problème lilo : volid read error
problème lilo : volid read error - Installation - Linux et OS Alternatifs
Marsh Posté le 21-08-2003 à 21:56:44
désolé, mais c'est un peu long, mais je fourni tout
[root@athlon boot]# lilo
Fatal: volid read error
voici la table de mes partitions
[root@athlon boot]# fdisk -l /dev/hda
Disk /dev/hda: 40.0 GB, 40027029504 bytes
255 heads, 63 sectors/track, 4866 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
   Device Boot    Start       End    Blocks   Id  System
/dev/hda1   *         1       191   1534176    7  HPFS/NTFS
/dev/hda2           192      2738  20458777+   7  HPFS/NTFS
/dev/hda3          2739      4866  17093160    f  Win95 Ext'd (LBA)
/dev/hda5          2739      3747   8104761    7  HPFS/NTFS # mon /home, bizarrement, le format n'est pas bon...
/dev/hda6          3748      4800   8458191   83  Linux # mon /
/dev/hda7          4801      4866    530144+  82  Linux swap
et mon lilo.conf
# Support LBA for large hard disks.
lba32
# Overrides the default mapping between harddisk names and the BIOS'
# harddisk order. Use with caution.
#disk=/dev/hde
#    bios=0x81
#disk=/dev/sda
#    bios=0x80
# Specifies the boot device.  This is where Lilo installs its boot
# block.  It can be either a partition, or the raw device, in which
# case it installs in the MBR, and will overwrite the current MBR.
boot=/dev/hda
# Specifies the device that should be mounted as root. (`/')
root=/dev/hda6
# Enable map compaction:
# Tries to merge read requests for adjacent sectors into a single
# read request. This drastically reduces load time and keeps the
# map smaller.  Using `compact' is especially recommended when
# booting from a floppy disk.  It is disabled here by default
# because it doesn't always work.
# compact
# Installs the specified file as the new boot sector
# You have the choice between: bmp, compat, menu and text
# Look in /boot/ and in lilo.conf(5) manpage for details
# n'existe pas
install=/boot/boot-menu.b
# Specifies the location of the map file
map=/boot/map
# You can set a password here, and uncomment the `restricted' lines
# in the image definitions below to make it so that a password must
# be typed to boot anything but a default configuration.  If a
# command line is given, other than one specified by an `append'
# statement in `lilo.conf', the password will be required, but a
# standard default boot will not require one.
# This will, for instance, prevent anyone with access to the
# console from booting with something like `Linux init=/bin/sh',
# and thus becoming `root' without proper authorization.
# Note that if you really need this type of security, you will
# likely also want to use `install-mbr' to reconfigure the MBR
# program, as well as set up your BIOS to disallow booting from
# removable disk or CD-ROM, then put a password on getting into the
# BIOS configuration as well.  Please RTFM `install-mbr(8)'.
# password=tatercounter2000
# Specifies the number of deciseconds (0.1 seconds) LILO should
# wait before booting the first image.
delay=20
# You can put a customized boot message up if you like.  If you use
# `prompt', and this computer may need to reboot unattended, you
# must specify a `timeout', or it will sit there forever waiting
# for a keypress.  `single-key' goes with the `alias' lines in the
# `image' configurations below.  eg: You can press `1' to boot
# `Linux', `2' to boot `LinuxOLD', if you uncomment the `alias'.
# message=/boot/bootmess.txt
prompt
timeout=100
#       prompt
#       single-key
#       delay=100
#       timeout=100
# Specifies the VGA text mode at boot time. (normal, extended, ask, <mode> )
# vga=ask
# vga=9
#vga=791
vga=normal
# Kernel command line options that apply to all installed images go
# here.  See: The `boot-prompt-HOWTO' and `kernel-parameters.txt' in
# the Linux kernel `Documentation' directory.
# append="hdc=ide-scsi"
# Boot up Linux by default.
default=Linux_2.4.21
image=/vmlinuz
        label=Linux_2.2.0
        read-only
#       restricted
#       alias=1
image=/boot/bz-2.4.20
        label=Linux_2.4.20
        read-only
image=/boot/bz-2.4.21
        label=Linux_2.4.21
        read-only
image=/boot/bz-2.6.0-test1
        label=2.6.0-test1
        read-only
# If you have another OS on this machine to boot, you can uncomment the
# following lines, changing the device name on the `other' line to
# where your other OS' partition is.
# other=/dev/hda4
#       label=HURD
#       restricted
#       alias=3
other=/dev/hda1
  label="WindowsXP"
[root@athlon boot]# ls -l
total 5046
-rw-r--r--    1 root     root          512 2003-06-02 12:48 boot.0300
lrwxrwxrwx    1 root     root            9 2003-08-21 21:43 boot.b -> boot.0300
-rw-r--r--    1 root     root       830999 2003-06-13 20:49 bz-2.4.20
-rw-r--r--    1 root     root       851980 2003-08-13 08:19 bz-2.4.21
-rw-r--r--    1 root     root      1122877 2003-07-16 00:47 bz-2.6.0-test1
-rw-r--r--    1 root     root         3888 2003-06-02 12:36 config-2.2.20-idepci
lrwxrwxrwx    1 root     root           38 2003-08-19 17:59 debianlilo.bmp -> /usr/share/lilo/contrib/debianlilo.bmp
-rw-------    1 root     root        54784 2003-08-13 08:21 map
lrwxrwxrwx    1 root     root           33 2003-08-19 17:59 sarge.bmp -> /usr/share/lilo/contrib/sarge.bmp
lrwxrwxrwx    1 root     root           31 2003-08-19 17:59 sid.bmp -> /usr/share/lilo/contrib/sid.bmp
-rw-r--r--    1 root     root       224124 2003-06-02 12:36 System.map-2.2.20-idepci
-rw-r--r--    1 root     root       420929 2003-06-02 12:51 System.map-2.4.20
-rw-------    1 root     root       434494 2003-08-21 21:34 System.map-2.4.21
-rw-r--r--    1 root     root       530382 2003-07-16 00:54 System.map-2.6.0-test1
-rw-r--r--    1 root     root       665509 2003-06-02 12:36 vmlinuz-2.2.20-idepci
que du classic ...
j'y comprends rien, j'ai rien touché ...
Marsh Posté le 22-08-2003 à 16:33:32
UP  :cry:
