I need help changing my FSB on this mobo i can change a jumper and change the clock speed to 450 but when the system is running its still 350 mhz. I cant find a program to download that works with this board is there anyway to access hidden features in the bios? It has a pheonix bios. If anyone knows of anyway to overclock this mobo help me out. Also is there anyway to change the clock multiplyer? Here is some system info.
Motherboard Properties Motherboard ID 4S4EB0X1.10A.0019.P09.9808141130 Motherboard Name Intel Seattle SE440BX Front Side Bus Properties Bus Type Intel GTL+ Bus Width 64-bit Real Clock 100 MHz Effective Clock 100 MHz Bandwidth 800 MB/s Memory Bus Properties Bus Type SDR SDRAM Bus Width 64-bit Real Clock 100 MHz Effective Clock 100 MHz Bandwidth 800 MB/s Motherboard Physical Info CPU Sockets/Slots 1 Expansion Slots 2 ISA, 4 PCI, 1 AGP RAM Slots 3 DIMM Form Factor ATX Motherboard Size 200 mm x 300 mm Motherboard Chipset i440BX
BIOS Properties BIOS Type Phoenix 4.0 Release 6.0 Version A09 System BIOS Date 08/14/98 Video BIOS Date 08/16/02 BIOS Manufacturer Company Name Phoenix Technologies Ltd.
CPU Type Intel Pentium II, 350 MHz (3.5 x 100) CPU Alias Deschutes, A80523 CPU Stepping dB0 Instruction Set x86, MMX L1 Code Cache 16 KB L1 Data Cache 16 KB L2 Cache 512 KB (Built-In, Half-Speed)
CPU Physical Info Package Type 242 Contact SEC Cartridge Package Size 12.82 cm x 6.28 cm x 1.64 cm Transistors 7.5 million Process Technology 5M, 0.25 um, CMOS Die Size 131 / 118 mm2 Core Voltage 2.0 V I/O Voltage 3.3 V Typical Power 11 - 24 W (depending on clock speed) Maximum Power 16.8 - 36.4 W (depending on clock speed)
Marsh Posté le 20-12-2007 à 11:11:45
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 100 MHz
Bandwidth 800 MB/s
Bus Type SDR SDRAM
Bus Width 64-bit
Real Clock 100 MHz
Bandwidth 800 MB/s
CPU Sockets/Slots 1
RAM Slots 3 DIMM
Form Factor ATX
BIOS Properties
BIOS Type Phoenix
BIOS Manufacturer
CPU Stepping dB0
L1 Code Cache 16 KB
L1 Data Cache 16 KB
CPU Physical Info
Core Voltage 2.0 V
I/O Voltage 3.3 V
Cuban Holiday Gardening Jobs
