xfree probleme parametrage
xfree probleme parametrage - Linux et OS Alternatifs
Marsh Posté le 04-08-2002 à 12:44:10
j'essaie d'installer XFree depuis un petit moment et impossible....
Ma carte graphique est normalement prise en charge et quand je fais un startx , je vois qu'il essaie de lancer xfree, et puis message:
XFree86 Version 3.3.3.1 / X Window System
(protocol Version 11, revision 0, vendor release 6300)
Release Date: December 29 1998
 If the server is older than 6-12 months, or if your card is newer
 than the above date, look for a newer version before reporting
 problems.  (see http://www.XFree86.Org/FAQ)
Operating System: Linux 2.0.35 i686 [ELF]
Configured drivers:
  SVGA: server for SVGA graphics adaptors (Patchlevel 0):
      NV1, STG2000, RIVA128, RIVATNT, ET4000, ET4000W32, ET4000W32i,
      ET4000W32i_rev_b, ET4000W32i_rev_c, ET4000W32p, ET4000W32p_rev_a,
      ET4000W32p_rev_b, ET4000W32p_rev_c, ET4000W32p_rev_d, ET6000, ET6100,
      et3000, pvga1, wd90c00, wd90c10, wd90c30, wd90c24, wd90c31, wd90c33,
      gvga, ati, sis86c201, sis86c202, sis86c205, sis86c215, sis86c225,
      sis5597, sis5598, sis6326, tvga8200lx, tvga8800cs, tvga8900b,
      tvga8900c, tvga8900cl, tvga8900d, tvga9000, tvga9000i, tvga9100b,
      tvga9200cxr, tgui9400cxi, tgui9420, tgui9420dgi, tgui9430dgi,
      tgui9440agi, cyber9320, tgui9660, tgui9680, tgui9682, tgui9685,
      cyber9382, cyber9385, cyber9388, cyber9397, cyber9520, 3dimage975,
      3dimage985, clgd5420, clgd5422, clgd5424, clgd5426, clgd5428,
      clgd5429, clgd5430, clgd5434, clgd5436, clgd5446, clgd5480, clgd5462,
      clgd5464, clgd5465, clgd6205, clgd6215, clgd6225, clgd6235, clgd7541,
      clgd7542, clgd7543, clgd7548, clgd7555, clgd7556, ncr77c22, ncr77c22e,
      cpq_avga, mga2064w, mga1064sg, mga2164w, mga2164w AGP, mgag200,
      mgag100, oti067, oti077, oti087, oti037c, al2101, ali2228, ali2301,
      ali2302, ali2308, ali2401, cl6410, cl6412, cl6420, cl6440, video7,
      ark1000vl, ark1000pv, ark2000pv, ark2000mt, mx, realtek, s3_virge,
      AP6422, AT24, AT3D, s3_svga, NM2070, NM2090, NM2093, NM2097, NM2160,
      NM2200, ct65520, ct65525, ct65530, ct65535, ct65540, ct65545, ct65546,
      ct65548, ct65550, ct65554, ct65555, ct68554, ct69000, ct64200,
      ct64300, mediagx, V1000, V2x00, p9100, spc8110, generic
(using VT number 7)
XF86Config: /etc/XF86Config
(**) stands for supplied, (--) stands for probed/default values
(**) XKB: keymap: "xfree86(fr)" (overrides other XKB settings)
(**) Mouse: type: Microsoft, device: /dev/ttyS0, baudrate: 1200
(**) Mouse: buttons: 3
(**) SVGA: Graphics device ID: "My Video Card"
(**) SVGA: Monitor ID: "My Monitor"
(--) SVGA: Mode "1024x768" needs vert refresh rate of 86.96 Hz. Deleted.
(--) SVGA: Mode "640x400" needs vert refresh rate of 85.08 Hz. Deleted.
(--) SVGA: Mode "640x480" needs vert refresh rate of 75.00 Hz. Deleted.
(--) SVGA: Mode "640x480" needs vert refresh rate of 85.01 Hz. Deleted.
(--) SVGA: Mode "1152x864" needs vert refresh rate of 89.18 Hz. Deleted.
(--) SVGA: Mode "800x600" needs vert refresh rate of 72.19 Hz. Deleted.
(--) SVGA: Mode "640x480" needs hsync freq of 53.01 kHz. Deleted.
(--) SVGA: Mode "1152x864" needs hsync freq of 53.51 kHz. Deleted.
(--) SVGA: Mode "800x600" needs hsync freq of 55.84 kHz. Deleted.
(--) SVGA: Mode "1024x768" needs hsync freq of 56.48 kHz. Deleted.
(--) SVGA: Mode "1280x1024" needs hsync freq of 51.02 kHz. Deleted.
(--) SVGA: Mode "800x600" needs hsync freq of 64.02 kHz. Deleted.
(--) SVGA: Mode "1024x768" needs hsync freq of 62.50 kHz. Deleted.
(--) SVGA: Mode "1152x864" needs hsync freq of 62.42 kHz. Deleted.
(--) SVGA: Mode "1280x1024" needs hsync freq of 64.25 kHz. Deleted.
(--) SVGA: Mode "1024x768" needs hsync freq of 70.24 kHz. Deleted.
(--) SVGA: Mode "1152x864" needs hsync freq of 70.88 kHz. Deleted.
(--) SVGA: Mode "1280x1024" needs hsync freq of 74.59 kHz. Deleted.
(--) SVGA: Mode "1600x1200" needs hsync freq of 75.00 kHz. Deleted.
(--) SVGA: Mode "1152x864" needs hsync freq of 76.01 kHz. Deleted.
(--) SVGA: Mode "1280x1024" needs hsync freq of 78.86 kHz. Deleted.
(--) SVGA: Mode "1024x768" needs hsync freq of 80.21 kHz. Deleted.
(--) SVGA: Mode "1280x1024" needs hsync freq of 81.13 kHz. Deleted.
(--) SVGA: Mode "1600x1200" needs hsync freq of 87.50 kHz. Deleted.
(--) SVGA: Mode "1152x864" needs hsync freq of 89.62 kHz. Deleted.
(--) SVGA: Mode "1280x1024" needs hsync freq of 91.15 kHz. Deleted.
(--) SVGA: Mode "1600x1200" needs hsync freq of 93.75 kHz. Deleted.
(--) SVGA: Mode "1600x1200" needs hsync freq of 105.77 kHz. Deleted.
(--) SVGA: Mode "1280x1024" needs hsync freq of 107.16 kHz. Deleted.
(--) SVGA: Mode "1800X1440" needs hsync freq of 96.15 kHz. Deleted.
(--) SVGA: Mode "1800X1440" needs hsync freq of 104.52 kHz. Deleted.
(--) SVGA: Mode "512x384" needs vert refresh rate of 77.97 Hz. Deleted.
(--) SVGA: Mode "512x384" needs vert refresh rate of 85.09 Hz. Deleted.
(--) SVGA: Mode "320x240" needs vert refresh rate of 75.14 Hz. Deleted.
(--) SVGA: Mode "400x300" needs vert refresh rate of 72.19 Hz. Deleted.
(--) SVGA: Mode "480x300" needs vert refresh rate of 72.07 Hz. Deleted.
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/75dpi/:unscaled,/usr/X11R6/lib/X11/fonts/75dpi/"
(--) SVGA: WD: Signature for WD90C[23]X=[0x32 0x34]
(--) SVGA: WD: Detected 90C24.  Try 90C30 or 90C31 if this doesn't work.
(--) SVGA: WD: FP_Lock = 0xa0:
(--) SVGA: WD: Current clock is 0x5
(--) SVGA: chipset:  wd90c24
(--) SVGA: videoram: 512k
(--) SVGA: clocks:  28.32  28.32  28.32  28.32  28.32  28.32  28.32  28.32
(--) SVGA: clocks:  44.80
(**) SVGA: Using 8 bpp, Depth 8, Color weight: 666
(--) SVGA: Maximum allowed dot-clock: 90.000 MHz
(--) SVGA: There is no defined dot-clock matching mode "800x600"
(--) SVGA: Removing mode "800x600" from list of valid modes.
(--) SVGA: There is no defined dot-clock matching mode "640x480"
(--) SVGA: Removing mode "640x480" from list of valid modes.
(--) SVGA: There is no defined dot-clock matching mode "640x400"
Fatal server error:
No valid modes found.
When reporting a problem related to a server crash, please send
the full server output, not just the last messages
PLEASE HELP...
Marsh Posté le 04-08-2002 à 12:45:25
la plage de fréquence définie pour ton écran doit être erronée.
Marsh Posté le 04-08-2002 à 13:18:15
je crois que j'ai essayé toutes les freqences et tailles possiles :cry:
Cependant je n'ai pas mis de Clockchip, comment savoir si je dois en mettre une et laquelle choisir.
PS je suis sous  Slakeware tiny avec un 486.
Marsh Posté le 04-08-2002 à 13:47:41
oula up :bounce:
Marsh Posté le 04-08-2002 à 14:06:22
Tiens va voir ici ... je sais pas si ca peux t'aider mais bon on sait jamais ... http://koala.ilog.fr/cgi-bin/nph-colas-modelines-fr
Marsh Posté le 04-08-2002 à 15:51:29
c ta plage de fréquence qui va pas.
