problème resolution en OpenGL - Installation - Linux et OS Alternatifs
Marsh Posté le 20-08-2003 à 19:58:33
Est-ce que tu a edite ton fichier /etc/X11/XF68config (ou XF86config-4 selon ta distrib) pour les bonnes resolutions ?
Poste ta configuration de la section "screen" de ce fichier.
Marsh Posté le 20-08-2003 à 20:23:42
oui je l'ai edité pour les pilotes nvidia dejà
ça donne ça :
# File generated by XFdrake.
# Refer to the XF86Config man page for details about the format of
# this file.
Section "Files"
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Mandrake 6.0 and later now use a font server independent of
# the X server to render fonts.
FontPath "unix/:-1"
EndSection
Section "ServerFlags"
#DontZap # disable <Crtl><Alt><BS> (server abort)
AllowMouseOpenFail # allows the server to start up even if the mouse doesn't work
#DontZoom # disable <Crtl><Alt><KP_+>/<KP_-> (resolution switching)
EndSection
Section "Module"
Load "dbe" # Double-Buffering Extension
Load "v4l" # Video for Linux
Load "extmod"
Load "type1"
Load "freetype"
Load "glx" # 3D layer
EndSection
Section "InputDevice"
Identifier "Keyboard1"
Driver "Keyboard"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr"
Option "XkbCompat" ""
Option "XkbOptions" ""
EndSection
Identifier "Mouse1"
Driver "mouse"
Option "Protocol" "IMPS/2"
Option "Device" "/dev/psaux"
Option "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
Identifier "monitor1"
VendorName "Generic"
ModelName "1600x1200 @ 76 Hz"
HorizSync 31.5-94.0
VertRefresh 50-90
# Sony Vaio C1(X,XS,VE,VN)?
# 1024x480 @ 85.6 Hz, 48 kHz hsync
ModeLine "1024x480" 65.00 1024 1032 1176 1344 480 488 494 563 -hsync -vsync
# TV fullscreen mode or DVD fullscreen output.
# 768x576 @ 79 Hz, 50 kHz hsync
ModeLine "768x576" 50.00 768 832 846 1000 576 590 595 630
# 768x576 @ 100 Hz, 61.6 kHz hsync
ModeLine "768x576" 63.07 768 800 960 1024 576 578 590 616
EndSection
Section "Device"
Identifier "device1"
VendorName "NVidia"
BoardName "NVIDIA GeForce4 (generic)"
Driver "nvidia"
Option "DPMS"
EndSection
Section "Screen"
Identifier "screen1"
Device "device1"
Monitor "monitor1"
DefaultColorDepth 24
Subsection "Display"
Depth 8
Modes "1280x960" "1152x864" "1024x768" "800x600" "640x480"
EndSubsection
Depth 15
EndSubsection
Depth 16
EndSubsection
Depth 24
EndSubsection
EndSection
Section "ServerLayout"
Identifier "layout1"
InputDevice "Keyboard1" "CoreKeyboard"
InputDevice "Mouse1" "CorePointer"
Screen "screen1"
EndSection
Marsh Posté le 20-08-2003 à 20:46:21
OK.
Est-ce que tu t'es assure que ta carte nvidia supporte la resolution que tu veux ?
Je veux dire par la que les resolutions pour une carte donnee sont fixees en hardware, genre tu peux pas mettre des valeurs arbitraires style 1000*500.
Essaye de rajouter 1600*1200 dans ta config pour voir si cela fonctionne et de voir si les jeux fonctionne en fullscreen dans cette resolution.
Autre possibilite : je remarque que la frequence de rafraichissement verticale de ton ecran est fort basse. Il veut peut etre pas changer la resolution a cause de ca parce que le modeline correspondant a la resolution que tu veux est en dehors de la plage acceptee par ta config.
Par exemple mon ecran qui vraiment pas luxueux accepte de 50-160 hz. FAIS GAFFE a ne pas changer cette valeur si tu connais pas la plage de valeurs acceptees : TU POURRAIS GRILLER TON ECRAN. Cherche dans le manuel de ton ecran les bonnes valeurs et/ou sur le site du constructeur.
Penses a redemarrer ton serveur X pour prendre en consideration tout changement fait a ce fichier.
Autre chose maintenant : tu dis que ca marche en mode fenetre quand tu vas en opengl en 1280*960, est ce que c'est un vraie fenetre (tu peux la deplacer etc, ...) ou bien c'est genre fullscreen avec des couleurs bizarres autour de la "scene" du jeu ? Tu as bien cocher fullscreen dans le jeu lui-meme ? (on sait jamais
Marsh Posté le 20-08-2003 à 18:35:58
Voilà j'ai un petit souci
Mon bureau est configuré en 1280*960 (4/3)
quand je joue à RTCW ET et les jeux openGL linux que j'ai (RTCW et QUAKE III) si je depasse les 1152*864 alors le jeu n'est plus en full screen mais dans une fenêtre
Je pense que c'est un truc tout con à editer
De plus si je passe la resolution du bureau en 1280*1024 apres les jeux ne fonctionnent plus, mais je veux mon bureau en 1280*960 et plus tant qu'à faire pour les jeux
Merci de m'aider !
