Main Memory 3 DDR DIMMs. Maximum memory size of 1.5GB. Support 128-bit system memory.
Slots One CNR Slot(Communication Network Riser). One AGP Slot. Note: AGP 2.0 2x/4x (1.5V only) Five PCI (v2.2) 32 bit Master PCI bus slots.
Onboard IDE An IDE controller on the MCP chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA 100 operation modes. Can connect to 4 IDE devices.
Video Shared with External Memory up to 32MB. 256-bit 2D/3D graphics accelerator. 2nd generation T&L engine, NVIDIA Shading Rasterizer (NSR). Multiplex DVI /TV interface with the AGP slot. (optional) PC 2001 compliant SMA and operates with 128-bit system memory installed.
Audio APU (Audio Processing Unit) integrated in MCP Support up to 256 hardware-processed voices or 64 hardware voices in 3D. Support multi-speaker 3D audio. S/PDIF out through external bracket.
Onboard peripherals 1 Floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes. 2 Serial ports (COM A + COM B) 6 USB ports (2 rear connectors and 2 USB front pin header to support four ports) 1 Parallel port supports SPP/EPP/ECP mode. 1 VGA connector. 1 IrDA connector. 1 Audio/Game port. 1 RJ-45 port.
BIOS The mainboard BIOS provides AMI "Plug & Play" Flash BIOS which detects the peripheral devices and expansion cards of the board automatically. The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension ATX Form Factor.
Mounting 6 mounting holes.
Quelqu'un a des infos sur cette carte mère ? Disponibilitée en france, prix...
[jfdsdjhfuetppo]--Message édité par beckman--[/jfdsdjhfuetppo]
Marsh Posté le 26-03-2002 à 23:32:28
Main Memory
3 DDR DIMMs.
Slots
Onboard IDE
Video
Network
Chip integrated 10/100 BaseT Ethernet/Fast Ethernet.
Audio
Onboard peripherals
1 VGA connector.
1 IrDA connector.
1 Audio/Game port.
1 RJ-45 port.
BIOS
Dimension
ATX Form Factor.
Mounting
6 mounting holes.
