j arrive plus a graver quand je veux graver avec nero y il me met
invalid block erreur
fonction writestate invalide
impossible d effectuer la fonction end track
voici le log : Windows NT 5.0 WinAspi: - ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.27, size=155715 bytes, created 14/09/2001 15:18:24 Nero Version: 5.5.1.8 Recorder: <PHILIPS PCRW804> Version: 1.8 - HA 1 TA 0 - 5.5.1.8 Adapter driver: <atapi> HA 1 Drive buffer : 2048kB CD-ROM: <GoldStar CD-ROM CRD-8520B>Version: 1.00 - HA 1 TA 1 - 5.5.1.8 Adapter driver: <atapi> HA 1
=== Scsi-Device-Map === DiskPeripheral : ST320420A atapi Port 0 ID 0 DMA: On CdRomPeripheral : PHILIPS PCRW804 atapi Port 1 ID 0 DMA: Off CdRomPeripheral : GoldStar CD-ROM CRD-8520B atapi Port 1 ID 1 DMA: Off =======================
12:33:30 #1 Text 0 File Writer.cpp, Line 125 Writer PCRW804 running
12:33:33 #2 Text 0 File Burncd.cpp, Line 1497 Recorder: PHILIPS PCRW804; CDR code: 00 97 15 17; OSJ entry from: Ritek Co. ATIP Data: Special Info [hex] 1: C0 00 90, 2: 61 0F 11 (LI 97:15.17), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
12:33:33 #3 Text 0 File ThreadedTransferInterface.cpp, Line 800 Prepare recorder PCRW804 for write in TAO DAO infos: ========== MCN: TOCTYPE: 0x0 Close CD Tracks 1 to 1: TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 734595072
12:33:33 #4 Text 0 File ThreadedTransferInterface.cpp, Line 828 Removed 2 run-out blocks from end of track 1.
12:33:33 #5 Text 0 File ThreadedTransferInterface.cpp, Line 665 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original CD pos #0 + 358539 (358539) = #358539/79:40.39 relocatable, CD pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358537 blocks [PCRW804 ] --------------------------------------------------------------
12:33:33 #6 Phase 24 File dlgbrnst.cpp, Line 1372 Start of caching files
12:33:33 #8 Phase 32 File dlgbrnst.cpp, Line 1372 Start of simulation at 8x (1200 KB/s)
12:33:37 #9 Text 0 File ThreadedTransferInterface.cpp, Line 1836 Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
12:34:06 #10 SCSI -1037 File Cdrdrv.cpp, Line 1392 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02AB4094 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x63 Sense Qual: 0x00 CDB Data: 0x2A 0x00 0x00 0x00 0x26 0xAC 0x00 0x00 0x1E 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x26 0xAC 0x13 0x00 0x00 0x00 0x00 0x63 0x00
12:34:06 #11 mmc -1037 File Writer.cpp, Line 311 End of user area of this track
12:34:06 #12 Text 0 File ThreadedTransfer.cpp, Line 218 all writers idle, stopping conversion
12:34:06 #13 Text 0 File ThreadedTransfer.cpp, Line 212 conversion idle, stopping reader
12:34:07 #14 CDR -201 File WriterStatus.cpp, Line 121 Invalid writestate
12:34:07 #15 TRANSFER -18 File WriterStatus.cpp, Line 121 Could not perform EndTrack
12:34:11 #16 Phase 34 File dlgbrnst.cpp, Line 1372 Simulation failed at 8x (1200 KB/s)
12:34:11 #17 Text 0 File Scsicmd.cpp, Line 371 SCSI not using temporary buffers 20 out of 20 temporary buffers allocated
Existing drivers: File 'Drivers\NeroCD2k.sys': Ver=1.0.0.9, size=44227 bytes, created 11/09/2001 22:55:29
c quoi le pb? j espere que j ai donne assez d info
Je viens d'avoir exactement le même problème que toi avec mon Plextor 8432, et pas moyen de graver mes 80 mais que des 74, as tu réussi à corriger ce problème ?
Marsh Posté le 15-09-2001 à 12:41:53
voici le log :
Windows NT 5.0
WinAspi: -
AutoRun : 1
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 48234496 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 383MB (392688kB)
Free physical memory: 159MB (163204kB)
Memory in use : 58 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: Off
CD-ROM (ISO)
15.9.2001
ATIP Data:
DAO infos:
MCN:
Tracks 1 to 1:
12:33:33 #7 Phase 25 File dlgbrnst.cpp, Line 1372
Caching files completed
Sense Code: 0x63
Sense Qual: 0x00
Invalid writestate
Existing drivers:
c quoi le pb?
