Soluce pour reparer votre DDur IBM
Soluce pour reparer votre DDur IBM - Hardware
Marsh Posté le 25-02-2002 à 15:02:51
Voici, ce que j'ai trouvé sur un forum anglais, personellement
je n'achete que IBM depuis 2ans, et je n'ai jamais eu de problem
mais ca peut servir pour ceux qui onts des problems de bad sector
etc..
pour traduction, il vaut mieux que je ne traduis pas, apres
ca sera plus compliquer à comprendre :D
I have found a way of recovering a faulty IBM hardrive.
Scenario:-
The hard drive goes belly up, the dreaded clicking sound and no amount of scandisks or formating will recover it.
Sound familiar ?
Well get yourself to the IBM site and download the drive fitness test http://service.boulder.ibm.com/stor.../dft32-v230.exe (Windows flavour)
and the IBM feature tool
http://service.boulder.ibm.com/stor...ool-install.exe (Windows flavour)
Other OS's catered for on the IBM Drive site.
These should each create a bootable floppy.
Run the drive fitness test.
My HD made the most horrible squealing noises at this point, came back with sector errors, interface errors and unknown errors !?????
I tried to wipe it with the zero all sectors option, with no sucess. Note: this is also useful if you have an NTFS partition and you want to get rid of it !.
This should tell you if your drive is indeed duff, normaly, it would be time to relegate it to the trash bin.
Not necessarily so.
Now boot up off the other disk (IBM feature tool).
In the options, switch both read and write ahead caching off, set the acoustic level down to minimum, this I believe slows the head seek movement down and I also had the power saving set to HD slow down rpm in power saving mode.
Now Boot off the Drive fitness disk again and zero all the sectors, with luck, it will now work.
Why? I can only assume that the drive loses track of where it is on the platter due to a dropout of formatting information on the disk, and with the high speed of the head positioning arm, it misses the track.
Slowing everything down gives it a chance to find the correct track sector etc.
You may be wondering why I suspect this is the problem?
I had a complete system failure using this HD some time ago, luckily I managed to track down the faulty file and replace it. Upon closer examination of the file, I found that a track worths of zeros had mysteriously appeared in the middle of it. It would indicate, that whilst writing the data to the HD, it skipped a track, but upon reading at bootup, it read it alright.
Also the squealing noise is the head positioning system desperately trying to move the heads to the next track, which the HD knows exist, but does not know that the head mechanism has already got to the physical end of it's travel, since it has skipped tracks.
If it zero's OK, do an advanced test just for good measure.
Boot up off the IBM feature tool disk, set all the caches back on and the speeds up to full, acoustic levels to loudest (max performance).
Once done, you should have a fully working IBM Hard disk again!.
I have ran test after test on mine and am using it again without a single glitch !.
At the moment, I don't know if this is a temperature related fault so I have fitted mine into cooldrive 2 cases just in case, it may be worth testing a drive with the temperature monitor utility on one of the bootable floppies to see what sort of uncooled temperature these drives can get too, then artifically heating the drive to the same temp, NO NAKED FLAMES !, then run Scandisk or some other utility to carry out a surface test on the Drive.
It may be worth leaving the acoustic level down a notch or two if the HD plays up again, this will of course slow the seek times down a little, but I hardly think you would notice it.
Hope you have some success.
Andrew Cichocki.
__________________
James Dagger,
Merci Andrew! (si ca marche) :)
[jfdsdjhfuetppo]--Message édité par digitalica--[/jfdsdjhfuetppo]
Marsh Posté le 25-02-2002 à 20:45:26
Traduction:
J'ai trouvé une voie de récupérer IBM défectueux hardrive.
Scénario: -  Le lecteur dur monte ventre, le bruit cliquetant
redouté et aucune quantité de scandisks ou de formating ne le
récupérera.  Familier sain?  Le puits s'obtiennent au site d'cIbm et
téléchargent l'essai http://service.boulder.ibm.com/stor...
/dft32-v230.exe (saveur de forme physique d'entraînement de Windows)
et l'outil http://service.boulder.ibm.com/stor... ool-install.exe
(saveur de dispositif d'cIbm de Windows) l'autre OS's couvert sur le
site d'entraînement d'cIbm.  Ceux-ci si chacun crée un disque souple
amorçable.
Exécutez l'essai de forme physique d'entraînement.  Mon HD fait les
bruits de couinement les plus horribles en ce moment, est revenu avec
des erreurs de secteur, des erreurs d'interface et le!????? inconnu
d'erreurs  J'ai essayé de l'essuyer avec la toute l'option nulle de
secteurs, sans des sucess.  Note:  c'est également utile si vous
faites vouloir une cloison et à vous de NTFS se débarasser d'elle!.
Ceci devrait vous indiquer que si votre lecteur est en effet duff,
normaly, il serait temps de le reléguer au coffre de détritus.  Pas
nécessairement ainsi.
Amorcez maintenant vers le haut de outre de l'autre disque (outil de
dispositif d'cIbm).  Dans les options, commutez lu et écrivez cacher
en avant hors fonction, déposent le niveau acoustique au minimum,
ceci que je crois ralentit le mouvement principal de recherche vers le
bas et j'ai également fait placer l'économie de puissance au
ralentissement T/MN de HD dans le mode d'économie de puissance.
Maintenant la botte outre du disque de forme physique d'entraînement
encore et mettent tous les secteurs, avec la chance, elle travaillera
maintenant.  Pourquoi?  Je puis seulement supposer que le lecteur
détruit la piste d'où il est sur le champ de cablage à couches
multiples dû à un renvoi d'information de formatage sur le disque,
et avec la grande vitesse du bras de positionnement principal, il
manque la piste.  Le ralentissement de tout lui donne vers le bas une
chance de trouver le secteur correct etc.. de piste.
et voila !!! :D  :sol:
Marsh Posté le 17-03-2002 à 16:56:41
les logiciels dont tu donnes les liens sont pas accesibles
Est ce que tu pourrais me les envoyer ?
Marsh Posté le 17-03-2002 à 17:00:05
J'ADORE LA TRADUCTION. :love:
Marsh Posté le 17-03-2002 à 17:04:36
t1 ca m'enerve j'ai mon 46 go qui vient de me lacher en faisant le bruit de clac clac et je peux pas le réparer
Marsh Posté le 17-03-2002 à 17:44:39
mon 60 Go m'a laché hier soir  :fou:  :fou:  :fou:
Faut absolument qque je trouve un moyen de le récuperer (ne serait-ce que temporairement) car j'ai toute ma musique dessus (45Go de mp3) et faut absolument que je la backup!!!  help :bounce:
Marsh Posté le 17-03-2002 à 17:49:07
Toi aussi ton dur fait un bruit bizarre ?
Marsh Posté le 17-03-2002 à 17:52:23
Soluce pour ne pas avoir à reparer votre DDur IBM => n'achetez pas IBM
C'est pas moi ! C'est Murphy !
Marsh Posté le 17-03-2002 à 18:14:24
un bruit bizarre?? Carrement!!!
tic - clack - bip (en boucle indéfiniment)
et il n'est plus reconnu au boot
Marsh Posté le 17-03-2002 à 18:19:50
mon dur aussi fait clac clac clac :((
alors quand je boot sou windows ca met 2h avant de charger
et reclac
g pus recuperer la moiti des donnees soit 1 partition sur 2 :((
tu passe par le rezo et tu partage ton disk
et la ca va pas ramer
Marsh Posté le 17-03-2002 à 18:27:21
Le miens ne fais pas clac click ping
c'est un Western  :D
Marsh Posté le 17-03-2002 à 19:03:34
et reclac
ouais pareil
il fait clac clac et met 4heures pour arriver sous win (je boot sur un autre dur)
Ensuite pour ouvrir l explorateur Windows ca met 4 heures
J'ai plus de réseau c ça mon prob
Marsh Posté le 17-03-2002 à 19:27:07
dit monssieur cmt tu fait pour avoir 45 Go de mp3...
je pige pas les types qui en on autant..t en a pour toute une vie a ecouter tous sa !!!
Marsh Posté le 17-03-2002 à 19:27:21
sinon desole je peu pas repondre a votre probleme ;-(
Marsh Posté le 17-03-2002 à 19:39:21
Moi aussi !! Mon 30Go vient de claquer aujourd'hui.
C'est pas le jour des IBM .....
Marsh Posté le 17-03-2002 à 19:44:15
c'est pas le quinquénat des ibm plutôt :D
Marsh Posté le 17-03-2002 à 20:14:04
simple! J'ai des gouts très éclectiques et j'écoute de la musique tout le temps (chez moi, au boulot, dans les transports,...)
Et encore 45 Go, c'est parce que j'ai du faire une sélection drastique et en suprimer pas mal.
Yen a qui peuvent se contenter de vivre avec quelques dizaines d'albums et la radio...pas moi! C'est une question deee mode de vie (déjà je ne supporte pas la radio).
Bref, avec ce disque qui lache c'est mon unique patrimoine qui s'évapore.
Marsh Posté le 17-03-2002 à 20:29:50
un disque dur ca se ventile !
je n'ai eu que des IBM sauf un western digital :
IBM 540 Mo
WD 1.3 Go
IBM 6.4 Go
IBM 10 Go DTLA
IBM 15 Go 75 GXP
IBM 40 Go 60 GXP
le 540 meg a son alim qui a lache au bout de 2 ou 3 ans
le WD tourne encore mais a un faible rythme et quel boucant !
les autres IBM tournent tous tres bien a l'exception du 6.4 gig mais c'est une troisiemme main et il a vraiment baroude celui la ...
mon 75 GXP et mon actuel 60 GXP ne m'ont JAMAIS cause de soucis ... quel est mon secret ? ils sont ventiles !
ca ne vous choquerait pas de voir des 10000 tours SCSI ne pas etre refroidis ? oui bien sur ! et bien c'est pareil avec nos 7200 tours ! un simple 80x80 en 7v suffit !
ca se preserve un DD, surtout quand on tient a ses donnees !
[jfdsdjhfuetppo]--Message édité par Batman-Fr--[/jfdsdjhfuetppo]
Tout ou rien mais rien que tout ! feed-back : http://forum.hardware.fr/forum2.ph [...] ost=121391
Marsh Posté le 17-03-2002 à 20:52:11
ouin j'arrive pas à le faire marcher mon dur :cry:
Marsh Posté le 17-03-2002 à 21:11:46
IBM 540 Mo
WD 1.3 Go
IBM 6.4 Go
IBM 10 Go DTLA
IBM 15 Go 75 GXP
IBM 40 Go 60 GXP
:lol: [:ddt] :lol:
le mec il y croit réellement en plus à son histoire de ventilation des hdd. et il compare un scsi 10krpm à un ide 7200rpm :sarcastic:
les IBM crèvent comme des mouches, c bien connu, ventilés ou non. si les tiens ne sont pas encore morts, c uniquement grace à la chance. tu verras que tes théories sur la ventilations vont vite s'envoler quand tes hdd d'entrée de gamme jettables vont commencer à faire crrr crrr crrr ou clac clac :lol:
[jfdsdjhfuetppo]--Message édité par Murphy--[/jfdsdjhfuetppo]
Marsh Posté le 17-03-2002 à 22:09:48
le mien il était ventilé et il est mort quand même.
Marsh Posté le 18-03-2002 à 00:09:59
il y a la meme chose pour les Western Digital qui font "clac-clac" ?
Marsh Posté le 18-03-2002 à 11:51:03
idem
Marsh Posté le 18-03-2002 à 11:58:27
pareil
faut pas rêver les gars...
Marsh Posté le 18-03-2002 à 12:00:37
Moi j'adore l "Familier sain"   :lol:  :lol:
Marsh Posté le 18-03-2002 à 12:13:22
bientot une nouvelle soluce pour vos HD ibm:
pour reparer un IBM vous l'ouvrez, nettoyer la tete a l'alcool ( des fois la tete est sale ! )
apres avec votre chiffon vous nettoyez les plateaux du HD !
si les plateaux sont un peu terne, prenez du vernis pour parquet et vernisser les !
non sans dec, un IBM ça marche vachement bien, suffit de savoir l'entretenir :o !
[jfdsdjhfuetppo]--Message édité par Chips--[/jfdsdjhfuetppo]
Marsh Posté le 18-03-2002 à 13:57:07
il y en a encore qui defend Ibm...ah, l'entetement humain...
Marsh Posté le 18-03-2002 à 14:10:30
IBM 540 Mo
WD 1.3 Go
IBM 6.4 Go
IBM 10 Go DTLA
IBM 15 Go 75 GXP
IBM 40 Go 60 GXP
J ai un 46gig IBM...
je le ventile avec un 8x8 en 12volts (bruits powwaaa)
bah ca l empeche pas de claquer et de me vernir de moulte secteurs defectueux...
Voici, l'histoire d'un nain capable...
Marsh Posté le 18-03-2002 à 14:42:49
:lol: [:ddt] :lol:
Je vais te raconter une histoire.
Un vendredi soir, y'a quelques mois, un copain m'appele catastrophé : son 30Go IBM vient de mourir devant ses yeux (pas tout à fait mort, il s'en apercevras plus tard, mais il à du mal à être detecté par le BIOS). Il vient l'essayer chez moi => dead.
Je part en we.
Il me rappele dimanche soir... 60Go IBM mort aussi (même verdict)...
indice : le pote en question n'est pas inquiet quand son tbird monte à 75° et sa tour est un véritable four. J'ai déjà eu l'occasion de mettre la main sur ses DD et il sont bouillants...
Perso j'ai 2 IBM : 20Go DTLA et 41Go 60GXP. Si tu les touches, ils sont FROIDS, quoi qu'ils fassent. Ma tour est bien ventilée, ils sont placés au bons endroits pour que ça chauffe pas.
Et j'ai jamais eu de pépins avec.
Maintenant quand IBM annonce 333h de fonctionnement par mois pour les 120GXP et les 60GXP, c'est sur, mon prochain DD seras pas un IBM !
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
Marsh Posté le 18-03-2002 à 19:17:43
:lol: [:ddt] :lol:
que tu n'adheres pas a mes propos, je n'ai rien n'a dire ...
mais de la a me parler comme ca, tu vas trop loin ...
je ne suis pas ton pote, alors calme toi un peu ...
 [:carambar eloustic]
Marsh Posté le 19-03-2002 à 00:01:57
pas tout à fait mort?? Tu peux m'exliquer car j'aimerai bien que le mien vive encore un peu, juste le temps de faire un backup (mon bios ne le détecte plus)
