equivalent a DFT pour seagate ? - Hardware
Marsh Posté le 20-05-2002 à 16:22:09
Marsh Posté le 20-05-2002 à 16:25:10
si il march en NTFS DL "disk wizard 2002"
dedan ya seatools
Marsh Posté le 20-05-2002 à 16:25:30
merci c sympa
je dl et je test
Marsh Posté le 20-05-2002 à 16:54:02
_ _ _
/ / (_)
_\ \ \ DIAGATA.EXE Version 3.02.1011ML
(_)_/_/
Copyright (c) 2000 by Seagate Technology, Inc. All rights reserved.
Timer Resolution: 0.000122
Long Test Begin: 20-May-2002 16:38:36
Cable Test - Passed
Buffer Test - Passed
Identify Data
Model Number: ST380021A
Serial Number: 3HV0BCJC
Firmware Revision: 3.10
Default CHS: 16383-16-63
Current CHS: 16383-16-63
Current Capacity: 16514064 Sectors
Total Capacity: 156301488 Sectors
80 Conductor Cable Reported
ID Method: Unknown
SMART Check: Passed
DST - Errors - Status: 07
Long Test Failed: 20-May-2002 16:40:30
_ _ _
/ / (_)
(_)_/_/
Short Test Begin: 20-May-2002 16:42:34
Cable Test - Passed
Identify Data
ID Method: Unknown
SMART Check: Passed
Outer Diameter Scan (0 to 2494208) - Passed
Elapsed Time: 30.00s
Estimated Internal Transfer Rates
Min: 67.64Mb/s Max: 477.27Mb/s Avg: 357.63Mb/s
Inner Diameter Scan (155054384 to 156301488) - Passed
Elapsed Time: 25.51s
Min: 32.54Mb/s Max: 268.47Mb/s Avg: 206.09Mb/s
Random Seek (1514 Cycles) - Passed
Estimated Access Times
Min: 1.465ms Max: 16.356ms Avg: 9.751ms
Random Read (1036 Cycles) - Passed
Min: 3.906ms Max: 25.144ms Avg: 14.321ms
PIO/DMA Data Compare
Total Bytes = 24987136
Estimated PIO Transfer Rates
Min: 0.93MB/s Max: 2.72MB/s Avg: 2.72MB/s
Estimated DMA Transfer Rates
Min: 77.60MB/s Max: 77.60MB/s Avg: 77.60MB/s
SMART Check: Passed
Short Test Passed: 20-May-2002 16:44:14
_ _ _
/ / (_)
(_)_/_/
Long Test Begin: 20-May-2002 16:44:31
Cable Test - Passed
Identify Data
ID Method: Unknown
SMART Check: Passed
Full Scan (0 to 6582018) - Errors
|LBA |Error Register|
|5719559 |40h |
|5953265 |40h |
|5955267 |40h |
|5999673 |40h |
|6001675 |40h |
|6005827 |40h |
|6082182 |40h |
|6086334 |40h |
|6195123 |40h |
|6199275 |40h |
|6242364 |10h |
|6246516 |40h |
|6342164 |40h |
|6346316 |40h |
|6379583 |40h |
|6395558 |40h |
|6405863 |40h |
|6566043 |40h |
|6568878 |40h |
|6582017 |40h |
Long Test Failed: 20-May-2002 16:46:57
effectivement ce soft fonctionne mais pas mon DD
Marsh Posté le 19-05-2002 à 17:31:31
ca existe ?
DFT : drive fitness test de IBM ( outils de diagnostic)
je voudrais diagnostic mon Barracuda a fond mais l'outils que g trouvé chez Seagate ne marche pas si le dd est en NTFS (
Le droit à la différence s'arrête là où ça commence à m'emmerder sérieusement.
