Plextor - Hardware
Marsh Posté le 03-06-2002 à 10:09:54
j'ai rien compris non plus j'aimerais savoir aussi
surtout ke ca dit ke si on l'active ca sera plus lisible sur tous les lecteurs audio !
(up deguisé)
Marsh Posté le 03-06-2002 à 12:54:46
VariRec is a new tool sported by the PX-4012TA, which allows users to adjust laser power settings when burning CDs (note: VariRec will only function at 4x). Jitter is to some audiophiles a huge problem, for jitter affects the quality of sound on CD by having deeper or longer pits than the original copy. Plextor's solution is to let the user adjust the laser power settings on a small margin in order to make a more accurate sounding copy of their music.
Marsh Posté le 03-06-2002 à 09:49:08
Ca sert a quoi le varirec sur le 401240 ???
