Graveur Teac 40/12/48 ( resolution d'un pb inside ) - Hardware
Marsh Posté le 28-04-2002 à 10:12:44
voila l'erreur qu'il ecrit dans le log, dans cette exemple j'ais tenté une copie cd a cd au cas ou l'erreur vienne de mes disuqes
Windows 2000 5.0
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 23/12/1997 02:23:24
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.45, size=172099 bytes, created 27/04/2002 14:01:10
Nero Version: 5.5.8.0
Recorder: <TEAC CD-W540E> Version: 1.0B - HA 1 TA 0 - 5.5.8.0
Adapter driver: <atapi> HA 1
Drive buffer : 6746kB
Bus Type : default (0) -> ATAPI
CD-ROM: <_NEC DV-5700A> Version: 1.91 - HA 0 TA 0 - 5.5.8.0
Adapter driver: <atapi> HA 0
=== Scsi-Device-Map ===
CdRomPeripheral : _NEC DV-5700A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TEAC CD-W540E atapi Port 1 ID 0 DMA: On
DiskPeripheral : ST340016A 3.10 HPT3xxNT Port 2 ID 0 DMA: ?
OtherPeripheral : HPT RCM DEVICE HPT3xxNT Port 2 ID 0 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523828kB)
Free physical memory: 424MB (434224kB)
Memory in use : 17 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: On
CD-Copy
27.4.2002
15:02:20 #1 Phase 72 File dlgbrnst.cpp, Line 1449
BURN-Proof activated
15:02:20 #2 Text 0 File Reader.cpp, Line 118
Reader running
15:02:20 #3 Text 0 File Burncd.cpp, Line 2636
Turn on Disc-At-Once, using CD-R/RW media
15:02:20 #4 Phase 48 File dlgbrnst.cpp, Line 1449
Analyzing CD
15:02:20 #5 CDCOPY -1 File CDCopy.cpp, Line 2462
The CD is copyrighted
15:02:21 #6 Text 0 File CDCopy.cpp, Line 2696
_Index0_ _______Index1_______ PostPause ___LastBlockOfTrack_
Track 1: 0 0 ( 0:02.00) 329875 329874 ( 73:20.24)
15:02:21 #7 Text 0 File CDCopy.cpp, Line 1019
Copy options: read subcode: OFF jitter correction: OFF copy on-the-fly: ON
read ISRC/MCN: ON ignore inv. TOC type: ON ignore audio read error: ON
source disc does not look like CD Extra
01. 0 - 329875 = 329875, data (2)
15:02:21 #8 Text 0 File ThreadedTransferInterface.cpp, Line 684
Setup items (original item values)
0: TRM_DATA_MODE2_FORM1_NOSUB (1 Data (mode 2))
2 indices, index0 (150) not provided
original CD pos #0 + 329875 (329875) = #329875/73:18.25
relocatable, CD pos for caching/writing not required/not required, no patch infos
15:02:40 #9 Phase 40 File dlgbrnst.cpp, Line 1449
Aborted by user
15:02:40 #10 Text 0 File DlgWaitCD.cpp, Line 199
Disc check failed: Medium not writable
15:02:40 #11 SCSI -1080 File Cdrdrv.cpp, Line 1209
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0012E4A8
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x3A
Sense Qual: 0x00
CDB Data: 0x51 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x22 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x3A 0x00
15:02:40 #12 Text 0 File DlgWaitCD.cpp, Line 1387
Recorder: TEAC CD-W540E;
CD type reading failed
ATIP Data: ?
15:02:40 #13 Text 0 File Scsicmd.cpp, Line 386
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 23/12/1997 03:02:46
[jfdsdjhfuetppo]--Message édité par spartacus le 28-04-2002 à 10:14:23--[/jfdsdjhfuetppo]
Marsh Posté le 28-04-2002 à 10:27:58
ReplyMarsh Posté le 28-04-2002 à 10:44:19
je sais pas quel est la dernière version, mais fait une recherche sur le forum et tu vas trouver réponse à ta question
Marsh Posté le 28-04-2002 à 12:03:31
c marche pas, j'ais mi la 4.70 mais tjrs la meme erruer, une autre idée?
Marsh Posté le 28-04-2002 à 12:07:27
ca la toujour fait
sinon vois à changer le firmware, mais je pense pas que ca vienne de la, tu as essayé avec un autre support ?
Marsh Posté le 28-04-2002 à 12:08:53
ben le graveur vient de sortir, y'a pas d'autre firmware. pour les cd j'ais que des traxdata, peut etre une incompatibilité?
Marsh Posté le 28-04-2002 à 12:09:44
y a un fimware qui viens de sortir, tu as quel firmware sur le tiens
Marsh Posté le 28-04-2002 à 12:12:03
c'est la 1.0B du teac CD-W540E
Marsh Posté le 28-04-2002 à 12:13:17
et bien la 1.0c est sortie, le 19 mars 2002
http://www.teac.co.jp/dspd/
Marsh Posté le 28-04-2002 à 12:13:59
cool merci je vais voir ca
Marsh Posté le 28-04-2002 à 12:18:13
spartacus a écrit a écrit : cool merci je vais voir ca |
mais tu devrais essayer avec un autre support quand mm pour voir
Marsh Posté le 28-04-2002 à 13:26:20
ben ca n'a pas marché en changent le firmware, j'ais donc passé le graveur en mode pio et ca marche m'enfin ca me fé chier de rester en pio, ptain avoir la derniere generation de graveur et ne pas pouvoir etre en udma ca fé chier
en tt cas merci pour ton aide ameddou
neanmoins si quelqu'un sait me dire comment faire marcher ce graveur en udma je l'en remerci d'avance.
PS j'ais les dernier Via 4in1, enfin je crois
[jfdsdjhfuetppo]--Message édité par spartacus le 28-04-2002 à 13:26:49--[/jfdsdjhfuetppo]
Marsh Posté le 28-04-2002 à 13:30:09
spartacus a écrit a écrit : ben ca n'a pas marché en changent le firmware, j'ais donc passé le graveur en mode pio et ca marche ![]() ![]() en tt cas merci pour ton aide ameddou ![]() neanmoins si quelqu'un sait me dire comment faire marcher ce graveur en udma je l'en remerci d'avance. PS j'ais les dernier Via 4in1, enfin je crois |
et est ce qu'il marche bien en mode PIO, car sinon je vois pas le problème, fait des testes, mais à mon avis ca ne viens pas du graveur mais plutôt de ta carte mère
Marsh Posté le 28-04-2002 à 16:12:01
ouais ca marche bien en pio j'ais gravé 10 cd en 40x, donc pour le pb c clair ca vient pas du graveur. Je verai si en passant a XP j'ais tjrs le meme pb si c le cas c la carte mere qui chie .
Marsh Posté le 28-04-2002 à 16:46:05
oki, et bien fait moi signe car je suis TEAC à fond, et je ne voudrais pas qu'il te désoit.
moi j'ai le 24 x
Marsh Posté le 01-05-2002 à 00:27:51
ameddou a écrit a écrit : oki, et bien fait moi signe car je suis TEAC à fond, et je ne voudrais pas qu'il te désoit. moi j'ai le 24 x |
et bien mauvaise nouvelle le passage a XP n'a rien changé. Je ne peut pas passer le graveur en udma...
si quelqu'un fait marcher ce graveur sur une EpoX 8kta3+ pro ou un n'importe quelle carte a base de KT133A, qu'il me fasse signe
Marsh Posté le 01-05-2002 à 11:52:18
Ayé j'ais trouvé la solution, chez moi le graveur ne marche en udma que si on utilise une nappe ATA33, avec la nappe ATA100 impossible de le faire tourner en udma, seul le mode pio4 marchait.
A bon entendeur Salut
Sinon il est geniale ce graveur, 2:38 pour graver un cd en 40x ( le cd est un cerftifié 8x ). Meme en mode pio4 aucun cd de planté. je ne suis pas decu d'avoir choisi Teac
[jfdsdjhfuetppo]--Message édité par Spartacus le 01-05-2002 à 11:54:11--[/jfdsdjhfuetppo]
Marsh Posté le 28-04-2002 à 10:04:43
quand je veux graver quelques chose avec nero5.5.8 il me dit "media no writable" pourtant mon cdr et bien vierge ( pour info ce sont des traxdara 2*4*6*8*)...quelqu'un a t'il rencontré ce prob, une solution peut etre?
[#ff0000]Probleme resolu, le graveur ne refusait le mode Udma et n'acceptait de fonctionner que en mode pio4 si utilisait une nappe ATA100. Mais lorsque on utillise une nappe ATA33l e graveur accepte le mode udma pour la gravure.
un autre point important je vous coneil vivement de flacher le graveur avec le dernier firmware en effet avec 1.0B Nero ne voit que 6mo de chache sur les 8mo annocés, pb resolu avec le firmware 1.0C, Nero voit enfin les 8mo[#ff0000]
[jfdsdjhfuetppo]--Message édité par Spartacus le 01-05-2002 à 11:59:06--[/jfdsdjhfuetppo]
Lone Wolf Rider
