Les alim les + performantes : tensions, bruit... c'est ici. [Sondage] - Hardware
Marsh Posté le 18-05-2002 à 12:28:46
TTGI, légèrement moins bruyantes que les Enermax, nettement moins chères, voltages mieux respectés (malgré ma config de "titan" )...
(TTGI 500W triple ventilée)
Marsh Posté le 18-05-2002 à 12:29:52
fortron : silence, mais voltage un peu leger.
a savoir; y'a 10 connecteur.
edit.
*  fortron
http://www.fortron-source.com/
NB: c FSP GROUP
existe en 300-350 et 400w.
Features
CSA, UL, IEC, VDE, NEMKO, TUV, FCC Certified
High Efficiency
Low Noise and Ripple
Output over Voltage Protection
Short Circuit Protection on all Outputs
Resettable Power Shut Down
Internal 12 VDC Fan Provided
100% Burn-in under High Ambient Temperature
MTBF Above 100,000 Hrs at 25 Degree Celsius
100% Hi-pot & ATE Tested
Built-in EMI Filter
Input Characteristics
Voltage: 95-132 VAC or 180-264 VAC Switchable
Frequency: 47Hz to 63 Hz
Input Current: 10 Amps Maximum/115 Vrms, 60 Hz; 5 Amps Maximum/230 Vrms, 50Hz
Output Characteristics
Output Voltage Min. Load Normal Load Max. Load
+3.3V   0.2A    14.0A    0.2/14A
+5V     2.0A    14.0A    30/20.7A
+12V    0.2A    6.0A     11.0A
-12V    0.0A    0.4A     0.8A
-5V     0.0A    0.15A    0.3A
+5Vsb   0.0A    1.0A     2.0A
Specification
Remote ON/OFF Control: The power supply shall accept a logic collector level which will disable/enable all output voltage (excluding +5V standby).
Temperature Range: Operating O Deg. Celsius ~ 50 Degree Celsius;
Non-operating Range: -20 Deg. C ~ +80 Deg. C
Temperature Coefficient: 0.01 % Deg. C
Transient Response: Output Voltage Returns in less than 1 ms Max. following a 35% Load Change
Hold Up Time: 16ms Min. at Full Load & Nominal Input Voltage
Dielectric Withstand: Input/Output 1800 VAC for 1 Sec. Input to Frame Ground 1800 VAC for 1 Sec.
Humidity: 90~95% RH
Efficiency: 65% Min., 70% Typical, at Full Load
Power Good Signal: On Delay 100ms to 500ms, Off Delay 1ms
Overload Protection: 150% Max
Inrush Current: 45A Max. for 115 VAC or 80A Max for 230 VAC at 25 Deg. C Ambient Cold Start
Over Voltage Protection: +5V Output: 6.5V;  +3.3V Output: 4.6V; +12V Output: 15.5V
+   TTGI = SUPERFLOWER d'apres risko.
http://www.ttgiusa.com/
test sur jacky pc
http://www.jackypc.com/index2.php3 [...] 143&next=1
MODELES/
300SS(12V,320W)
370SS(12V,350W)
400SS(12V,420W)
Specifications:
Model No: TTGI TT-300SS (320W).
AC Input: 115/230Vac, 8/4A, 60/50Hz.
 DC Output:
+3.3V~20.0A, +5V~30.0A,
+12V~16.0A. +5Vsb~2A,
-5V~0.5A,
-12V~0.8A).
 MAX OUTPUT POWER: 300W.
Four IDE connectors, two floppy connectors.
Features
Dual Fan design of E type P.S
Dual 8 cm Ball Bearing fans:  CFM=28.50, RPM = 2200, Noise Level = 25 db
Top quality Steel sheet metal case
Cable tube tied ( TT400SS and TT500SS only)
Silent Operation
AMD desirable Thermal Mechanical version
Meet K7 and Intel 2.03 Version.
+ 5 Vsb = 2.0A
Output over voltage protection. Short circuit protection on all output levels.
Low Ripple and Noise
Overcurrent Protection
Fan speed monitoring function for new MB
Noiseless and longer life
High MTBF >100,000 hours
Long power leads (15" )
on complete.
400W
Spécifications Techniques
Caractéristiques techniques
Alimentation ATX 400w ventilée
Conforme aux normes ATX 2.03 et PFC
Alimentation agrée AMD Athlon XP 2100+
2 ventilateurs auto-régulés
Connecteurs
  1 connecteur ATX 20 broches
  1 connecteur AUX 6 broches (Pentium 4)
  1 connecteur 12v 4 broches (Pentium 4)
  8 connecteurs 4 broches Molex pour périphériques 5"1/4
  2 connecteurs 4 broches Molex pour périphériques 3"1/2
Fonctionalités avancées
Le 2ème ventilateur permet l'extraction de la chaleur dégagée par le CPU
Accessoires fournis   Cordon d'alimentation
  Kit de visserie
Attention
Cette alimentation est commercialisée sous plusieurs marques : TTGI et Superflower (marque suivant arrivages). Dans tous les cas il s'agit d'une alimentation conçue par TTGI et agréée par AMD.
500W
Alimentation ATX 500w ventilée
3 ventilateurs auto-régulés
Connecteurs
 10 connecteurs 4 broches Molex pour périphériques 5"1/4
Ventilateur arrière 90mm avec régulateur de vitesse manuel
2 ventilateurs 80 mm (avant + dessous) à vitesse regulée par la température du système
Accessoires fournis
  Kit de visserie
550W
Alimentation ATX 550w ventilée
Connecteurs
Accessoires fournis
 Kit de visserie
merci Hemlish
le 5 v est bon le 12 un peu bas.
+        LA nenermax
a lire pour completer
http://www.mikhailtech.com/articles/psu/enermax365fca/
EG365P-VE FCA et  EG465P-VE FCA
Model No.
                        EG365P-VE FCA         EG465P-VE FCA
I/P
 Voltage rating
 90V~135V AC or 180V~264V AC
(selected by slide switch)
                                   Iin=115/230Vac
                          10A / 6A                 12A / 7A
Frequency
 47Hz~63Hz
Inrush current
                         40A max. / 115V;      80A max. / 230V
3.3V     50mV               0A / 32A              0A / 38A
+5V      50mV               8A / 32A             11A / 44A
+12V     120mV             4.25A / 17A            5A / 20A
-5V       50mV               0A / 1A              0A / 2A
-12V     120mV               0A / 1A              0A / 1A
+5Vsb     50mV              0A / 2.2A             0A / 2.2A
3.3V & +5V                     185W                 220W
TOTAL O/P                      350W                 431W
Enermax EG301P-VE-FMA - 300w double ventilateur
Alimentation ATX 300w ventilée
Conforme aux normes ATX 2.03 & Intel ATX +12V 1.1
Compatible Intel Pentium 4
Produit recommandé par AMD !
Ventilateur inférieur 90 mm auto-régulé
Ventilateur arrière 80 mm à réglage manuel
Connecteurs
1 connecteur Molex 3 pins pour le monitoring de la vitesse du ventilateur
6 connecteurs 4 broches Molex pour périphériques 5"1/4
Longueur des câbles : 600 mm
Connecteurs plaqués or pour un meilleur contact et eviter la corrosion
Regulation de la vitesse du ventilateur 80 mm par potentiomètre & monitoring par la carte mère
Ventilateur 90 mm pour optimiser l'extraction de la chaleur dégagée par le processeur
Faible niveau sonore (29 db)
Enermax EG365AX-VE-FMA - 353w double ventilateur
Alimentation ATX 353w ventilée
Conforme aux normes ATX 2.03, Intel ATX +12V 1.1 & PFC
compatible Intel Pentium 4
Connecteurs
Longueur des câbles : 800 mm
Connecteurs plaqués or pour un meilleur contact et eviter le corrosion
regulateur de vitesse du ventilateur manuel
Monitoring de la vitesse du 2eme ventilateur par la carte mère
Suivi des recommandations AMD concernant l'extraction de chaleur
Enermax EG365P-VE-FMA - 350w double ventilateur
Alimentation ATX 350w ventilée
Connecteurs
 Enermax EG465AX-VE-FMA - 433w double ventilateur
Alimentation ATX 433w ventilée
Connecteurs
Regulateur de vitesse du ventilateur manuel
Enermax EG651P-VE-FMA - 550w double ventilateur
Connecteurs
[#0000ff]11 connecteurs 4 broches Molex pour périphériques 5"1/4
1 connecteur 4 broches Molex pour périphériques 3"1/2 [/#c63800]
et la derniere qui est toute moche
+    la cwt
http://www.mikhailtech.com/articles/psu/cwt420/
Output  Voltage  Regulation  Min. Load  Max. Load  Ripple
V1        +5V      +/- 5%       2.0A      40A       50mV
V2        +12V     +/- 5%       0.3A      18A       100mV
V3        -12V     +/- 10%       0A       1.0A      100mV
V4         -5V      +/- 5%       0A       1.0A      50mV
V5         +3,3V    +/- 5%      0.3A      28A       50mV
V6        +5Vsb     +/- 5%       0A       3.0A      50mV [undefined]
[jfdsdjhfuetppo]--Message édité par machistador le 19-05-2002 à 00:23:55--[/jfdsdjhfuetppo]
Marsh Posté le 18-05-2002 à 12:31:00
| machistador a écrit a écrit  : fortron : silence, mais voltage un peu leger.  |
Marsh Posté le 18-05-2002 à 12:38:46
| sachy a écrit a écrit  : TTGI, légèrement moins bruyantes que les Enermax, nettement moins chères, voltages mieux respectés (malgré ma config de "titan" )... (TTGI 500W triple ventilée)  |
euh. tu aime bien jeter de l'argent par la fenetre ?
  Parce que pour ta config, une alim de 350 w aurait LARGEMENT suffit
enfin au moins tu fais marcher le commerce
Marsh Posté le 18-05-2002 à 12:40:03
cool je cherchais justement un topic comme celui-là pcq je vais m'en acheter une d'ici peu...
Marsh Posté le 18-05-2002 à 12:40:04
| hacker a écrit a écrit  : euh. tu aime bien jeter de l'argent par la fenetre ? enfin au moins tu fais marcher le commerce  |
Non, 350W j'avais des problèmes
Et puis t'a pas à me juger je fais ce que je veux.
De plus, 500W TTGI = 350W/450W Enermax niveau prix donc bon
[jfdsdjhfuetppo]--Message édité par sachy le 18-05-2002 à 12:41:18--[/jfdsdjhfuetppo]
Marsh Posté le 18-05-2002 à 12:40:46
| sachy a écrit a écrit  : Non, 350W j'avais des problèmes  |
 avec quel alim ?(marque?)
Marsh Posté le 18-05-2002 à 12:41:46
| hacker a écrit a écrit  : |
Enermax
>>>+5V
Marsh Posté le 18-05-2002 à 12:44:25
kenshirooo --> oui une 350 sera largement suffisante
sachy --> c'est vrai que le 5v peine chez enermax, mais la c'est pas la puissance qui est en cause
Marsh Posté le 18-05-2002 à 12:46:46
| hacker a écrit a écrit  : kenshirooo --> oui une 350 sera largement suffisante sachy --> c'est vrai que le 5v peine chez enermax, mais la c'est pas la puissance qui est en cause  |
je me prendrais bien celle la
http://www.eurisko.fr/fiche.php?da [...] 52ZXJ0PQ==
j ai une noname qui commence a vieillir
elle est correcte niveau volatagge mais niveau ventilation c est pas trop ça(y a tres peu d air qui sort derriere)
je vais gagner des degres ac celle la?
Marsh Posté le 18-05-2002 à 12:50:56
bin si c'est juste pour fair baisser la T° de ton boitier, achète des ventilo suplémentair (comme les enermax réglables) plutot qu'une alim vu que la tienne marche encore bien
Marsh Posté le 18-05-2002 à 12:52:53
| hacker a écrit a écrit  : bin si c'est juste pour fair baisser la T° de ton boitier, achète des ventilo suplémentair (comme les enermax réglables) plutot qu'une alim vu que la tienne marche encore bien  |
bein les ventilos c est deja fait (aqua 690 +ernemax 80)mais je me disais comme alim ac double ventilo pouvait jouer aussi
Marsh Posté le 18-05-2002 à 12:58:54
oui mais met des ventilo en aspiration et en extraction dans ton boitier tu verra...
c'est quoi la T° a l'interieur de ton boitier la ^?
Marsh Posté le 18-05-2002 à 13:02:56
| hacker a écrit a écrit  : oui mais met des ventilo en aspiration et en extraction dans ton boitier tu verra... c'est quoi la T° a l'interieur de ton boitier la ^?  |
bein niveau ventilos j ai
-un ernemax 80 en aspi en bas
-un aqua 690 sur le proco (ac de la artic silver tt comme y faut)
-un evercool 5cm en extraction a cote du proc
-un autre 8 cm en haut de la tour en aspi
-les 2 ventilos de ma GF4
-mon petit ventilo de chipset
il fait 25 dans ma piece
et j ai 55 deg pour le  proco
et 35 pour ala mobo ordi ferme
Marsh Posté le 18-05-2002 à 13:06:14
| kenshirooo a écrit a écrit  : bein niveau ventilos j ai -un ernemax 80 en aspi en bas -un aqua 690 sur le proco (ac de la artic silver tt comme y faut) -un evercool 5cm en extraction a cote du proc -un autre 8 cm en haut de la tour en aspi met le en extraction !!! -les 2 ventilos de ma GF4 -mon petit ventilo de chipset il fait 25 dans ma piece et j ai 55 deg pour le proco et 35 pour ala mobo ordi ferme donc dans la tour  |
je vais te dire: en achetant une autre alim tu va (presque) rien gagner
[jfdsdjhfuetppo]--Message édité par hacker le 18-05-2002 à 13:06:39--[/jfdsdjhfuetppo]
Marsh Posté le 18-05-2002 à 13:07:34
| hacker a écrit a écrit  : je vais te dire: en achetant une autre alim tu va (presque) rien gagner  |
je le met en extraction pour qu il soufle vers l exterieur alors?
je peux faire quoi encore pour ameliorer mes perf niveau temp?
[jfdsdjhfuetppo]--Message édité par kenshirooo le 18-05-2002 à 13:08:26--[/jfdsdjhfuetppo]
Marsh Posté le 18-05-2002 à 13:11:45
cf risko :
Equipée de deux ventilateurs montés sur roulements à billes, la TT-350SS est peu bruyante (25 dB)
vous confirmez ???
c la TTGI 350W dont je parle
Marsh Posté le 18-05-2002 à 13:13:10
mode chieur on:
ca vous dis pas de faire un topic propre?
avec les spec et tout!?
mode chieur off:
Marsh Posté le 18-05-2002 à 13:16:07
| machistador a écrit a écrit  : mode chieur on: ca vous dis pas de faire un topic propre? avec les spec et tout!? mode chieur off:  |
Marsh Posté le 18-05-2002 à 13:17:02
mais c vrai quoi!
zou j'essaye fortron, si je trouve.
[jfdsdjhfuetppo]--Message édité par machistador le 18-05-2002 à 13:17:24--[/jfdsdjhfuetppo]
Marsh Posté le 18-05-2002 à 13:19:04
CWT 420W potarisée Powaaaaaaa
5V nickel avec une conf ki suce pas mal
en plus thermorégulée
Marsh Posté le 18-05-2002 à 13:52:38
pourquoi dès qu'on leur demande de bosser y'a plus personne?
[jfdsdjhfuetppo]--Message édité par machistador le 18-05-2002 à 13:53:20--[/jfdsdjhfuetppo]
Marsh Posté le 18-05-2002 à 14:26:59
Ouais si tu veux
Marsh Posté le 18-05-2002 à 15:55:26
TTGI est-il réellement si supérieur que cela à ENERMAX en terme de voltages ?
Si vous ne deviez pas regarder au prix prendriez-vous sans hésiter ENERMAX ou TTGI ?
Pour les amis belges, connaissez vous des magasins en belgique qui vendent les alimentations TTGI ?
Marsh Posté le 18-05-2002 à 16:37:19
| Laurent2019 a écrit a écrit  : TTGI est-il réellement si supérieur que cela à ENERMAX en terme de voltages ? Si vous ne deviez pas regarder au prix prendriez-vous sans hésiter ENERMAX ou TTGI ?  |
Moi jprendrais CWT
Marsh Posté le 18-05-2002 à 17:18:23
qui a les spec des cwt?
faudrais les nenermax, mais je cherche pas vu que je les aiment pas!
Marsh Posté le 18-05-2002 à 17:21:12
ReplyMarsh Posté le 18-05-2002 à 17:23:34
danke
j'édite pour la rajouter.
et pour la nenermax:
nb: c un coup de bol, y'avais un lien direct.
[jfdsdjhfuetppo]--Message édité par machistador le 18-05-2002 à 17:25:11--[/jfdsdjhfuetppo]
Marsh Posté le 18-05-2002 à 18:04:24
J'ai une chieftec 340 W dont je suis tres content
les tension sont stables et il y a '2 mode de ventilation'
si  je branche le monitoring, ca ventille à 3000 tr min et  ca fait du bruit sinon c'est à 1500 et c'est silencieux
Marsh Posté le 18-05-2002 à 18:05:13
| waloof a écrit a écrit  : moi je dis MOREX ...  |
c koi le pb ac les morex?
Marsh Posté le 18-05-2002 à 18:10:23
| fute77 a écrit a écrit  : J'ai une chieftec 340 W dont je suis tres content les tension sont stables et il y a '2 mode de ventilation' si je branche le monitoring, ca ventille à 3000 tr min et ca fait du bruit sinon c'est à 1500 et c'est silencieux  |
lé bien celle aussi mais moi jl'ai revendue paske je croyais que y'avait po de potar alors que y'en avait un
tes 2 modes c artisanal ?
Marsh Posté le 18-05-2002 à 18:25:48
ReplyMarsh Posté le 18-05-2002 à 18:28:18
| pierrotlemaboule a écrit a écrit  : |
elles sont bleues elees sont bien!
non c pas comme ca que ca fonctionne?
ah bon, je croyais!
Marsh Posté le 18-05-2002 à 11:01:38
Salut.
Je souhaite réaliser ce petit sondage pour aiguiller les gens (telles que moi) qui ne savent pas quelle marque d'alimentation choisir.
Ce sondage a pour but de récolter un maximum d'infos sur les marques en générales et leurs caractéristiques (bruit, tensions tables et justes...).
Voilà, si vous avez des remarques... n'hésitez pas !
Merci.
[jfdsdjhfuetppo]--Message édité par Hemlish le 18-05-2002 à 11:02:54--[/jfdsdjhfuetppo]
