[Topic Unique] Thermaltake Big water 780e[MAJ Tests Dispo !]
Thermaltake Big water 780e[MAJ Tests Dispo !] [Topic Unique] - Water & Xtreme Cooling - Overclocking, Cooling & Modding
Marsh Posté le 04-04-2008 à 11:57:34
Salut à tous et bienvenue sur le topic dédié au BigWater 780e
http://thermaltakeusa.com/product/Liquid/DIY/cl-w0169/image/780E/01_CL-W0169.gif
les caractéristiques du kit :
Support nVIDIA ESA Technology
5.25 Drive Bay design: liquid cooling system in-a-box to save the space in the chassis and simplifies installation
Mesh design front bezel enhances ventilation
Easy to  install and refill.
12cm Motorsports Radiator :
1. DTT - Dimple Tube Technology swirls the coolant within the radiator to increase thermal transfer.
2. An all-aluminum radiator featuring expanded outer fins and tube style for maximum performance.
Pure Copper Waterblock:
1. Advanced Brazing technology improves reliability and leakage free
2. All-in-one mounting design supports all latest CPU from Intel & AMD. (Includes: Intel Socket   LGA775
    and AMD K8/AM2.)
 Ultra-low noise fan:
1. Silent fan with blue LED (800 ~ 2500rpm).
2. The 4-pin of the fan connector has PWM & thermal control function
High-performance PWM Liquid Pump:
1.Silent and powerful P500(500L/hr) pump provide superb reliability
2.The ceramic bearings significantly extend the life-expectancy of the pump.
3. The 4-pin of the pump connector has PWM & thermal control function
Flow meter:
Accurate monitoring and fast response- Transparent cover clearly shows the movement of the coolant.
Quick connector:
Quickconn connector : Valves shuts off water flow immediately when dismantling to prevents water leakage
Durable 3/8” Tube: Special material to prevent wear & tare from being clogged up or over bending.
P/N
CL-W0169
3U Bay Drives
 Dimension
249.5mm(L) X 149mm(W) X 128mm(H)
Weight
1.74(kg)
Application  CPU
AMD AM2/AM2+
AMD K8
Intel LGA775
Intel P4
Water Block  Material  All copper designed
Dimension  58mm(L) X 58mm(W) X 35mm(H)
Quick install connector
For  9.5mm ID (3/8”) tubing
Weight
318(g)
Pump  Dimensions
75(L) x 70(W) x 75(H) mm
Bearing
Ceramic bearing
Maximum Capacity  500 L/ hr
Rated Voltage  DC 12V
Input current  600 mA
Connector  4 pin
Noise
10 ~16 dBA
Life time
80000 hr (MTBF)
Connector
4-Pin PWM function
Radiator  Dimensions  153(L) x 120(W) x 28(H) mm
Material  Aluminum
Tube Design  Aluminum, Dimple
Fin Design  Aluminum, Louvered
Tubing & Hoes Clip
Fan
Fan Dimension
120(L) x 120(w) x 25(H) mm
Fan Speed
 1600~2400 RPM
Rated Voltage
12V
Noise
10 ~20 dB
Life Expectancy
30,000 hr
Connector
4-Pin PWM function
Liquid Tank  Dimensions
130.2 (L) x 107.2(W) x 51.5(H) mm
Capacity
530 c.c
Tube  Dimensions
9.5mm ID(3/8”) tube
Material
Green UV
Coolant  Capacity
1000 c.c
Major Material Ingredient
Propylene Glycol
Non n'avons pas beaucoup plus d'nfos à son sujet excepté qu'il est une évolution du 760, qu'il prends donc 3 bay au lieu d'une et que les perfs seraient en nette hausse (peut-être que TT se bouge après mon mail datant y a 1 semaine).
Dispo pour la deuxième semaine du moins d'Avril 2008
Message édité par Fssabbagh le 10-04-2008 à 11:21:51
Messatsu !
Marsh Posté le 04-04-2008 à 12:29:09
Vu les perfs du 760 il faut espérer qu'ils auront fait un sacré effort avec celui-ci...
On attend les tests !  :)
Marsh Posté le 04-04-2008 à 13:00:37
Drapal, je leur ai d'ailleur envoye un mail gentil mais bien direct leur expliquant que ds les tests le 760 etait moins perf que le big typhoon donc ca doit etre ca qui les a fait reagir :hello:
Messatsu !
Marsh Posté le 09-04-2008 à 11:30:50
ce genre d'offre quasi plug & play c'est attirant pour les noobs en water comme moi, mais non de dieu, jusqu'a present les perfs etaient bien minables en config silence (un des interet premiers du water) et pas geniales non plus en mode "perfs" avec le ventilo a fond...sans parler des histoires de pompe peu fiables et de kit non evolutif  :o
on trouve encore les premiers cooler master rev² double baie a 60€ sur ldlc ICI mais je ne sais pas ce que ça vaut, quasiment aucun test sur cette version...
pour revenir a ce 780e, 3 baie ça commence a faire bcp, je m'attend aussi au pire niveau tarif...les perfs ont interet d'etre là parce qu'a 150€ on trouve du swiftech 120 compact et qq kits tout fait chez docmicro qui assurent un max (meme le petit ecodoc a 79€)
je drapal ce topic on sait jamais  :D
GT / PSN / Pc-steam :BassTon13 ¤Mon Feed¤
Marsh Posté le 09-04-2008 à 18:13:36
on ne sait jamais :whistle:  :whistle:
Messatsu !
Marsh Posté le 10-04-2008 à 11:21:11
Enfin un test !
http://www.legionhardware.com/docu [...] id=734&p=0
-Au programme :
Armor+
Big Water 780e
Toughpower 850 watts ESA
-nforce ESA
A la lecture du dossier de Legion Hardware, on se rend compte que le ESA est bien plus qu'un simple monitoring. Il permet réellement de créer des profils selon vos besoins (silence ou performance). On peut aussi directement overclocker les différents éléments du PC, comme le processeur, ou bien la carte graphique si celle-ci est une Nvidia.
C'est le système ESA qui est testé et d'après legion hardware c'est une vrai révolution !
http://www.legionhardware.com/Pics/Thermaltake_Nvidia_ESA-enabled_Platform/Image_09.jpg
http://www.legionhardware.com/Pics/Thermaltake_Nvidia_ESA-enabled_Platform/Image_10.jpg
http://www.legionhardware.com/Pics/Thermaltake_Nvidia_ESA-enabled_Platform/Image_18.jpg
Les températures obtenues
Hardware
- Intel Core 2 Duo E6750 (2.66GHz) LGA775
- x2 1024MB Corsair XMS PC3-10600 CAS7 Module(s)
- Seagate 750GB 7200RPM (Serial ATAII)
- ASUS Radeon HD 3850 (512MB)
- ASUS Striker II Extreme (Nvidia nForce 790i Ultra SLI)
- Thermaltake Toughpower ESA (850 watt)
http://www.legionhardware.com/Bench/Thermaltake_Nvidia_ESA-enabled_Platform/High.png
http://www.legionhardware.com/Bench/Thermaltake_Nvidia_ESA-enabled_Platform/Low.png
Message édité par Fssabbagh le 10-04-2008 à 11:33:50
Messatsu !
Marsh Posté le 10-04-2008 à 12:11:46
Bon cette technologie ESA a l'air intéressante ... reste que le test n'est pas très fouillé concernant le 780e.
En tout cas ils ont eu l'air d'apprécier.
Marsh Posté le 10-04-2008 à 14:15:59
drapal : Thermaltake se réveille, preuve qu'ils sont du potentiel  :)
Messatsu !
Marsh Posté le 10-04-2008 à 15:58:41
merci pour ce test ^^
les T°c sont pas mal mais bon si je regarde mon cas perso...pour un quad OC ça me semble insuffisant car là, dans le test, il s'agit d'un e6750 stock a 2.66ghz qui atteint "deja" 54°c en full...
bon etant donné que c'est du water, possible que pour un quad ça ne monte guere plus haut (<60°c)...enfin attendons d'autres test car les resultats de celui sont deja plus encourageant que ceux des productions passées :D
edit: apperement le 760 et le 780 partage le meme rad et la meme pompe, il ya juste un reservoir plus grand et peut etre un ventilo different...je m'en vais rechercher des test du 760 pour voir si touss ne sent pas le petard mouillé :o
Message édité par Bass__Ton le 10-04-2008 à 16:02:03
Marsh Posté le 10-04-2008 à 16:16:45
Rhaaa tu as raison, c'est le même rad !!!
Autant dire que c'est du WC à papa ... dommage je pensais qu'ils avaient enfin sorti un bon water tout integré.
Marsh Posté le 11-04-2008 à 09:22:33
OMG !!!
Messatsu !
Marsh Posté le 11-04-2008 à 09:47:35
mouep c'est quelque peu decevant toussa  :o
néanmoins je garde un petit espoir car j'ai envie de faire mon relou et de remmettre un peu en question le test que j'ai lu sur le bigwater 760 face au bigT...
le rad n'est certes pas enorme mais la pompe a un bon debit, on est pas en face d'un mini gate 80 par exemple...donc niveau matos j'ai envie de dire que c'est correct.
si on ajoute a cela le fait que ici meme sur ce forum, il n'est pas rare de voir des variations enorme de perfs pour un meme matos en raison d'un montage mal réalisé (que l'on croit pourtant bien fait) ou d'un proc concave qui vient tout gacher...je me dit que pour peu que le gars ayant fait le test ait legerement mal monté le 760, genre le waterblock qui bute un peu sur les elements alentours alors que le ventirad lui à été fixé fortement... alors on arrive a des resultats bien pourris :fou:
je vais chercher d'autre test que celui-ci, depuis que j'ai vu un gars modifier un minigate 120 pour refroidir CPU+GPU et avoir de bonnes T°C je me dit que ce genre de matos comme le bigwater ne peut pas être aussi peu performant que ce que ce test laisse penser!
 :ange:   (c'est beau l'espoir)
Marsh Posté le 11-04-2008 à 10:25:03
ayé j'ai trouvé un test un peu plus encourageant:
sur legit reviews
a base de Q6600 stock et OC a 3ghz ce qui est deja pas mal vu que ces bébé ne sont pas reputé pour etre froid...
le test revele qu'effectivement le bigwater se montre moins perfs que le zerotherm nirvana utilisé:
Q6600 @ 3ghz
burn :760i 54°c pour le core le plus chaud/ 49° - chaud
burn :zeroT 47°c core le plus chaud / 44°c - chaud
dans l'absolue c'est quand meme pas mal...bien mais pas top :D
Mais ce n'est pas là le plus important:
en fin de test, le testeur depité (comme nous) par les T°c reflechie a la situation et aux rapport de cause a effets entre rad et ventilo et il decide de simuler un ecart/trou dans son boitier M998 et de refaire les test
c'est sans appel car il retombe a 42°c en burn pour le Q6600 @ 3ghz :ouch:
il faut donc creuser a ce niveau a mon avis messieurs, apperement un simple tweakage alacon destiné a apporter un peu plus d'air frais semble changer du tout au tout les perfs...la simplicité d'installation en format double baie est certes geniale pour le coté plug'n'play mais ça etouffe les perfs et c'est logique puisque le ventilo est situé sur le dessus du bigwater, il peut donc etre facilement obstrué par un graveur de dvd placé juste au dessus de lui !
si j'ai bien tout compris, car je ne suis pas bilingue, c'est pas si degeulasse que ça :D apres faut voir le prix car la concurrence est active
Message édité par Bass__Ton le 11-04-2008 à 10:29:44
Marsh Posté le 11-04-2008 à 11:24:45
Effectivement il a monté le BW tout en haut de sa tour. Du coup il y a peu d'air frais qui rentre au niveau du rad.
Une fois qu'il a plus d'air alors là ça change. Du coup il faudrait trouver un test fait avec un bon gros boitier (comme mon TT Armor par exemple) pour se faire réellement une idée.
Marsh Posté le 12-04-2008 à 13:30:19
Il y a aussi le BigWater 745 qui est top d'après le test :
http://www.virtual-hideout.net/rev [...] ndex.shtml
http://www.virtual-hideout.net/reviews/Mega_Watercooling_Roundup/ThermalTake_W3/16.jpg
Messatsu !
