CVS to SVN
CVS to SVN - Divers - Programmation
Marsh Posté le 25-08-2008 à 17:39:34
Voila je voudrais convertir un repository CVS en SVN.
Pour cela j'utilise l'utilitaire cvs2svn avec la commande :
$ cvs2svn -s /svnroot/wooyay /cvsroot/wooyay
Le problème est que j'obtiens les erreurs ci-dessous :
Malformed RCS delta in /cvsroot/wooyay/APP_LOGS/MSVC420/DEBUG/Aic/APPLOGSD.EXP,v, revision 1.1: Deletion beyond file end
ERROR: '/cvsroot/wooyay/APP_LOGS/MSVC420/DEBUG/Aic/APPLOGSD.EXP,v' is not a valid ,v file
Malformed RCS delta in /cvsroot/wooyay/APP_LOGS/MSVC420/LOG/Aic/APPLOGSL.EXP,v, revision 1.1: Deletion beyond file end
ERROR: '/cvsroot/wooyay/APP_LOGS/MSVC420/LOG/Aic/APPLOGSL.EXP,v' is not a valid ,v file
Malformed RCS delta in /cvsroot/wooyay/LIB_BANC/LOG/lobmsvc60/Log/Aic/GSTFIL.obj,v, revision 1.1: Deletion beyond file end
ERROR: '/cvsroot/wooyay/LIB_BANC/LOG/lobmsvc60/Log/Aic/GSTFIL.obj,v' is not a valid ,v file
Malformed RCS delta in /cvsroot/wooyay/LIB_EURC/msvc60/Normal/Aic/CRCEUR.obj,v, revision 1.1: Deletion beyond file end
ERROR: '/cvsroot/wooyay/LIB_EURC/msvc60/Normal/Aic/CRCEUR.obj,v' is not a valid ,v file
Malformed RCS delta in /cvsroot/wooyay/LIB_EURS/msvc60/Normal/Aic/CRCEUR.obj,v, revision 1.1: Deletion beyond file end
ERROR: '/cvsroot/wooyay/LIB_EURS/msvc60/Normal/Aic/CRCEUR.obj,v' is not a valid ,v file
Malformed RCS delta in /cvsroot/wooyay/LIB_LOGC/msvc60/Log/Aic/GSTFIL.obj,v, revision 1.1: Deletion beyond file end
ERROR: '/cvsroot/wooyay/LIB_LOGC/msvc60/Log/Aic/GSTFIL.obj,v' is not a valid ,v file
Malformed RCS delta in /cvsroot/wooyay/TST_EURC/msvc60/Normal/Aic/HEXBIN.obj,v, revision 1.1: Deletion beyond file end
ERROR: '/cvsroot/wooyay/TST_EURC/msvc60/Normal/Aic/HEXBIN.obj,v' is not a valid ,v file
Pass 1 complete.
Error summary:
ERROR: '/cvsroot/wooyay/LIB_BANC/LOG/lobmsvc60/Logitele/Attic/GSTFIL.obj,v' is not a valid ,v file
ERROR: '/cvsroot/wooyay/LIB_LOGC/msvc60/Logitele/Aic/GSTFIL.obj,v' is not a valid ,v file
Exited due to fatal error(s).
Quelqu'un a t'il eu ce genre de problème et sait-il comment le régler?
Pour info je suis sous red hat 4, cvs version 1.11.22 et svn version 1.4.3.
Marsh Posté le 26-08-2008 à 14:35:38
Personne n'a une idée ou une autre solution pour migrer un projet CVS vers SVN?
Marsh Posté le 27-08-2008 à 09:44:49
les fichier debug, log et obj, tu ne peux pas les supprimer avant la migration ?
Marsh Posté le 27-08-2008 à 11:57:25
Oui j'ai bien pensé à supprimer les fichiers qui posent problème mais vu que ce n'est pas mon projet je ne connais pas l'impact...
