WIN XP m empeche t il d overclocké ???? voltage core ki fé des truc - Overclocking, Cooling & Modding
Marsh Posté le 28-05-2002 à 19:17:32
jvien de lancer 3DMark 2001 SE
ca tourne impec a 1000 mhz 10X100mhz 1.85 V de core ca chauffe pas trop genre 45 ° radiateur je peut laisser ma main sur la radiateur (ca chauffe un peu kan meme mais c pas intenable du tout )
Marsh Posté le 28-05-2002 à 19:18:36
harfffffffffffffff
mé ca tourne bien pourtant jé pas envie de repasser a 98 SE
c koa ki fou la merde ?
il a un log des voltages core ?
Marsh Posté le 28-05-2002 à 19:44:47
ca c mon system report montrant kilé stable
***** Start of Report *****
<<< General >>>
Program Name: SiSoftware Sandra Standard [Web]
Program Version: 2002.1.8.59
Registered User: JOEBAR_69
Registered Company: FIGHT CLUB
Licence Status: Unregistered Shareware Evaluation Copy. FREE for
personal use.
Licence Extra: See Ordering Document for information on the
Professional version.
Report Done By: JOEBAR_69
Host Name: JOEBAR
System ID: 4E492441-3184-42a5-9518-E41C366D6CDB
Run ID: 38AE3BCB-4537-42d5-AFEC-B7C2FECFA37A
Report Done On: mardi 28 mai 2002
Report Done At: 19:21:51
<<< Comments >>>
Comments: 1000 mhz 1.85v 10X100mhz
<<< CPU Arithmetic Benchmark >>>
< Benchmark Results >
Dhrystone ALU: 2754MIPS
Whetstone FPU: 1372MFLOPS
< Test Status >
SMP Test: No
Total Test Threads: 1
SMT Test: No
Dynamic MP/MT Load Balance: No
Processor Affinity: No
< Processor(s) >
Model: AMD Duron(tm) Processor
Speed: 1.01GHz
Model Number: 1006 (estimated)
Performance Rating: PR1338 (estimated)
L2 On-board Cache: 64kB ECC synchronous write-back
Front Side Bus Speed: 2x 101MHz (202MHz data rate)
< Technology Support >
SSE2 Technology: No
Hyper-Threading Technology: No
< Performance Tips >
Notice N5008: To change benchmarks, click Options.
Notice N5004: Synthetic benchmark. May not tally with 'real-life'
performance.
Notice N5006: Only compare the results with ones obtained using the
same version!
Tip T2: For more information about tips, press F1 and scroll
to the Tips section.
<<< CPU Multi-Media Benchmark >>>
Integer aEMMX/aSSE: 5482it/s
Floating-Point aE3DNow!: 6074it/s
< Test Status >
SMP Test: No
SMT Test: No
< Processor(s) >
Speed: 1.01GHz
Model Number: 1007 (estimated)
Performance Rating: PR1339 (estimated)
MMX Technology: Yes
SSE Technology: No
SSE2 Technology: No
Extended AMD MMX Technology: Yes
3DNow! Technology: Yes
Extended 3DNow! Technology: Yes
performance.
same version!
<<< Memory Bandwidth Benchmark >>>
RAM Bandwidth Int Buffered aEMMX/aSSE:765MB/s
RAM Bandwidth Float Buffered aEMMX/aS:763MB/s
< Int Buffered aEMMX/aSSE (Integer STREAM) Results Breakdown >
Assignment: 769MB/s
Scaling: 768MB/s
Addition: 762MB/s
Triad: 763MB/s
Data Item Size: 4-bytes / 32-bits
Buffering Used: Yes
Bandwidth Efficiency: 95% (estimated)
< Float Buffered aEMMX/aSSE (Float STREAM) Results Breakdown >
Assignment: 768MB/s
Scaling: 768MB/s
Addition: 757MB/s
Triad: 760MB/s
Data Item Size: 8-bytes / 64-bits
Buffering Used: Yes
Bandwidth Efficiency: 94% (estimated)
< Test Statistics >
Array Memory Used: 64MB
SMP Test: No
SMT Test: No
< System Chipset >
Model: VIA Technologies Inc VT8363/5 KT133/KM133 System
Controller
Max. Bus Bandwidth: 1616MB/s (estimated)
< Logical/Chipset Memory Banks >
Bank 0 Setting: 64MB SDRAM 2-2-2CL
Bank 4 Setting: 64MB SDRAM 2-2-2CL
Bank Interleave: 4-way
Memory Bus Speed: 1x 101MHz (101MHz data rate)
Max. Memory Bandwidth: 808MB/s (estimated)
< Instruction Set Support >
MMX Technology: Yes
SSE Technology: No
SSE2 Technology: No
performance.
same version!
Warning W5403: Tests using (E)MMX/SSE(2) are not standard STREAM.
***** End of Report *****
Marsh Posté le 28-05-2002 à 19:10:17
je vous explique mon probleme
je souhaite repasser mon duron 800 a 1000mhz ( stable sous win 98 se ) c un duron debrider sur soltek SL75KAV
donc voila mon blem
je vais dans le bios je met 10x100mhz a 1.825 v pour etre sur , je boot j arrive dans win ca tourne 10 min a 45 ° environ
je remarque une couille dans sisoft sandra au nivo de la motherboard ki marque plus rien en info
je lance MBM5 pour verifier la temp et boum ca plante
je relance je met 1.85 v , ca plante de meme
je met 1.60 , ca plante de meme
alors je comprend plus rien la le processeur surchauffe pas
il tient impec sauf kan je lance des application ki font appelle au sonde (MBM5 a installé un fichier bizarre en dll en disnat kilyruai ptete des blem )
ca vient de WIN XP , de MBM5 ou de ma CM kiné pas stable ?
avant ca marchait impec a 1000mhz sous win 98 se
