un ecran ibm P260 21" ? (on m'en propose 1 à 2500 Fr je fonce ?) - Hardware
Marsh Posté le 07-08-2002 à 21:47:00
ftp://ftp.pc.ibm.com/pub/pccbbs/visuals/p260ug.pdf
il a - de 1 ans
Marsh Posté le 07-08-2002 à 21:54:09
Features:
FD Trinitron CRTs for bright, sharp, accurate images on a virtually flat screen
High contrast CRTs with 1/4-wave anti-reflective coating for high definition images
Two video inputs with selection by a front mounted switch
Display Data Channel (DDC) 1/2B for error-free setup (PC system hardware and software dependent)
Lockable digital controls with On Screen Display navigation in a choice of nine languages
85 Hz flicker-free images at up to 1600 x 1200 addressability (PC system hardware and software dependent)
ISO 9241, Part 3 capability for improved image quality (PC system hardware and software dependent)
ENERGY STAR and NUTEK compliant for low power consumption (PC system hardware and software dependent)
TCO-99 for the latest environmental requirements (pearl white models)
TCO-95 environmental label (stealth black models)
Twin video inputs allow the P260 color monitors to be connected to two computer systems at once using a convenient switch on the front bezel
The P260 color monitors have a 21-inch FD Trinitron CRT with a 19.8-inch (503-mm) viewable image size, and a 0.24-mm aperture grille pitch. A maximum horizontal frequency of 121 kHz delivers an optimum 1600 x 1200 pels at 85 Hz and higher refresh rates such as 1920 x 1440 pels at up to 75 Hz refresh rate.
The P260 color monitors are capable of ENERGY STAR and NUTEK power management via DPMS; monitor Plug and Play via DDC; ISO 9241-3 image quality, and refitted with a universal voltage power supply for worldwide operation.
Attachment to certain IBM PC and workstation systems may require the use of a signal cable adapter.
Marsh Posté le 07-08-2002 à 21:57:09
vérifie la profondeur quand même, ça commence à devenir lourd, encombrant et à chauffer ces bêtes là !
ou bien économise pour un 17' LCD pour Noël
Marsh Posté le 07-08-2002 à 22:14:32
Prems a écrit a écrit : Une bonne affaire on va dire : 2500F cai le prix d'un 19" bas de gamme. |
19 bas de game = 220 euro
pas 375
Marsh Posté le 07-08-2002 à 22:22:49
les moniteurs sont noirs ?
si oui ils sont terribles
Marsh Posté le 08-08-2002 à 11:20:00
seyed_s a écrit a écrit : les moniteurs sont noirs ? si oui ils sont terribles ![]() |
ca ve dir koi ?
Marsh Posté le 08-08-2002 à 11:26:33
c un 21'' fonce !!!!
sinon donne moi l'adresse !! j'en veux un....
Marsh Posté le 08-08-2002 à 20:37:47
hutch.web a écrit a écrit : ca ve dir koi ? |
http://www5.pc.ibm.com/fr/products [...] C7002F3C88
Marsh Posté le 08-08-2002 à 23:32:11
seyed_s a écrit a écrit : http://www5.pc.ibm.com/fr/products [...] C7002F3C88 |
NON c celui la
http://www5.pc.ibm.com/br/products [...] enDocument
Marsh Posté le 08-08-2002 à 23:34:32
hutch.web a écrit a écrit : NON c celui la http://www5.pc.ibm.com/br/products [...] enDocument |
c'est presque le meme modele, à ta place j'hesiterais pas
Marsh Posté le 08-08-2002 à 23:36:59
Moi je serais toi je prendrais un bon 19" de qualité c'est vrai que c'est un 21" trinitron et que le prix est très correcte mais bon regarde chez iiyama tu verras qu'en 19" ils ont de quoi te satisfaire Mais il est vrai qu'il est très beau
Marsh Posté le 09-08-2002 à 00:07:40
Très bon matos!
Surtout pour le prix!
Vérifie quand même que le tube ne soit pas rayé...
Marsh Posté le 09-08-2002 à 00:11:14
Homecinematroc a écrit a écrit : Moi je serais toi je prendrais un bon 19" de qualité c'est vrai que c'est un 21" trinitron et que le prix est très correcte mais bon regarde chez iiyama tu verras qu'en 19" ils ont de quoi te satisfaire ![]() ![]() |
attends tu rigole, c'est un tube Sony, iiyama est largué ! je crois que c'est le meme tube que la gamme E500
Marsh Posté le 09-08-2002 à 00:15:11
Vu les perfs de de la bete en rafraichissement et le pas de masque a 2500FF faut pas hesiter...
Et la c'est l'equivalent du "bas de gamme" SONY l'E530...
PS : Les tubes SONY sont trop de la balle, y gouter c'est etre accro (Vivement que j'ai 1500? pour m'acheté un F520
Marsh Posté le 09-08-2002 à 18:43:49
Mei a écrit a écrit : la c'est l'equivalent du "bas de gamme" SONY l'E530... |
le bas de gamme ??
il fait koi de plus le haut de gamme
le 260 c du bas de gamme ???
à bon je croyais qu'il etait correct
Marsh Posté le 09-08-2002 à 18:52:28
Non c'est l'equivalent du SONY E530 l'IBM P260.
Et chez SONY l'E530 est l'entrée de gamme, mais c'est un excelent entré de gamme...
Look le SONY F520 pour comparé
Marsh Posté le 09-08-2002 à 19:24:07
Mei a écrit a écrit : Non c'est l'equivalent du SONY E530 l'IBM P260. Et chez SONY l'E530 est l'entrée de gamme, mais c'est un excelent entré de gamme... ![]() Look le SONY F520 pour comparé ![]() |
fo voir aussi si les 2000F d'écart sont justifiés
Marsh Posté le 09-08-2002 à 19:38:12
seyed_s a écrit a écrit : fo voir aussi si les 2000F d'écart sont justifiés |
Oui, car passage de 0.24 a 0.22 de pas de masque.
Mais bon... A ce prix là faut au moins le garder 10 ans
Marsh Posté le 09-08-2002 à 19:41:26
Mei a écrit a écrit : Oui, car passage de 0.24 a 0.22 de pas de masque. ![]() Mais bon... A ce prix là faut au moins le garder 10 ans ![]() |
ou tu prends le E530 + un TFT 15" pour les lan
Marsh Posté le 09-08-2002 à 19:42:30
Ca peut etre une solution aussi... Tout est question de ce qu'on fait avec apres.
Marsh Posté le 09-08-2002 à 19:45:15
Cet ecran, c'est un ecran de station de travail IBM.
le genre d'ecran que l'on trouve avec les stations 43P260 par exemple.
J'ai travaille des heures et des heures sur ce genre de matos, c'est sympa.
Question :
Tu habites dans le Doubs ou pas ?
Si oui, je sais d'ou il vient !!!!!!!!
Marsh Posté le 09-08-2002 à 19:50:46
Mei a écrit a écrit : Ca peut etre une solution aussi... Tout est question de ce qu'on fait avec apres. |
à l'usage ils doivent pas etre tres différents, et puis fo vraiment etre un sacré psychopathe pour vouloir absolument le F520
moi j'ai un 19" Iiyama depuis 3 ans, il me va très bien.
Marsh Posté le 09-08-2002 à 20:22:10
salut
alors ,je vais te dire PRENDSSSSSSSSSSSSSSSSSSS !!
sony c'est de la Bombe !!
j'avais un llyama 19'' et je suis passer a un Sony A420 19'' aussi mais alors la difference est carement flagrante !!
mais attention je ne dit pas que llyama c'est de la merde mais Sony c grand!!!
sony rulezzz!!
Marsh Posté le 09-08-2002 à 20:26:12
unptitdiable a écrit a écrit : Question : Tu habites dans le Doubs ou pas ? |
non je suis du centre
Marsh Posté le 10-08-2002 à 20:25:12
c fait je l'ai acheté 330 ? soit 2164 Fr
merci à tous
il est à vendre chez mistergooddeal à 819,00?
http://www.mistergooddeal.com/v2/V [...] 5400014242
Marsh Posté le 07-08-2002 à 20:43:21
c un 21" c un trinitron FD , pitch 0,24
c po top je croi ?
c special comme technologie ca fait mal aux yeux non ?
et ya des bande horizontal non ?
Message édité par hutch.web le 07-08-2002 à 21:23:30
