problème d'installation de policykit-qt - Installation - Linux et OS Alternatifs
MarshPosté le 13-08-2009 à 22:21:18
Bonsoir, je ne parviens pas à installer (sous Gentoo) policykit-qt ! =>
>>> Emerging (2 of 2) sys-auth/policykit-qt-0.9.2 * polkit-qt-0.9.2.tar.bz2 RMD160 SHA1 SHA256 size ;-) ... [ ok ] * checking ebuild checksums ;-) ... [ ok ] * checking auxfile checksums ;-) ... [ ok ] * checking miscfile checksums ;-) ... [ ok ] >>> Unpacking source... >>> Unpacking polkit-qt-0.9.2.tar.bz2 to /var/tmp/portage/sys-auth/policykit-qt-0.9.2/work >>> Source unpacked in /var/tmp/portage/sys-auth/policykit-qt-0.9.2/work >>> Preparing source in /var/tmp/portage/sys-auth/policykit-qt-0.9.2/work/polkit-qt-0.9.2 ... >>> Source prepared. >>> Configuring source in /var/tmp/portage/sys-auth/policykit-qt-0.9.2/work/polkit-qt-0.9.2 ... >>> Working in BUILD_DIR: "/var/tmp/portage/sys-auth/policykit-qt-0.9.2/work/polkit-qt-0.9.2_build" cmake -C /var/tmp/portage/sys-auth/policykit-qt-0.9.2/temp/gentoo_common_config.cmake -DCMAKE_INSTALL_PREFIX=/usr -DBUILD_examples=OFF -DBUILD_EXAMPLES=OFF -DBUILD_Examples=OFF -DCMAKE_BUILD_TYPE=Gentoo -DCMAKE_INSTALL_DO_STRIP=OFF -DCMAKE_USER_MAKE_RULES_OVERRIDE=/var/tmp/portage/sys-auth/policykit-qt-0.9.2/temp/gentoo_rules.cmake /var/tmp/portage/sys-auth/policykit-qt-0.9.2/work/polkit-qt-0.9.2 loading initial cache file /var/tmp/portage/sys-auth/policykit-qt-0.9.2/temp/gentoo_common_config.cmake -- The C compiler identification is GNU -- The CXX compiler identification is GNU -- Check for working C compiler: /usr/bin/i686-pc-linux-gnu-gcc -- Check for working C compiler: /usr/bin/i686-pc-linux-gnu-gcc -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working CXX compiler: /usr/bin/i686-pc-linux-gnu-g++ -- Check for working CXX compiler: /usr/bin/i686-pc-linux-gnu-g++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Looking for Q_WS_X11 -- Looking for Q_WS_X11 - found -- Looking for Q_WS_WIN -- Looking for Q_WS_WIN - not found. -- Looking for Q_WS_QWS -- Looking for Q_WS_QWS - not found. -- Looking for Q_WS_MAC -- Looking for Q_WS_MAC - not found. -- Found Qt-Version 4.5.1 (using /usr/bin/qmake) -- Looking for XOpenDisplay in /usr/lib/libX11.so;/usr/lib/libXext.so -- Looking for XOpenDisplay in /usr/lib/libX11.so;/usr/lib/libXext.so - found -- Looking for gethostbyname -- Looking for gethostbyname - found -- Looking for connect -- Looking for connect - found -- Looking for remove -- Looking for remove - found -- Looking for shmat -- Looking for shmat - found -- Looking for IceConnectionNumber in ICE -- Looking for IceConnectionNumber in ICE - found -- Found X11: /usr/lib/libX11.so -- Looking for include files CMAKE_HAVE_PTHREAD_H -- Looking for include files CMAKE_HAVE_PTHREAD_H - found -- Looking for pthread_create in pthreads -- Looking for pthread_create in pthreads - not found -- Looking for pthread_create in pthread -- Looking for pthread_create in pthread - found -- Found Threads: TRUE -- Found Automoc4: /usr/bin/automoc4 -- checking for module 'polkit>=0.8' -- package 'polkit>=0.8' not found CMake Error at cmake/modules/FindPkgConfig.cmake:270 (message): A required package was not found Call Stack (most recent call first): cmake/modules/FindPkgConfig.cmake:322 (_pkg_check_modules_internal) CMakeLists.txt:17 (pkg_check_modules)
-- checking for module 'polkit-dbus>=0.8' -- package 'polkit-dbus>=0.8' not found CMake Error at cmake/modules/FindPkgConfig.cmake:270 (message): A required package was not found Call Stack (most recent call first): cmake/modules/FindPkgConfig.cmake:322 (_pkg_check_modules_internal) CMakeLists.txt:18 (pkg_check_modules)
-- checking for module 'polkit-grant>=0.8' -- package 'polkit-grant>=0.8' not found CMake Error at cmake/modules/FindPkgConfig.cmake:270 (message): A required package was not found Call Stack (most recent call first): cmake/modules/FindPkgConfig.cmake:322 (_pkg_check_modules_internal) CMakeLists.txt:19 (pkg_check_modules)
-- Configuring incomplete, errors occurred! * * ERROR: sys-auth/policykit-qt-0.9.2 failed. * Call stack: * ebuild.sh, line 49: Called src_configure * environment, line 2831: Called cmake-utils_src_configure * environment, line 796: Called die * The specific snippet of code: * cmake ${cmakeargs} "${CMAKE_USE_DIR}" || die "cmake failed"; * The die message: * cmake failed * * If you need support, post the topmost build error, and the call stack if relevant. * A complete build log is located at '/var/tmp/portage/sys-auth/policykit-qt-0.9.2/temp/build.log'. * The ebuild environment file is located at '/var/tmp/portage/sys-auth/policykit-qt-0.9.2/temp/environment'. *
>>> Failed to emerge sys-auth/policykit-qt-0.9.2, Log file:
* Messages for package sys-auth/policykit-qt-0.9.2:
Y eu une dépendance qui s'est installé mais avec un problème, ils'agit de sys-auth/policykit-0.92 =>
Marsh Posté le 13-08-2009 à 22:21:18
>>> Unpacking source...
>>> Source prepared.
-- <<< Gentoo configuration >>>
Build type: Gentoo
Install path: /usr
* Call stack:
* The die message:
* cmake failed
* Call stack:
* The die message:
* cmake failed
PolicyKit-1.xml:5: warning: failed to load external entity "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd"
I/O error : Attempt to load network entity http://www.oasis-open.org/docbook/ [...] cbookx.dtd
polkitd-1.xml:5: warning: failed to load external entity "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd"
pkexec.xml:5: warning: failed to load external entity "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd"
Note: Writing polkitd-1.8
Note: Writing pkexec.1
Note: Writing PolicyKit-1.8
/usr/bin/xsltproc -nonet --stringparam man.base.url.for.relative.links /usr/share/gtk-doc/html/polkit-1/ --xinclude http://docbook.sourceforge.net/rel [...] ocbook.xsl pkcheck.xml
/usr/bin/xsltproc -nonet --stringparam man.base.url.for.relative.links /usr/share/gtk-doc/html/polkit-1/ --xinclude http://docbook.sourceforge.net/rel [...] ocbook.xsl pkaction.xml
pkcheck.xml:5: warning: failed to load external entity "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd"
pkaction.xml:5: warning: failed to load external entity "http://www.oasis-open.org/docbook/xml/4.1.2/docbookx.dtd"
Je ne comprends rien, je suis pas assez calé là.... si qqun peut m'aider
