[Topic Unique] Asus PUNDIT P3-PH5 - Core 2 Duo
Asus PUNDIT P3-PH5 - Core 2 Duo [Topic Unique] - Mini PC - Hardware
Marsh Posté le 01-02-2007 à 13:36:54
http://usa.asus.com/999/images/products/1534/1534_l.jpg
Il semblerait qu'une alternative sérieuse voie le jour, face au certes très bien fini Shuttle SD37P2 mais un peu hors de prix.
#  Product Type:
Mini PC Barebone System
# Mfr P/N / Model:
PUNDIT P3-PH5
# Form Factor:
Slim Book Size
# Bezel Color:
Black
# Drive Bay:
2 x 3.5" ==> deux disques durs :love:
1 x 5.25"
# Power Supply Included:
275 W (PFC)
# Front I/O:
1 x IEEE 1394 (4pin)
2 x USB 2.0
1 x Microphone
1 x Headphone
1 x 6-in-1 Card Reader
# Card Reader:
6-in-1 Card Reader
# MB Form Factor:
uATX (9.6" x 9.6" )
# MB Chipsets:
North Bridge: Intel G965
South Bridge: Intel ICH8
# CPU Socket:
LGA 775
# CPU Support:
Intel Core 2 Extreme/Core 2 Duo/Pentium D/Pentium 4/Celeron D
- Compatible with Intel 05B/05A/06 processors
- Intel Hyper-Threading Technology ready
{ Please refer to mfr WWW for CPU support }
# CPU FSB:
1066/800/533 MHz FSB
# Memory:
4x DDR2 slot support Dual Channel DDR2 800/667/533 upto 4 GB
# Expansion Slot:
1x PCIe x16
1x PCIe x4
2x PCI
# Storage 1:
Intel ICH8 (Southbridge)
2x SATA 3.0 Gb/s ports (NO RAID FUNCTION)
# Storage 2:
JMicron JMB363 controller
- 1 x ATA133 for up to 2 IDE devices
- 1 x eSATA 3.0 Gb/s port (external SATA port)
# Onboard Video:
integrated Intel Graphics Media Accelerator X3000
# Onboard Audio:
integrated ADI AD1988 8-channel
# Onboard LAN:
integrated Realtek PCI-E Gigabit LAN controller
# Onboard Firewire:
TI 1394a controller supports 2x IEEE 1394a ports (1 front, 1 rear)
# eSATA:
1x eSATA port
# Rear I/O Ports:
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel port
1 x External SATA
1 x VGA port
1 x IEEE1394a
1 x RJ45 port
4 x USB 2.0/1.1
8-Channel Audio I/O
1x Back Surround LR/Side Surround LR/Center LFE
# Dimensions:
95 x 357 x 398mm (WxHxD)
3.75" x 14.05" x 15.67"
# Gross Weight:
20.5 lbs
Photo de l'intérieur de la bête par jivede.
http://img516.imageshack.us/img516/69/img2640oe2.th.jpghttp://img524.imageshack.us/img524/1411/img2662yo1.th.jpghttp://img377.imageshack.us/img377/8766/img2665oj0.th.jpghttp://img377.imageshack.us/img377/3995/img2666op4.th.jpg
http://img341.imageshack.us/img341/6371/img2667jv5.th.jpghttp://img452.imageshack.us/img452/9427/img2701ju4.th.jpghttp://img452.imageshack.us/img452/8728/img2703yo0.th.jpghttp://img505.imageshack.us/img505/2818/img2706wa2.th.jpg
Message édité par Toxin le 27-03-2007 à 11:38:03
"If you can walk away from a landing, it's a good landing. If you use the airplane the next day, it's an outstanding landing." - Chuck Yeager. | Chaîne YT | Photos
Marsh Posté le 01-02-2007 à 13:37:45
FEEDBACKS
Par jivede, le 07-03-2007
Petit retour rapide après montage, à prendre pour ce que ça vaut vu que le seul barebone que j'avais monté avant était un shuttle en 2003 (je ne doutais pas que ça avait évolué depuis   :D  ).
Impressions au montage :
  • Finitions propres, pas de jeu, une bonne impression de solidité (c'est qu'il est assez lourd mine de rien)
  • Visserie fournie
  • Montage du proc + rad hyper rapide
  • Insertion des 2 barettes de RAM
  • Montage des équerres low profile sur la x1600
  • Insertion de la x1600 bien pratique avec le systeme sans vis (mais c'est systematique ça maintenant non ?)
  • Montage de l'IDE 5"1/4 avec 2 vis et un systeme de clips (à noter que l'arrière d'un lecteur DVD viendra pousser très légèrement une des barettes de RAM a cause de la nappe, mais rien de méchant)
  • Montage de 2 HD, les vis sont a poser avant (+ rondelles de caoutchouc fournies pour faire silent block) la fixation se fait via des clips cette fois aussi.
  • Fermeture du boitier
J'ai pas chronométré mais le tout est très simple et très rapide.
Impressions après l'install d'un vista :
  • Speedfan me donne mes 2 cores à 47° en idle avec le fan a 1500rpm
  • Plutot silencieux en idle, les durs sont bien isolés par les "silent blocks" et surtout les patins en caoutchouc sous les pieds du boitier
  • Je n'entend pas la CG
  • Le ventilo de l'alim est relativemment silencieux (bien que dans les aigus, 40mm oblige)
  • Au final on entend surtout le souffle du rad (en même temps les aérations sont placées au dessus et en face de lui) qui est plutôt dans les graves donc ça va (en idle, je n'ai pas testé de le faire chauffer un peu).
Voila pour aujourd'hui, je ne regrette pas du tout mon achat en tout cas  :)
Message édité par Toxin le 27-03-2007 à 11:36:59
Marsh Posté le 01-02-2007 à 13:37:51
[Réservé]
Marsh Posté le 09-02-2007 à 21:20:31
[:abnocte invictus]
Marsh Posté le 13-02-2007 à 11:32:55
Quelqu'un aurait-il connaissance de CG qui rentrent dans le boitier ?
Marsh Posté le 16-02-2007 à 13:56:38
+1
une lowprofile recente compatible HDCP
Marsh Posté le 16-02-2007 à 16:03:14
bon moio qui voulait un Gigabyte H971 Home Theater, j pense plutot m'orienter vers ca, ca sera surement moins couteux
par contre ca serait bien que ca sorte :d
Marsh Posté le 17-02-2007 à 23:23:49
wep il est bien sympa comme boitier,il me plait bien :D
Marsh Posté le 18-02-2007 à 15:42:09
Drapal je suis interessé par un petit media center C2D pour la HD :)
Marsh Posté le 18-02-2007 à 16:20:15
J'espère que l'alimentation est silencieuse,sur certains sites étranger il est a 200€ par là ça fait vrement pas bien cher avec un peu de chance il dépasseras pas les 250/300 en france :)
Marsh Posté le 18-02-2007 à 19:28:30
tu là trouvé ou à ce prix là ?
Marsh Posté le 18-02-2007 à 19:51:46
on l trouve aussi a 198€ sur des sites italiens, ca m'etonnerai quand meme
qu'ils ne le foutent a 250€ quand meme, du moins pas quand bon nombre
de mag l'auront en stock!
Marsh Posté le 18-02-2007 à 19:57:02
a fallait mettre des liens :d
voila alors
http://www3.avitos.com/shop/basket [...] duct_list=
en meme temps 264,00 CHF = 162,731 EUR
CA FAIS ENVIE  :love:
Message édité par KeepCool le 18-02-2007 à 20:01:33
Marsh Posté le 18-02-2007 à 20:09:29
Bon par contre faudrait tous qu'on s'mette a la recherche d'une CG rentrant dedans ^^
car apparement personne n'en a trouve une jusqu'a aujourd hui
moi perso a part des X300 (BEURK) j'ai rien trouvé ^^
mais bon j cherche encore
y a ca Sapphire X1600 Pro HDMI mais pas trouvé de revendeur ???
pareil pour celle la  Leadtek PX7600GS TDH LP
EDIT
ah mais si mais si ^^
http://www.ldlc.com/fiche/PB00047840.html
Message édité par KeepCool le 18-02-2007 à 20:38:19
Marsh Posté le 23-02-2007 à 10:45:53
Ca y est on connait un prix pour la france ---> http://www.sabmegastore.com/fiche-asus-3473.html
pour LDLC aussi 203€ FDP IN, reste plus que la disponiblité ^^
Marsh Posté le 23-02-2007 à 13:08:10
Bon Bah du coup je prepare la ptite config:
asus pundit 160e
saphire radeon X1600 133e
INTEL Core 2 Duo E4300 1.8Ghz 147e
Seagate 500Go 7200 RPM S-ATA II 16Mo (Barracuda 7200.10) 145e
Message édité par fabcool le 23-02-2007 à 16:22:01
Marsh Posté le 23-02-2007 à 17:55:24
Le reve pour un bon petit serveur  :love:
Marsh Posté le 23-02-2007 à 19:14:59
c'est l'objectif ^^ freebox optique ^^
Marsh Posté le 04-03-2007 à 21:44:07
Alors personne ne l'a ce petit joujou ? j'aimerais quelques feeback :)
Marsh Posté le 04-03-2007 à 21:51:25
Je vais probablement le commander sur LDLC (indiqué dispo le 8 mars), j'attends d'être sûr que d'autres achats qui conditionnent le sien soient confirmés :)
Marsh Posté le 05-03-2007 à 11:25:21
commandé mardi dernier sur ldlc (juste avant rupture du stock initial), d'après chronopost il devrait arriver dans la journée, je ferais un feedback ici
ASUSTeK Pundit P3-PH5 (Intel G965 Express)
Samsung SpinPoint T - HD401LJ - 400 Go 7200 RPM 16 Mo Serial ATA II (bulk)
Intel Core 2 Duo E6300 - Dual Core ! Socket 775 FSB1066 cache L2 2 Mo 0.065 micron (version boîte - garantie Intel 3 ans)
Sapphire Radeon X1600 Pro HDMI - 256 Mo TV-Out/HDMI - PCI Express (ATI Radeon X1600 Pro)
LDLC Quality Select Kit Dual 2Go DDR2-SDRAM DDR800 PC6400 (2x 1 Go)
Message édité par jivede le 05-03-2007 à 11:31:44
Marsh Posté le 05-03-2007 à 18:38:09
Jivede -> Je suis intéressé par cette config, j'ai hate de connaître ton feedback, notamment par rapport au bruit de la machine.
Par contre pour la CG, j'ai bien trouvé la sapphire radeon x1600 Pro HDMI, elle a bien l'aire d'être low profile mais sur la fiche rien d'indiqué, est-ce que l'équerre low profile est fournit ou alors faut-il en bricoler un ?
Marsh Posté le 05-03-2007 à 20:01:30
Je n'ai pas trouvé de confirmation écrite mais je me suis décidé en voyant ces photos :
http://www.theinquirer.net/images/articles/saphd.jpghttp://www.theinquirer.net/images/articles/saphd1.jpg
http://www.theinquirer.net/default.aspx?article=34632
ps: pas reçu ma commande aujourd'hui je croise les doigts pour demain.
Marsh Posté le 06-03-2007 à 19:43:51
Idem, je pense le commander chez LDLC. J'attends avec impatience ton feeback sur ce barebone. Le seul truc qui m'embête c'est qu'il est assez profond comparé au P2-P5945 (10 cm d'écart).
Marsh Posté le 07-03-2007 à 01:01:01
  • Visserie fournie
Message édité par jivede le 07-03-2007 à 09:01:44
Marsh Posté le 07-03-2007 à 01:33:42
merci pour ton feed
on peut avoir quelques toph ?
ça ma l'air globalement assez positif qd meme :)
Marsh Posté le 07-03-2007 à 09:07:32
fabcool a écrit :
merci pour ton feed
Je fais un edit après l'avoir utilisé un peu ce matin, en fait ça dépend de l'idée qu'on se fait du silence. Je n'ai rien pour mesurer donc tout ce que je peux dire c'est qu'on l'entend un peu en idle (autant que mon laptop asus f3jm pleine charge) mais que le son est un souffle grave plus agréable. Les commentaires postés au dessus je les ai fais avec le pundit posé a coté de moi, là il est sous mon bureau et il faut tendre l'oreille pour l'entendre.
(photos à venir)
Message édité par jivede le 07-03-2007 à 10:37:44
Marsh Posté le 07-03-2007 à 10:17:18
Merci jivede, je passe ma commande:
ASUSTeK Pundit P3-PH5 (Intel G965 Express) - Noir/Argent
Intel Core 2 Duo E6700 - Dual Core ! Socket 775 FSB1066 cache L2 4 Mo 0.065 micron
Samsung SpinPoint T - HD501LJ - 500 Go 7200 RPM 16 Mo Serial ATA
LDLC Quality Select Kit Dual 2 Go DDR2-SDRAM DDR800 PC6400 (2x 1 Go)
NEC AD-7173-0B - DVD(+/-)RW/RAM 18/8/18/6/12 DL(+/-) 8/8x CD-RW 48/32/48x IDE - Noir
Pour le silence, ça ne pourra pas être pire que ma grande tour antec et ses 7 ventilos ;-)
Marsh Posté le 07-03-2007 à 10:35:52
Tu vas faire le même saut que moi alors, je me sépare d'un bon vieil antec 1030 qui avait à refroidir un amd64 et une radeon 9800 (6 ventilos).
Y'a pas photo les bruits émis n'ont rien a voir :)
Marsh Posté le 07-03-2007 à 18:38:18
Merci pour ton feedback sur le barebone. On attends les tof avec impatience ;-)
Message édité par driveofyourlife le 07-03-2007 à 18:38:44
Marsh Posté le 07-03-2007 à 19:22:53
[en location pour 3€ l'heure]
http://www.deezer.com/track/1115801 Qu'est ce que la vie ? :(
Marsh Posté le 15-03-2007 à 01:13:12
Je viens seulement de tester la machine pour jouer et ... quand le ventilo du proc monte dans les tours il devient super bruyant, je n'ai pas de point de comparaison avec d'autres barebones mais il l'est suffisamment pour que ce soit génant. (solution possible: utiliser un autre rad que celui fourni avec le pundit, il faudrait que je teste l'intel à tout hasard)
Marsh Posté le 15-03-2007 à 11:13:01
AÏe, je n'ai pas reçu ma conf encore, il chauffe tant que ça pour se mettre à faire autant de bruit ?
Marsh Posté le 15-03-2007 à 11:42:02
quelques nombres (plus note subjective) :
- 45° / 1500 rpm en idle (plutôt silencieux)
- 50° / ~2000 à 2500 rpm en utilisant des applis gourmandes (en faisant joujou avec le fullscreen d'itunes par exemple, un peu de bruit mais rien de grave)
- 60° / ~3500 à 4000 rpm en jeu (HL2 pour le test, bruit bien génant)
- 70° / 4500 rpm, la maximum, avec un cpu burner (bruit insupportable)
après 10 min de cpu burner (sp 2004 orthos edition) je n'ai pas vu la température monter au dessus de 70°
Message édité par jivede le 15-03-2007 à 11:43:35
Marsh Posté le 16-03-2007 à 11:57:33
oué bon à la limite c'est suportable vu que perso ça servira à matter de la HD avec un bon home ciné donc bon le bruit sera laaargement couvert :)
quelques toph seraient la bienvenue :)
Marsh Posté le 18-03-2007 à 19:27:00
Avec du retard en voila :)
Marsh Posté le 18-03-2007 à 20:21:19
Au niveau de l'alim, ya moyen de la changer? c'est quel type d'alim? comment elle est ventilé?
Marsh Posté le 20-03-2007 à 07:35:28
salut les mecs.moi aussi je voudrais un jouet comme ca,mais ce qui m'interesse vraiment c'est si le bruit est moins que acceptable,parce que j'ai lu sur quelques sites(http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16856110068 en anglais)  des opinions des gens qui l'ont utilise et ils disent tous que le barebone est bruyant comme un avion.je vais l'utiliser pas pour jouer que pour un home theater pc et j'ai des soupcons que le bruit sera fort si le vais lui donner des fichiers video en haute definition a decoder.je m'excuse pour les erreurs de langue parce que je parle pas tres bien votre langue.a bientot
Marsh Posté le 20-03-2007 à 18:00:50
Je n'ai pas encore reçu ma commande, mais pour le bruit à la limite tu peux changer le ventilo, c'est ce que je ferai s'il est trop bruyant.
