Petit reportage de mon 1er watercooling integré - Water & Xtreme Cooling - Overclocking, Cooling & Modding
Marsh Posté le 07-11-2008 à 10:28:56
Bon soit il est parfait (ce dont je doute) et personne ne trouve rien a redire, soit il est complement naze et personne ne se donne la peine de ma dire pourquoi?
Marsh Posté le 07-11-2008 à 10:38:38
Bah le post est mal présenté
Des balises à gauches à droites mal foutues çà donne pas envie
Quant on prétend à un topic unique on se donne la peine de faire çà bien
Marsh Posté le 31-10-2008 à 19:05:37
Voici mon premier watercooling, je m' excuse de la qualité aleatoire des photos
![http://img399.imageshack.us/img399/7142/image360hq5.th.jpg http://img399.imageshack.us/img399/7142/image360hq5.th.jpg](http://img399.imageshack.us/img399/7142/image360hq5.th.jpg)
[/img]
![http://img183.imageshack.us/img183/5307/image363aa6.th.jpg http://img183.imageshack.us/img183/5307/image363aa6.th.jpg](http://img183.imageshack.us/img183/5307/image363aa6.th.jpg)
[/img]
![http://img372.imageshack.us/img372/7021/image401ks5.th.jpg http://img372.imageshack.us/img372/7021/image401ks5.th.jpg](http://img372.imageshack.us/img372/7021/image401ks5.th.jpg)
[/img]
![http://img265.imageshack.us/img265/6650/image403pi1.th.jpg http://img265.imageshack.us/img265/6650/image403pi1.th.jpg](http://img265.imageshack.us/img265/6650/image403pi1.th.jpg)
[/img]
![http://img530.imageshack.us/img530/909/image405lj3.th.jpg http://img530.imageshack.us/img530/909/image405lj3.th.jpg](http://img530.imageshack.us/img530/909/image405lj3.th.jpg)
[/img]
![http://img158.imageshack.us/img158/5940/image410mc6.th.jpg http://img158.imageshack.us/img158/5940/image410mc6.th.jpg](http://img158.imageshack.us/img158/5940/image410mc6.th.jpg)
[/img]
![http://img371.imageshack.us/img371/8811/image411km3.th.jpg http://img371.imageshack.us/img371/8811/image411km3.th.jpg](http://img371.imageshack.us/img371/8811/image411km3.th.jpg)
[/img]
Alors deja j' ai pas recu le bon boitier j' ai recu la version S (plus petit de 10pourcent, mais payé au prix du 570 normal)
-1ere étape découper le dessus (dremel achetée a l' occasion)
[img]
-2eme etape enlever le cage a disque dur car la 4870 aura du mal a passer (pas prevu car au depart boitier plus grands, merci au ciseau a bois de mon beau-pere)
[img]
-3eme étape mettre de la mousse isolante pour cacher les traces de bricolage et "tenter" de reduire les bruit (ca marche quasiement pas au passage pour ceux qui ca interesserait)
[img]
-4eme étape, caler la pompe, cequi ne fut pas facile du tout, j' ai du utilisé des visses de la carte mere +teflon pour les faire rentrées dans les trous de la pompe + silentblock sur ceux ci le tout posé sur le mousse akasa.
[img]
-5eme étape, reussir a caser le disque dur la dedans, pour cela j' ai utilisé des elastiques a cheveux pour suspendre celui ci.
[img]
-6eme étape le montage du matos j' ai bricolé un interrupteur en facade pour couper tout les ventilos et le mettre en passif la nuit.
[img]
[img]
Voila ce furent les differentes étapes de mon 1er watercooling et de ma 1ere integration dans un boitier, si vous avez des suggestion n' hesitez pas il y en a surement a faire.
merci d'avance
