printing problems? solution here
printing problems? solution here - Imprimante - Hardware - Périphériques
Marsh Posté le 07-01-2010 à 11:10:14
Sirs,
as you experienced very well, Windows creates a lot of problems in plotting CAD/Cutting/Engraving works.
The problem is that Windows, Plotters and Applications usually don't give good drivers, up-to-date or they don't give at all for old plotters.
Common problems with other Windows plotter drivers include:
Unrecoverable Application Errors
General Protection Faults
Out of bounds pen movements
Incorrect line style
Poor performance for wide lines
Errors rendering arcs
Spurious lines
Incomplete plot
Low resolution affecting curve smoothness
Polygon fills do not take account of pen widths
Incorrect text sizing, positioning and/or rotation
Drawing does not fit on the sheet
Output data size up to ~10x larger than drawing size
Slow plot generation
Incomplete paper size support
Jagged rendering of diagonal lines
Incorrectly joined polylines
Lack of support for HPGL and DMPL languages
Driver does not exist for the plotter model
Problems with mixed files vector+raster, OLE objects
We can offer a solution: a Third Party Product for all plotter and large format inkjet/laser printers: drivers have been engineered by Vector Driver Experts to drive your plotter, cutter or engraver efficiently from popular Windows applications and to create efficient HPGL files suitable for document management systems and downstream usage.
And they are those recommended from HP, Autodesk and many Others and work great with all CAD Applications and Corel Draw, Power Point, Micrografx Designer, EXCELL, Lotus, Word and all vectorial-oriented Windows applications, under W95, W98, WME, NT 4.0, W2000, WinXP, Win VISTA, Win 7 32-64
On a flatbad plotter it supports a work area of up to:
Maximum Width: 100,000mm (3,937 inches)
Maximum Length: 100,000mm (3,937 inches).
Supports long page sizes on DesignJet and Vinyl Cutters (up to 200m or 660 feet).
Please go here and give a contact: you'll receive all informations in English language
www dot plotterdriver dot it
>>>info
Marsh Posté le 07-01-2010 à 13:28:11
casella a écrit :
Sirs,
Spurious lines
Incomplete plot
>>>info
Thanks for your information, bur your site address is not operational. Correct it, please.
Best regards.
Noël Bouvet
Marsh Posté le 07-01-2010 à 15:28:09
? L'adresse est correcte (il faut évidemment remplacer dot par un point "." )
Marsh Posté le 07-01-2010 à 16:34:26
Yes Sir, but it is necessary to insert an URL syntax on this forum, like this :
www.plotterdriver.it
Best regards.
Noël Bouvet
Message édité par papynono le 07-01-2010 à 16:35:06
Marsh Posté le 07-01-2010 à 16:37:14
>>>info
Message édité par casella le 07-01-2010 à 16:43:41
