mplayer + gui probleme a la configuration -->APOLON34 (stp)
mplayer + gui probleme a la configuration -->APOLON34 (stp) - Linux et OS Alternatifs
Marsh Posté le 08-03-2002 à 14:31:53
alors voila je suis ss MDK8.0 et je veux configurer mplayer avant de le compiller pour k il gère les skin : alors je tape :
 ./configure --disable-gcc-checking --enable-gui
et voila les commentaires :
Detected operating system: Linux
Detected host architecture: i386
Hmm. You really want to compile MPlayer with an *UNSUPPORTED* C compiler?
Ok. You know. Do it. But did you already read DOCS/gcc-2.96-3.0.html ???
DO NOT SEND BUGREPORTS OR COMPLAIN, it's *YOUR* compiler's fault!
Get ready for mysterious crashes, no-picture bugs, strange noises... REALLY!
Lame which is used by mencoder produces weird errors, too.
If you have any problem, then install GCC 2.95.x or 3.x version and try again.
If the problem _still_ exists, then read DOCS/bugreports.html !
  *** DO NOT SEND BUGREPORTS OR COMPLAIN it's *YOUR* compiler's fault! ***
Checking for CPU vendor ... GenuineIntel (6:8:6)
Checking for CPU type ...  Pentium III (Coppermine)
Checking for GCC & CPU optimization abilities ... i686
Checking for kernel support of mmx ... yes
Checking for kernel support of mmx2 ... yes
Checking for kernel support of sse ... yes
Checking for mtrr support ... yes
Checking for assembler (as 2.10.91) ... ok
Checking for Linux kernel version ... 2.4.3-20mdk, ok
Checking for extra headers ... none
Checking for extra libs ... none
Checking for kstat ... no
Checking for posix4 ... no
Checking for nanosleep ... yes
Checking for socklib ... yes (using -lnsl)
Checking for inet_pton() ... yes (using -lnsl)
Checking for stdint.h ... yes
Checking for malloc.h ... yes
Checking for memalign() ... yes
Checking for alloca.h ... yes
Checking for mman.h ... yes
Checking for dynamic loader ... yes
Checking for pthread ... yes (using -lpthread)
Checking for sys/soundcard.h ... yes
Checking for termcap ... no
Checking for termios ... yes (using sys/termios.h)
Checking for shm ... yes
Checking for 3dfx ... no
Checking for tdfxfb ... no
Checking for DirectFB ... no
Checking for language ... using en
Checking for vsscanf() ... yes
Checking for X11 headers ... yes (using /usr/include)
Checking for X11 libs ... yes (using /usr/X11R6/lib)
Checking for X11 ... yes
Checking for DPMS ... yes (using Xdpms 4)
Checking for Xv ... yes
Checking for Xinerama ... yes
Checking for Xxf86vm ... yes
Checking for DGA ... yes (using DGA 2.0)
Checking for OpenGL ... yes
Checking for /dev/mga_vid ... no
Checking for syncfb ... no
Checking for xmga ... no
Checking for GGI ... no
Checking for AA ... no
Checking for SVGAlib ... no
Checking for FBDev ... no
Checking for DVB ... no
Checking for PNG support ... yes
Checking for VESA support ... yes
Checking for SDL ... yes (using sdl-config)
Checking for NAS ... no
Checking for DXR3/H+ ... no
Checking for libmp1e ... no
Checking for OSS Audio ... yes
Checking for ALSA audio ... no
Checking for Sun audio ... no
Checking for Sun mediaLib ... no
Checking for SGI Audio ... no
Checking for VCD support ... ok
Checking for DVD support ... no
Checking for zlib ... no
Checking for RTC ... yes
Checking for mad support ... no
Checking for OggVorbis support ... no
Checking for Win32 DLL support ... yes (using /usr/lib/win32)
Checking for DirectShow ... yes
Checking for XAnim DLL ... no (no suitable directory found - see DOCS/codecs.html)
Checking for iconv ... yes
Checking for FFmpeg libavcodec (static) ... yes
Checking for Divx4linux decore ... not found
Checking for libmp3lame (for mencoder) ... no
Checking for Divx4linux encore (for mencoder) ... no
Checking for lirc ... no
Checking for fastmemcpy ... yes
Checking for TV interface ... yes
Checking for Video 4 Linux TV interface ... yes
Checking for select ... yes
Checking for streaming ... yes
Checking for GUI ... yes
Error: PNG support required for GUI compilation
Check configure.log if you do not understand why it failed.
et moi je comprend po pourkoi ca marche po :??:
noté ke j ai souligné des les commentaires ce qui parait ce rapporter au GUI.
et sans l option gui j ai pas de prob.
[jfdsdjhfuetppo]--Message édité par yank--[/jfdsdjhfuetppo]
Marsh Posté le 08-03-2002 à 16:45:35
j'ai deja eu le probleme....
verifie si t'as bien les lib png ou qqch du meme genre meme si il te dit que c bon
version execution et developpement bien sur
Marsh Posté le 09-03-2002 à 19:00:21
j ai installé ts les packages contenant le mot png et pis ca change rien :(
Marsh Posté le 11-03-2002 à 17:31:15
UP SVP :bounce:
Marsh Posté le 12-03-2002 à 17:06:22
Marsh Posté le 12-03-2002 à 21:13:03
apolon34> explique comment tu as resolut ton prob STP ???
Marsh Posté le 12-03-2002 à 21:18:01
fais voir :
> rpm -qa | grep png
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
Marsh Posté le 12-03-2002 à 21:30:10
lut Dark ;)
grep =
libpng2-1.0.9-1mdk
gif2png-2.4.0-1mdk
libpng2-devel-1.0.9-1mdk
libclanlib0-png-0.4.4-25md
et pis rpmdrake ne me trouve plus rien avec du png à installer depuis les cd de la distrib.
Marsh Posté le 12-03-2002 à 21:33:12
mhhhhhhhhhhhhh
essaie  ceci. dans le rep des sources de mplayer :
> rm config.cache
Marsh Posté le 12-03-2002 à 21:37:55
pas de ca ds mon rep!!! ni de cache.config ...
Marsh Posté le 13-03-2002 à 03:03:35
essaye avec libpng3 et libpng3-devel
http://forum-darius.fr.st/
Marsh Posté le 13-03-2002 à 12:59:26
j ai deja eu le meme probleme et j ai installer les dernieres version de libpng et d une part ca ne marche pas et d autre part tout les programmes aue je lance qui utilise cette lib se referme aussitot. la fenetre s affiche et s eteint, en gros je doit tout faire en mode console... pour resoudre le proble;e j ai formater mais je ne pense pas que ce soit la solution la plus simple. mais bon en gros ce aue je veux dire c fait gaffe!!!!
Marsh Posté le 13-03-2002 à 13:04:47
c pas les rpm png qui ont étés installés en forçant ???
des versions pas faites pour la MDK8  ????
Marsh Posté le 13-03-2002 à 15:24:40
je tir mes rpm png de la distrib mdk ...
magot m a foutu les boules avec sont histoire alors j ose pas essayer :(
si j analyse tous ca, ca marche pas pour tout le monde et pis ont peu rien y faire :??:
Marsh Posté le 13-03-2002 à 16:33:17
men rappelles plus.....
je vais te filer la liste des msg a la compil si ca peut t'aider
Checking for CPU vendor ... AuthenticAMD (6:7:0)
Checking for CPU type ...  AMD Duron(tm) processor
Checking for GCC & CPU optimization abilities ... athlon
Checking for kernel support of 3dnow ... yes
Checking for kernel support of 3dnowex ... yes
Checking for assembler (as 2.11.90.0.8) ... ok
Checking for Linux kernel version ... 2.4.7-10custom, ok
Checking for ALSA audio ... yes (using alsa 0.9.x)
Checking for DVD support ... libdvdread
Checking for zlib ... yes
Checking for Divx4linux decore ... yes
Checking for Divx4linux encore (for mencoder) ... yes
Checking for XShape extension ... yes
Checking for gtk version ... 1.2.10 (using gtk-config)
Checking for glib version ... 1.2.10 (using glib-config)
Creating Gui/config.mak
Creating config.mak
Creating config.h
Creating libvo/config.mak
Creating libao2/config.mak
Creating help_mp.h
Config files successfully generated by ./configure !
  Install prefix: /usr/local
  Data directory: /usr/local/share/mplayer
  Config direct.: /usr/local/share/mplayer
  Enabled optional drivers:
    Input: network tv-v4l tv dvdread vcd
    Codecs: divx4linux libavcodec directshow win32
    Audio output: alsa9 oss sdl
    Video output: sdl vesa png mpegpes(file) opengl dga xv x11
'config.h' and 'config.mak' contain your configuration options.
Note: if you alter theses files (for instance CFLAGS) MPlayer may no longer
      compile *** DON'T BUGREPORT if you tweak these files ***
'make' will now compile MPlayer and 'make install' will install it.
Note: On non-Linux systems you might need to use 'gmake' instead of 'make'.
Please check mtrr settings at /proc/mtrr (see DOCS/video.html#2.2.1.1)
If you cannot understand why a test failed please check configure.log.
If you believe it is a bug in configure, please report it.
voila j'espere que ca peut t'aider.....
Marsh Posté le 13-03-2002 à 21:04:52
il faut pas etre aussi defetiste il y a bien quelqu'un pour qui ca marche, mais au fait tu utilise quelle version de mplayer se ne serait pas un bug de cette version car il dit:
libpng yes
puis probleme avec libpng, c bizarre non???
Marsh Posté le 13-03-2002 à 21:32:02
ma version (0.6) m'a fait ca aussi....
j'ai installe pleins de trucs depuis et maintenant ca marche
Marsh Posté le 14-03-2002 à 19:44:11
moi aussi c est la 0.6...
je vais essayer d installer plein de truc en comparant avec ton fichier configure apolon34 et pis on verra (vive la cuisine :lol: )
Marsh Posté le 14-03-2002 à 20:12:31
ouais j pense que ya pu que ca a faire
c sur que c pas tip top mais je peux pas t'aider plus
Marsh Posté le 16-03-2002 à 16:11:45
ma cuisine a fonctionner :)
merci apollon34 car il me manquait Zlib!!!
je vais encore plus pouvoir apprécier Mplayer :hap:
Marsh Posté le 16-03-2002 à 16:43:31
de rien!!!
content pour toi et c'est vrai que mplayer est tres beau!!
