Impossible d' Effacer DVD+RW
Impossible d' Effacer DVD+RW - CD/DVD/BD - Hardware
Marsh Posté le 05-10-2009 à 22:03:36
Bonsoir;
Depuis un certain temps (je n'arrive tjs pas a identifier à quel événement..) , tous mes DVD +RW ou CD+RW une fois gravé.. je ne peux plus les effacer !
Lecteur Graveur : PIONEER DVD 111D
Support : DVD+RW Verbatim
Voici le logs de NERO:
Spoiler :
====== *** Nero Burning ROM, History File *** ======
NerO
inc
1C89-0000-1911-0000-4003-6992-****
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.8.5.0
Internal Version: 7, 8, 5, 0
Recorder:             <PIONEER DVD-RW  DVR-111D>Version: 1.29 - HA 1 TA 0 - 7.8.5.0
 Adapter driver:      <IDE>                     HA 1
 Drive buffer  :      2000kB
 Bus Type      :      default (0) -> ATAPI, detected: ?
CD-ROM:               <PIONEER  DVD-RW  DVR-111D>Version: 1.29 - HA 1 TA 0 - 7.8.5.0
=== Scsi-Device-Map ===
CdRomPeripheral      : PIONEER DVD-RW  DVR-111D         atapi Port 0 ID 0  DMA: On
DiskPeripheral       : Maxtor 6V200E0                   atapi Port 1 ID 0  DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-RW  DVR-111D   F:   CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE           : 0
Physical memory     : 1023MB (1047788kB)
Free physical memory: 735MB (753256kB)
Memory in use       : 28
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
4.10.2009
Compilation ISO
19:57:39 #1 Text 0 File SCSIPTICommands.cpp, Line 411
 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
19:57:39 #2 Text 0 File Isodoc.cpp, Line 6608
 Iso document burn settings
 Determine maximum speed : FALSE
 Simulate                : FALSE
 Write                   : TRUE
 Finalize CD             : TRUE
 Multisession            : FALSE
 Burning mode            : DAO
 Mode                    : 1
 ISO Level               : 2 (Max. of 31 chars)
 Character set           : ISO 9660
 Joliet                  : TRUE
 Allow pathdepth more than 8 directories : TRUE
 Allow more than 255 characters in path  : TRUE
 Write ISO9660 ;1 file extensions        : TRUE
19:57:40 #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
 First writeable address = 0 (0x00000000)
19:57:40 #4 Text 0 File Burncd.cpp, Line 3499
 Turn on Disc-At-Once, using DVD media
19:57:40 #5 Text 0 File DlgWaitCD.cpp, Line 307
 Last possible write address on media:  2295103 (510:01.28, 4482MB)
 Last address to be written:            2289327 (508:44.27, 4471MB)
19:57:40 #6 Text 0 File DlgWaitCD.cpp, Line 319
 Write in overburning mode: NO (enabled: CD DVD)
19:57:40 #7 Text 0 File DlgWaitCD.cpp, Line 2949
 Recorder: PIONEER DVD-RW  DVR-111D, Media type: DVD+RW
  Disc Manufacturer ID: MKM, Media Type ID: A02, Product revision number: 0
  Disc Application Code: 0, Extended Information Indicators: 1
19:57:40 #8 Text 0 File DlgWaitCD.cpp, Line 493
 >>> Protocol of DlgWaitCD activities: <<<
19:57:40 #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
 Setup items (after recorder preparation)
  0: TRM_DATA_MODE1 ()
     2 indices, index0 (150) not provided
     original disc pos #0 + 2289328 (2289328) = #2289328/508:44.28
     relocatable, disc pos for caching/writing not required/ required
     -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2289328 blocks [F: PIONEER DVD-RW  DVR-111D]
19:57:40 #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
 Prepare [F: PIONEER DVD-RW  DVR-111D] for write in CUE-sheet-DAO
 DAO infos:
  MCN: ""
  TOCType: 0x00; Session Closed, disc fixated
  Tracks 1 to 1:                                  Idx 0         Idx 1      Next Trk
    1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    4688543744, ISRC ""
 DAO layout:
  ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
         0 |  lead-in |   0 |    0x41 |        0 |        0 | 0x00
         0 |        1 |   0 |    0x41 |        0 |        0 | 0x00
         0 |        1 |   1 |    0x41 |  2289328 |        0 | 0x00
   2289328 | lead-out |   1 |    0x41 |        0 |        0 | 0x00
19:57:40 #11 Text 0 File SCSIPTICommands.cpp, Line 209
 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
19:57:40 #12 Text 0 File Burncd.cpp, Line 4278
 Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
19:57:40 #13 Phase 24 File dlgbrnst.cpp, Line 1762
 Caching of files started
19:57:40 #14 Text 0 File Burncd.cpp, Line 4397
 Cache writing successful.
19:57:40 #15 Phase 25 File dlgbrnst.cpp, Line 1762
 Caching of files completed
19:57:40 #16 Phase 36 File dlgbrnst.cpp, Line 1762
 Burn process started at 4x (5 540 Ko/s)
19:57:40 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
19:57:40 #18 Text 0 File Cdrdrv.cpp, Line 9859
 ---- Disc Structure: Physical Format Information (00h) ----
 Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
  Book Type: DVD+RW (9), Part Version: 1.1x (2)
  Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
  Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: re-writable
  Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
  Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
  End Sector Number in Layer 0:                 0 h (LBN: FFFD0000 h, 4193920 MB)
  Data in Burst Cutting Area (BCA) does not exist
   Disc Application Code: 0 / 0 h
   Extended Information indicators: 1 h
   Disc Manufacturer ID: MKM.....
   Media type ID: A02
   Number of Physical format information bytes in use in ADIP up to byte 63: 57
  Media Specific [16..63]:
     00 00 01 4D 4B 4D 00 00 - 00 00 00 41 30 32 00 39    ...MKM.....A02.9
     23 00 94 79 64 02 20 00 - 9C 7A 6C 02 20 00 9A 7B    #..yd....zl....{
     68 02 20 12 12 10 E0 00 - F0 00 00 00 00 00 00 00    h...............
19:57:40 #19 Phase 98 File dlgbrnst.cpp, Line 1762
 Start formatting disc before burning
19:58:10 #20 Phase 100 File dlgbrnst.cpp, Line 1762
 Formatting disc was successful
19:58:10 #21 SPTI -1066 File SCSIPassThrough.cpp, Line 179
 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
 Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
 Sense Code: 0x24
 Sense Qual: 0x00
 CDB Data:   0xAC 00 00 00 00 00 00 00 00 64 00 00
 Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
 Buffer x0503f080: Len x648
19:58:10 #22 Text 0 File DVDPlusRW.cpp, Line 674
 Start write address at LBA 0
 DVD high compatibility mode: No
19:58:10 #23 Text 0 File ThreadedTransfer.cpp, Line 269
 Pipe memory size 83836800
19:58:11 #24 Text 0 File Cdrdrv.cpp, Line 1338
 19:58:11.953 - F: PIONEER DVD-RW  DVR-111D : Queue again later
19:58:12 #25 Text 0 File Cdrdrv.cpp, Line 1338
 19:58:12.187 - F: PIONEER DVD-RW  DVR-111D : Queue again later
20:12:12 #26 Text 0 File WriterStatus.cpp, Line 113
 <F: PIONEER DVD-RW  DVR-111D> start writing Lead-Out at LBA 2289328 (22EEB0h), length 0 blocks
20:12:14 #27 Text 0 File DVDPlusRW.cpp, Line 899
 Media-Format will be stopped after burning
20:12:14 #28 Phase 133 File dlgbrnst.cpp, Line 1762
 Writing short lead-out
20:12:40 #29 Text 0 File DVDPlusRW.cpp, Line 934
 EndDAO: Last written address 2289328
20:12:40 #30 Phase 37 File dlgbrnst.cpp, Line 1762
 Burn process completed successfully at 4x (5 540 Ko/s)
20:12:40 #31 Phase 78 File dlgbrnst.cpp, Line 1762
 Data verification started
20:12:43 #32 Text 0 File ThreadedTransfer.cpp, Line 269
 Pipe memory size 590400
20:22:18 #33 Phase 80 File dlgbrnst.cpp, Line 1762
 Data verification completed successfully
20:22:19 #34 Text 0 File SCSIPTICommands.cpp, Line 254
 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
20:22:23 #35 Text 0 File Cdrdrv.cpp, Line 11214
 DriveLocker: UnLockVolume completed
20:22:23 #36 Text 0 File SCSIPTICommands.cpp, Line 411
 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Merci par avance de vos pistes :(
@+ [:athome]
NerO
