[reglé] probleme de frequence (xorg.conf) - Mal aux yeux ^^
probleme de frequence (xorg.conf) - Mal aux yeux ^^ [reglé] - Installation - Linux et OS Alternatifs
Marsh Posté le 05-07-2006 à 15:55:51
salut
jme suis installé une xubuntu (base : breezy)
le probleme c'est que ma fréquence ne dépasse pas les 60Hz
mon vieux 15" est pourtant capable d'afficher du 72Hz en 1024 et c'est ce que je voudrais
alors j'ai aussi pris soin d'installer les drivers nvidia mais ça ne change rien
voici mon fichier xorg.conf
  1. # /etc/X11/xorg.conf (xorg X Window System server configuration file)
  2. #
  3. # This file was generated by dexconf, the Debian X Configuration tool, using
  4. # values from the debconf database.
  5. #
  6. # Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
  7. # (Type "man /etc/X11/xorg.conf" at the shell prompt.)
  8. #
  9. # This file is automatically updated on xserver-xorg package upgrades *only*
  10. # if it has not been modified since the last upgrade of the xserver-xorg
  11. # package.
  12. #
  13. # If you have edited this file but would like it to be automatically updated
  14. # again, run the following command:
  15. #   sudo dpkg-reconfigure -phigh xserver-xorg
  16. Section "Files"
  17. FontPath "/usr/share/X11/fonts/misc"
  18. FontPath "/usr/share/X11/fonts/cyrillic"
  19. FontPath "/usr/share/X11/fonts/100dpi/:unscaled"
  20. FontPath "/usr/share/X11/fonts/75dpi/:unscaled"
  21. FontPath "/usr/share/X11/fonts/Type1"
  22. FontPath "/usr/share/X11/fonts/CID"
  23. FontPath "/usr/share/X11/fonts/100dpi"
  24. FontPath "/usr/share/X11/fonts/75dpi"
  25.         # paths to defoma fonts
  26. FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
  27. FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
  28. EndSection
  29. Section "Module"
  30. Load "GLcore"
  31. Load "i2c"
  32. Load "bitmap"
  33. Load "ddc"
  34. Load "dri"
  35. Load "extmod"
  36. Load "freetype"
  37. Load "glx"
  38. Load "int10"
  39. Load "type1"
  40. Load "vbe"
  41. EndSection
  42. Section "InputDevice"
  43. Identifier "Generic Keyboard"
  44. Driver  "kbd"
  45. Option  "CoreKeyboard"
  46. Option  "XkbRules" "xorg"
  47. Option  "XkbModel" "pc105"
  48. Option  "XkbLayout" "fr"
  49. Option  "XkbVariant" "latin9"
  50. EndSection
  51. Section "InputDevice"
  52. Identifier "Configured Mouse"
  53. Driver  "mouse"
  54. Option  "CorePointer"
  55. Option  "Device"  "/dev/input/mice"
  56. Option  "Protocol"  "ImPS/2"
  57. Option  "Emulate3Buttons" "true"
  58. Option  "ZAxisMapping"  "4 5"
  59. EndSection
  60. Section "Device"
  61. Identifier "Carte vidéo générique"
  62. Driver  "nvidia"
  63. BusID  "PCI:1:0:0"
  64. EndSection
  65. Section "Monitor"
  66. Identifier "Écran générique"
  67. Option  "DPMS"
  68. HorizSync 28-51
  69. VertRefresh 43-60
  70. EndSection
  71. Section "Screen"
  72. Identifier "Default Screen"
  73. Device  "Carte vidéo générique"
  74. Monitor  "Écran générique"
  75. DefaultDepth 24
  76. SubSection "Display"
  77.  Depth  1
  78.  Modes  "1024x768" "800x600" "640x480"
  79. EndSubSection
  80. SubSection "Display"
  81.  Depth  4
  82.  Modes  "1024x768" "800x600" "640x480"
  83. EndSubSection
  84. SubSection "Display"
  85.  Depth  8
  86.  Modes  "1024x768" "800x600" "640x480"
  87. EndSubSection
  88. SubSection "Display"
  89.  Depth  15
  90.  Modes  "1024x768" "800x600" "640x480"
  91. EndSubSection
  92. SubSection "Display"
  93.  Depth  16
  94.  Modes  "1024x768" "800x600" "640x480"
  95. EndSubSection
  96. SubSection "Display"
  97.  Depth  24
  98.  Modes  "1024x768" "800x600" "640x480"
  99. EndSubSection
  100. EndSection
  101. Section "ServerLayout"
  102. Identifier "Default Layout"
  103. Screen  "Default Screen"
  104. InputDevice "Generic Keyboard"
  105. InputDevice "Configured Mouse"
  106. EndSection
  107. Section "DRI"
  108. Mode 0666
  109. EndSection
est-ce qu'un spécialiste xorg pourrait me venir en aide ?
merci par avance  :jap:
Message édité par soitfranc le 05-07-2006 à 16:46:01
Marsh Posté le 05-07-2006 à 16:14:34
Regarde à la ligne 75 de ton fichier de config, tu as écrit :
"VertRefresh    43-60". Cela veut dire que ton moniteur ne montera pas plus haut que 60Hz! Spécifie quelque chose comme 43-72 (suivant les spec de ton moniteur), redémare le serveur x. Cela devrait suffire pour soulager tes nieuzes :)
Marsh Posté le 05-07-2006 à 16:28:07
merci de ta réponse et de penser à mes nieuzes budo-ka :D
j'ai essayé de mettre 72 à la place de 60 mais ça fonctionne uniquement pour les résolutions inférieures à 1024
on est po loin du but :)
Marsh Posté le 05-07-2006 à 16:29:51
mets 16 au lieu de 24 à la ligne 82.
tu va reduire un peu le nombre de couleurs, mais tu verras
pas de différence et tu va pouvoir libérer un peu de ram,
pour faire plus que du 800x600
Marsh Posté le 05-07-2006 à 16:30:40
Consultes les catacteristiques de ecran sur le site du constructeur.
Décentralisons Internet-Bépo-Troll Bingo - "Pour adoucir le mélange, pressez trois quartiers d’orange !"
Marsh Posté le 05-07-2006 à 16:43:36
merci pour vos réponses !
@memaster62 : ok j'ai testé, en effet je passe bien en 16bits mais ma résolution 1024 était toujours en 60Hz
@Homer_Simp : H Freq/ V Freq: 31-60 / 50-115
(http://www.monitorworld.com/Monitors/compaq/v50.html)
maintenant ça marche  :sol: en 75Hz !  j'aurais plus mal aux yeux grace à vous  :ouch:
[:am7] MERFFFI
Message édité par soitfranc le 05-07-2006 à 16:44:05
